Results 1 to 2 of 2
    Feb 2017
    Giant Anthem X3 2014 - Buy used
    Hi, I am new in this forum so I want the opinion from others members, Im from Brazil, so actually I found Giant Anthem 2014 X3 used with some upgrades.
    I want to know if its a good setup
    It comes with
    Frame with no upgrades
    Rock Shox Sid XX with Lock
    XTR rapid fire
    Cranck Set XT
    Rear and Front deraulier XT
    Wheel very basic
    Shimano hydraulic brake basic
    Its a good setup?
    And what can I use from my other bike? I have a Scott Scale 710 with
    Magura TS8
    My wheels are Ryde Edge Mc1 with Dt Swiss Revolution Spokes and Dt Swiss 240s Hubs.
    SLX brake
    Whats the best Rock Shox XX or Magura TS8?
    Reputation: Bahamut2119's Avatar
    Apr 2016
    That bikes definitely been upgraded the fork isn't stock, nor is any part of the drivetrain the question more is how much they asking and what kinda shape is it in. Should also inquire on the suspension service history if neathiers been serviced nor the bushings in the 3 years since that model hit the shops then they may be very questionable and you might be getting in even deeper. Otherwise that's a very nice setup as is and from what I could tell not that you gave us really any details yes everything you got should fit and work on the anthem perfectly. Without knowing the exact spacing and axle type of the wheels I couldn't give you a 100% answer. Looking at the specs the frame uses a 135x5mm integrated QR but they do note its convertible so if you dont get whatever exactly you need to convert to 142x12mm then you may be screwed on the rear unless you spend more money. Don't have a clue how much any of this costs fyi and i'm not a expert if you go for it good luck.
    Edit: oh id probably say the rockshox but then again I dont know much about magura forks there out of my price range.
  1. 2014 Giant Anthem 27.5 3
    By bdalton in forum 27.5
    Last Post: 03-15-2017, 03:24 PM
  2. Replies: 7
    Last Post: 08-03-2014, 06:54 PM
  3. Giant Anthem X3 2014 27,5 need some diet
    By ecadantas in forum 27.5
    Last Post: 06-01-2014, 07:12 PM
  4. 2012 Giant Anthem X 29er 2 or 2014 Giant Talon 27.5 1
    By XDR in forum Beginner's Corner
    Last Post: 10-05-2013, 11:53 PM
  5. 2010 FSR XC PRO vs. 2014 Giant Anthem x 4
    By Clindari in forum Beginner's Corner
    Last Post: 08-22-2013, 11:29 AM
