Results 1 to 7 of 7
    Reputation: taprackbang's Avatar
    Jun 2014
    Can I put 27.5+ wheelset on my 27.5 bike?
    I have a 2015 Lapierre Zesty 27.5, but is it possible if I swap out to a 27.5+ wheelset will it work/fit? The rear chainstay on the LP is really roomy and assuming there is enough space, will this be an easy swap out? I'm running Fox 34 Factory in the front.
    nvphatty
    Guest
    Quote Originally Posted by taprackbang View Post
    possible? yes. but first measurements of both CS & SS spacing will tell the tale. Same for the fox fork @ the seal bulge. Depending on what plus wheelset & tires you envision it may well dictate whats possible. As an example i35 rims with 2.8's mounted are in the area of 68mm knob-knob, hence good clearance for debris/mud and avoid tire rub would be 75-77mm between stays.
    this link has some good info listed.
    https://docs.google.com/spreadsheets...D5w/edit#gid=0
    make mine a nine
    Reputation: abevern's Avatar
    I'd be interested to hear how you go if go down this path. Please update this thread if you do.
    Reputation: noose's Avatar
    I plan to do this at some point with my 2015 Trance when I get wider wheels around 30 to 35mm id. I will likely run no bigger than 2.6" tires (with a front tire no bigger than 2.8") since I am hearing reports that many are finding them the sweet spot for trail riding.
    2015 Giant Trance 3
    X-Fusion Sweep RL2 160mm fork
    Straitline Defacto pedals
    Renthal Fatbar with TV 40mm stem
    Ergon Grips
    nvphatty
    Guest
    The OP has never posted again with any sort of findings........noose if you do use 2.6 then i30 rims are your target point.
    Apr 2014
    Quote Originally Posted by nvphatty View Post
    Would 35 id be fine as well?
    nvphatty
    Guest
    Quote Originally Posted by MrBB View Post
    certainly would be but numerous factors play into this wide rim era we find ourselves. What tire, what brand and size can dictate the choice you make.
  1. 29+ Wheelset for Fat Bike w/ Tires
    By spartan_msu in forum Classifieds
    Last Post: 06-16-2016, 12:00 PM
  2. Old bike, new wheelset. Help?
    By MATPHAT in forum Wheels and Tires
    Last Post: 04-10-2015, 08:04 AM
  3. Replies: 1
    Last Post: 12-22-2014, 11:39 AM
  4. Replies: 6
    Last Post: 08-20-2014, 07:36 PM
  5. Road bike wheelset for 275# guy?
    By texasnavy05 in forum Clydesdales/Tall Riders
    Last Post: 09-09-2012, 07:29 PM
