Results 1 to 1 of 1
    "b" clearance? Spec. Epic Carbon pics
    How likely is it that 650b will fit this 2008 Specialized Epic Carbon Expert?
    There was just enough tension to hold a nickel (21.0mm diameter measured w/ analog dial caliper) between chain stay & lightly used 2.0 OEM tire:
    Below five pictures display seat stay clearance:
    20mm/.787" (19mm + 1mm from end of ruler to 1mm mark):
    Just less than 7/8" on tape measure; .875" (7/8) - .088 = .787" as above:
    Three pics below show less than 21.0mm clearance (nickel diameter); consistent w/ above measurements:
