Results 1 to 3 of 3
    Mar 2015
    DT Swiss E1900 issue? (YT Capra)
    Hi,
    My DT Swiss E1900 free hub (on my 2017 Capra Al Comp) makes an abnormally loud "ding" sound when it engages under quick loud of power. The sound vibrates through the spokes and the rim making it even louder. It happens when bunnyhopping, coming out of an endo, jumping, doing drops and etc. (Basically every time the rear wheel contacts with the ground). It also happens when I start pedalling quickly, and when I change the gear to smaller cog. (The smaller the cog, the louder the noise in my case). I have a video of my issue with the hub :
    https://www.youtube.com/watch?v=jYRk2m8RRFY
    What can cause this? Should I contact YT? Or should I take the wheel to my LBS?
    Thank you for the help.
    May 2016
    You should contact YT but it just seems to be an issue with spoke tension. Either too tight or loose.
    Aug 2016
    Sounds just like the ones I have on my bike, as far as the volume goes. There is some rattling though, I can't really describe it well, might be two spokes vibrating against each other? Something like that.
    But doesn't sound abnormal.
  1. Dt Swiss e1900 - thoughts?
    By aflax in forum Wheels and Tires
    Last Post: 01-29-2017, 05:46 AM
  2. Replies: 1
    Last Post: 05-08-2016, 12:15 PM
  3. Dt Swiss e1900 bearing
    By miggy in forum Wheels and Tires
    Last Post: 04-26-2016, 05:02 AM
  4. DT Swiss 350 freehub issue
    By Snoopshomes in forum Wheels and Tires
    Last Post: 07-06-2015, 03:09 PM
  5. DT Swiss shock issue?
    By Rhinodriver in forum Scott Sports
    Last Post: 03-17-2014, 01:32 PM
Members who have read this thread: 4
