bottom bracket Feimin FP-902W on a Giant Rincom- Mtbr.com
    Mar 2020
    Hello all
    I'm an old bloke mid 50's who rides about the south of Cambodia for excercise.
    I have covered over 4000 miles/6500km in southern Cambodia since I bought this here in the capital last November and if the BB needs changed I would have to take the bike all the way up there on a bus, at least a 4 hour ride , to get if replaced ...unless I can get the tool and another bracket when it gives up.
    I have a Giant Rincon (GI) 2019 which is the entry level model...its fine for me as I ride usually on sealed and unsealed roads, no jumps or trails etc... I have been trying to find out how to be sure of the tool to remove the bottom bracket ?
    and which one I can order as a replacement.
    thanks for any pointers !
    Reputation: grubetown's Avatar
    Sep 2013
    From the pictures on Giant's website, it looks like a square taper bottom bracket. You will actually need two tools - a crank puller and bottom bracket socket. Once you pull the cranks, then you will have to measure the spindle length and bottom bracket shell. You might be able to call a giant dealer to get the specs. Any square taper bottom bracket with the same measurements/threads will work as a replacement.
    Mar 2020
    Thanks... I have a crank puller was hoping some one would just say order this tool xxxxxxx and this bracket yyyyyyy..
    Mar 2020
    Quote Originally Posted by grubetown View Post
    Thanks... I have a crank puller was hoping some one would just say order this tool xxxxxxx and this bracket yyyyyyy........it is a square taper bkt
  1. Threaded bottom bracket (2019 Stumpjumper): Want carbon crank with bottom bracket
    By rakerdeal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-27-2020, 08:03 AM
  2. Using Bottom Bracket Wrench vs. Bottom Bracket Socket
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2016, 10:36 PM
  3. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  4. Replies: 3
    Last Post: 03-24-2013, 08:44 AM
  5. Exploring Hogan with FP and Ogre
    By fred-da-trog in forum California - Norcal
    Last Post: 12-29-2012, 05:28 PM
Members who have read this thread: 8
