Help with conversion to mullet setup- Mtbr.com
Results 1 to 3 of 3
    Jul 2017
    I have a Santa Cruz N4 2019 model with a Fox Factory 36 fork (27.5) . I am trying to setup mullet without changing the fork. I try with a 29inch wheel with 2.3 Maxxi DHF tyre. Itís just touch the fork crown bridge.
    I hope to stick with 2.3 tyre. Can anyone suggest which model tyre have minimum tyre height? Cause I believe with 2.1 tyre will sure clear.
    Try hard to search online, nothing came out.
    Hope some1 can share some lights here.
    Thank you
    Reputation: d365's Avatar
    If it touches while just spinning the wheel, it will really touch on a hard compression, when the tire deforms. A wider rim could square off the tire profile more, but you're going to be hard pressed to find a low enough profile 2.3 that will clear on compression as is.
    I used to run a 27.5 wheel/2.3 tire on my 26" fork. It would clear with 3-4mm of space just sitting there, but would braaap on a hard compression. I'd bet your set up would catch pretty hard, if it already touches.
    Jul 2017
    Cheers mate. Never thought about that.
    Guess the only solution is to get a 27.5+/29 fork.
    Thank you
  1. Mullet Plus VS 29+ for Summer Setup[emoji769]
    By AllMountin' in forum Fat bikes
    Last Post: 05-24-2020, 09:13 PM
  2. To mullet or not to mullet, that is the question...
    By hardwarz in forum Beginner's Corner
    Last Post: 06-14-2011, 12:29 AM
  3. Replies: 0
    Last Post: 07-18-2007, 08:11 PM
  4. help change my mullet to a 9 speed from a 27
    By dckiteboards in forum Downhill - Freeride
    Last Post: 04-20-2007, 10:56 PM
  5. Thoughts on the mullet setup
    By ParkerFly in forum 29er Bikes
    Last Post: 06-14-2006, 04:21 PM
Members who have read this thread: 18
