Bad Boy 1 (2018) and WTB Horizon 650 47c- Mtbr.com
Results 1 to 10 of 10
    Apr 2020
    Bonking ... not feelin' well Bad Boy 1 (2018) and WTB Horizon 650 47c
    Hello community,
    Just changed my Schwalbe G-One Performance - 650x40c by WTB Horizon 650 47c TCS. to be honnest I was sure this was 40c but I made a mistake. Here is the 47c rear mounted:
    There is 2mm and after... its the frame .
    Do you think it's bad choice? Should I change it?
    Thanks by advance for your advices.
    Barichon
    Attached Thumbnails Attached Thumbnails Bad Boy 1 (2018) and WTB Horizon 650 47c-img_20200501_132936.jpg
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    Are you planning on putting on fenders? Are you a big boy on flexy wheels? Judging from the frame and tires, this bike is purely used on the street? Properly tension the spokes and you should be fine. Use the tires til they're worn then get the 40-42c tires.
    Amolan
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Iím a firm believer in running the biggest tire my frame/fork can clear. Whatís the occasional tire rub? SEND IT!
    Apr 2020
    Hello,
    Thanks for the reply.
    I am planning this fender: https://www.sks-germany.com/en/products/edge-al-56/
    My use will only be for street and clean graveled road. My weight is 79kg.
    Apr 2020
    There is no tyre rub (fortunately) , the worst case tyre is at 1mm of the frame.
    dirtbag
    Sep 2003
    Depending on how forward the new fender wrap around the tire, you may have to trim is down so its stops before the tire/chainstay junction. Is the tire/seatstay clearance good?
    Amolan
    Rider
    Reputation: TylerVernon's Avatar
    Nov 2019
    It works great until you want to sell the frame and the buyer asks you why it looks like someone tried to sand through the seat stays.
    Apr 2020
    Yes, there is space. About 5mm each side:
    Rider
    Nov 2019
    Meant chain stays.
    Apr 2020
    ok, I called my vendor. He is ok to change the tires !
    My previous tires were Schwalbe G-One Performance - 650x38B (27.5 x 1.5).
    Is it ok if take this one: https://www.probikeshop.fr/pneu-schw...78/134956.html which are typically
    650x40(27,5x1,60) ?
    I guess it should be ok but I prefer asking now to avoid mistakes: it should be 2 mm more than the Schwalbe G-One (my old one and 5mm less than the wtb...).
    Thanks for your support.
  1. WTB Horizon 47c cracking. Bad or not?
    By mogulman1 in forum Wheels and Tires
    Last Post: 3 Weeks Ago, 08:11 AM
  2. Oh Boy, Oh Boy, Oh Boy!
    By stan4bikes in forum Vintage, Retro, Classic
    Last Post: 01-15-2008, 10:24 PM
  3. Boy meets bike, boy falls in love, boy goes into debt...
    By Darkwing Duck in forum Singlespeed
    Last Post: 10-31-2005, 03:44 PM
Members who have read this thread: 9
