Results 1 to 5 of 5
Thread: DISS Fork?
    veinte nueve pulgadas
    Reputation: nzumbi's Avatar
    DISS Fork?
    Anyone try a 29er wheel in a DISS fork? I think there's enough axle-crown, just don't know about lateral clearance.
    Jun 2005
    Quote Originally Posted by nzumbi
    Schmucker noted on my "GUSS 96er" thread that "I found that my stock rigid Bianchi fork will clear a Rampage on a Flow rim... but it's TIGHT. It's more limited width wise."
    What is the axle to crown length of your fork? (caveat: I am a noob when it comes to these 9er conversion, but am willing to help...)
    [QUOTE=What is the axle to crown length of your fork? (caveat: I am a noob when it comes to these 9er conversion, but am willing to help...)[/QUOTE]
    I don't actually have the fork yet. I have a guy willing to sell me one for $25+ship. He says it is about 413mm. I'm probably just best off buying a 1x1 fork, since we know it works. Crappy part is that I have one (1x1 fork), but w/out a disc mount.
    Jun 2005
    For $25 I say go for it. It has the same axle to crown length as a 1X1 (although I imagine the 1x1 has more clearance for wider tires....).
    Let us know what you decide and how it works out. I currently have a Karate Monkey fork on my GUSS and am looking to try something shorter A-to-C.
    Yeah, it'll fit as long as it is dimensionally the same as my MUSS fork. It fits like a non-suspension corrected 29er fork, but the tire clearance isn't there. A narrower tire or one with less aggressive side knobs would be perfect. As it was stated, I put my Rampage on my Flow rim and it was very tight. Make sure you true the tabs to make sure the wheel is perfectly centered. I put a 2.35 Schwalbe Big Apple on my Flow and tried that. That was a very nice fit. So anything with a tread width of about 55mm or less will be a nice fit. Use Shiggy's site for reference. http://www.mtbtires.com/specs/700.html
    You may find that if you use a narrower rim some of the wider tires will fit fine. The Flow is 28mm and according to Stan's increases tire volume by 4% and Shiggy does his measurements on a Velocity Dyad (24mm).
