damage inside carbon frame head tube- Mtbr.com
Results 1 to 9 of 9
    Feb 2012
    How bad do you think it is? The scratch is probably screwdriver made (or similar tool). It is 15mm long, 4mm wide, and 0,5mm deep. It is upper head tube hole. The front part. It starts shallow at the top edge of the head tube, and ends around 0,5mm deep after 15mm going down the head tube.
    I was about to assemble a bike out of it but now I am not sure if that is what this frame be used for. It accepts ZS 44 headset cup.
    new picture
    old picture made with potato
    Attached Thumbnails Attached Thumbnails damage inside carbon frame head tube-intensetracer275gouge.jpg
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    EDIT: with the new pic
    what I say here about jbweld is the ticket.
    mix up some jbweld, smear some over that then wipe it down so the smear is flush (barely any jbweld) and let it harden 24 hours.
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Reputation: dbhammercycle's Avatar
    I concur with the above. If you hadn't mentioned that it's a little deeper into the carbon as you go, I would think it was a smudge in the carbon grip paste.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Feb 2012
    I added a better picture.
    EAT MORE GRIME
    Nov 2013
    ok we now see the gouge
    definitely jbweld it. mix it long and perfect
    let it harden a wee bit more like silly putty or a bit looser
    jam some in there, scrape it with plastic edge so it's smooth
    let cure 24 hours
    do not use any quick set or clear, use old school gray that takes 24 hours to harden fully.
    or
    have a carbon repair expert do a repair. but the location and depth doesn't look super bad. but I retract what I said. it ain't nothing, it's something minor
    Feb 2012
    Quote Originally Posted by 127.0.0.1 View Post
    let cure 24 hours
    or
    JB Weld is a company name. If any, which product should I use for this application?
    Sent from my GT-I9505 using Tapatalk
    Feb 2012
    Any more opinions would be great. I started warranty process and I am sure that will replace the front triangle. The only reason I am asking how bad is this gouge and should it be repaired is the fact I hate wasting resources and polluting the planet. The bottom line is I want to be safe and I want to be able to put in and in case of problems - take out the headset. This damage looks that way that if I took the headset out in the future, the operation might damage the frame further. I like the idea with fixing it with epoxy but I'd like to hear some more opinions.
    Mar 2013
    Looks as though someone used the wrong tool to tap out the headset cup. Used frame? If it was sold to you as a new frame I would return it. Itís probably not a big deal as most of the force at the headtube is at the bottom race/cup but I am no engineer.
    EAT MORE GRIME
    Nov 2013
    Quote Originally Posted by goroncy View Post
    jbweld twin tube cold weld original two part epoxy
    it is one of the strongest you can buy and is safe for carbon
    and easy to work with. mix mix mix, let harden enough so it is like runny playdough
    smear push squeeze into the gouge, scrape flat, let harden 24 hours. that gouge won't be able to propagate further
    it would not be used in a larger repair but it is great for that gouge you have
  1. Replies: 2
    Last Post: 07-11-2018, 05:39 AM
  2. Sand inside of CF frame head tube?
    By skiahh in forum General Discussion
    Last Post: 02-03-2015, 06:37 AM
  3. Carbon frame - marks inside seat tube. What to think?
    By madskatingcow in forum 29er Bikes
    Last Post: 11-01-2013, 08:27 AM
  4. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  5. Replies: 3
    Last Post: 02-03-2012, 01:50 PM
