Results 1 to 11 of 11
Thread: First timer
    NedwannaB
    Reputation: JMac47's Avatar
    First timer
    A big THANKS to Mr. Brown and Outside Outfitters! Now to figure which bike gets what...
    Wait whuuut, who did he tell you that!?!?....
    NedwannaB
    Weird.....
    So much for the Quasi being the smallest of the 650's! Just cheked it on my Laser Disc wheel in the back of the KHS. I had as much or more room with the 2.1 Nevegal.
    Looking at the brite side I will be way faster on it now!
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Did you ever
    try the wolverine? Yeah my 2.1 moto fits really well on the 5spot.
    NedwannaB
    Not in back
    Quote Originally Posted by jrm View Post
    Just front. I figured the 2.2 would be too big. Have to check it out.
    I do like the pattern and volume of the Quasi. Sounds contrary but it should be good for winter trails to me anyway.
    Reputation: RedDirtGorilla's Avatar
    Mar 2012
    650 palace
    Vee Rubber will be offering 11 650b tires, all are expected to be released by Interbike 2012, check out 650B Palace's blog for a look
    jrm
    jrm is offline
    Yeah i never tried it
    Quote Originally Posted by JMac47 View Post
    in back cuz it would be a pita. Like it up front though.
    NedwannaB
    Your Spot
    It's a pre DW right? Guitarzan is asking about our tweener wheels on his newer model, what do you think?
    Dec 2009
    So much for the Quasi being the smallest of the 650's! l:
    It is in width, but I'm pretty sure it's the same height as a Neo 2.1and a Racing Ralph.
    NedwannaB
    Yeah pretty much same
    Quote Originally Posted by gvs_nz View Post
    Guess I was thinking they were going to be smaller. But since originally coming from using 700c cyclecross wheels and tires on 26" frames I'm ok with the low profile tire pattern. Looking back at some of the archived threads the IRC is probly the smallest knobby tread to use in a tight fitting retro fit application.
    With all this being said, I think I'm going to cry Uncle and order a 650B specific frame next week so I can finally run any size tire I want to!
    Dec 2009
    My guestimate was wrong . Just measured my one again and it's 2mm smaller in height than Neo 2.1.Which I'm sure is the same height as Ra Ra. Others are getting different measurements than me on the Quasi though?
    NedwannaB
    Tire size be damned!
    My Bastardo frame came in so I can run whateverrrr size and style I want now!
