Intense Carbine 27.5 Vs Kona Process- Mtbr.com
Results 1 to 5 of 5
    Sep 2012
    Title says it all. Looking for a 27.5 XC/trailbike that will handle some occasional bike park stuff and above normal XC drops.
    Ive been eying the Kona Process 134 and 153, and started looking at the Intense Carbine 27.5 too.
    I'm coming off a Jet 9 with 80/100 mm travel, and want to keep the weight down to 26-27 pounds. I will be doing a build and buying frame only.
    How do these bikes compare? I know the travel is plenty. Looking at weight, standover, and handling more than anything.
    Thanks in advance!
    mtbr memeber
    Reputation: jpre's Avatar
    Given your weight goal, imo the Process would be shooting yourself in the foot. I have a 153 and like it, but it's no lightweight.
    Sep 2012
    Quote Originally Posted by jpre View Post
    Is it a factory build, or did you build it? Any idea on frame weight?
    mtbr memeber
    Factory build of the cheaper, heavier one. I'm sorry I don't know the frame weight. It's well over 30 lbs. From what I think I've read around you'd need to drop at least 5 lbs from the oem build to approach your goal. I suppose when I said what I said, I didn't take into account that if you're made of $ then you could probably pull it off.
    Sep 2012
    Yeah the posted weights were high. The carbine frame is lighter than my jet 9, so its a start
  1. kona process 134 sizing
    By NHMB in forum Kona
    Last Post: 02-19-2014, 10:21 AM
  2. Kona Process, Anyone have it yet?
    By Buggyr333 in forum Kona
    Last Post: 07-29-2013, 02:29 PM
  3. Kona Process
    By DirtDogVT in forum Kona
    Last Post: 07-23-2013, 08:39 PM
  4. Kona process
    By EmbraceTheHate in forum All Mountain
    Last Post: 03-15-2013, 06:38 PM
  5. Replies: 0
    Last Post: 02-22-2013, 05:27 AM
