Deemax wheels arent fitting right- Mtbr.com
Results 1 to 2 of 2
    Aug 2020
    Hey guys, just picked up some 2nd hand 27.5 deemax wheels. the previous owner ran them on his 148mm boost frame and my commencal has the same 148mm spacing, however when bolting wheel to frame i realized that with the brake rotor mounted it's not going to fit as it will be hitting the rear caliper mounts. Do i need different axle adapters to make it work? its strange because im running the same boost spacing as previous owner. any help is greatly appreciated, thank you
    Attached Thumbnails Attached Thumbnails Deemax wheels arent fitting right-img_5433.jpg
    Aug 2017
    Rim is centered in frame? Endcaps are on proper sides? Can you try to switch?
  1. Grips arent sticking on handlebars
    By XCRIDERBG in forum Beginner's Corner
    Last Post: 11-29-2018, 12:15 PM
  2. arent you cannondale guys pissed at cannondale?
    By david8613 in forum Cannondale
    Last Post: 08-09-2012, 10:17 PM
  3. Tire change and back brakes arent working (disc)
    By crestfallinman in forum Beginner's Corner
    Last Post: 07-18-2012, 02:44 PM
  4. 05 deemax vs 06 deemax
    By freeriderB in forum Downhill - Freeride
    Last Post: 05-01-2006, 08:13 AM
  5. Deemax Rims & Non-Deemax Hubs, Spokes & Nipples
    By Freerider in forum Downhill - Freeride
    Last Post: 01-09-2006, 04:03 PM
Members who have read this thread: 21
