Results 1 to 13 of 13
    Sem
    Nov 2018
    Any tubeless 27.5" front wheels that are 9mm quick release
    Building a 27.5" bike, and made the mistake of getting a fork with 9mm qr rather than 15mm thru and I am sort of regretting it. I have a normal dt Swiss x1900 spline rear wheel which is great and set up tubeless. Does anybody know of any good front wheels that are tubeless and 9mm * 100mm, or better yet a 15mm * 100mm that comes with the correct end caps? Thanks!
    May 2018
    Quote Originally Posted by Sam Humphreys View Post
    Perhaps mavic stuff. Its cheap to get endcaps for their 15x100 as i recall.
    Lots of dirt cheap mavic 27.5 15x100 front wheel out there. At least in EU.
    Sem
    Nov 2018
    That's great ill look into it, yeah I live in Britain so hopefully prices should be cheap
    May 2018
    Then I would check first chainreaction and then wiggle. Usually the latter is cheapest.
    You can probably get a mavic quest qr from 2015 for like 40 pound or so but its 19mm iw and not tubeless ready but will work tubeless if you fight for it. Dirt cheap but imo a stretch.
    Xa elite is like 110 pounds is 25iw but it's really really good wheel. Here you have to add cost for endcaps.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    I'm sure there are x1900 15x100 front wheels on the used market you can swap end caps or use and adapter. Any 15x100 ta can be made to be old school qr.
    Sem
    Nov 2018
    Ok cool that's helpful, thanks
    Sem
    Nov 2018
    Yeah I'll do that, thosw wheels sound perfect, thanks
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    have you looked into 15mm to 9mm adapters?
    https://www.google.com/search?q=15mm...hrome&ie=UTF-8
    Sem
    Nov 2018
    Quote Originally Posted by jrm View Post
    Yeah I think I'm gonna have a 15mm one and swap out the end caps.
    Upcyclist
    He can get a 15mm to 9mm thru axle adapter and use a 9mm RWS, which is way better than a 9mm QR.
    https://www.chainreactioncycles.com/...y/rp-prod81162
    I have a couple of those^^, and one of these (Linked below) because I had 15mm end caps for one set of Hope hubs.
    https://www.velofuze.com//thru-axle/...elease-skewer/
    Cool heads prevail
    Sem
    Nov 2018
    Could do, Ive looked into it and a lot of wheels come with 9mm end caps aswell, meaning I can still use the wheel when I upgrade my fork to a 15mm in the future
    You can swap caps on dt hubs easily. My advice though would be to swap the fork for a through axle. QR is super flexible and not great for a suspension fork and disc brake imo.
    Sent from my Pixel 2 using Tapatalk
    Make America Bike Again
    Reputation: richj8990's Avatar
    Apr 2017
    I looked up your wheels, the back is either 22.5mm or 25mm internal width, 29". So to more or less match the rear...
    RaceFace AEffect SL 29" Mountain Front Wheel
    $90, 24mm internal width, 15x100mm
    If you want to stay with 9x100 quick release:
    SHIMANO WH-MT15 29" Quick Release Aluminum Clincher Wheel
    $110, 25mm internal width, 9x100mm
    Gallia est omnis divisa in partes tres: quod Belgiae, quod Celtae, et quod Aquitainae.
  1. Replies: 4
    Last Post: 05-30-2015, 10:03 PM
  2. Manitou Mavel Comp 9mm quick through bolt quick release
    By MBTStuff in forum 29er Components
    Last Post: 06-14-2014, 07:15 PM
  3. Replies: 3
    Last Post: 04-28-2014, 01:20 PM
  4. 9mm quick release to 9mm thru axle
    By TalMiz in forum Wheels and Tires
    Last Post: 01-09-2014, 10:54 AM
  5. Making a quick release, a REAL quick release! Help!
    By metomeya in forum Wheels and Tires
    Last Post: 10-11-2005, 09:40 AM
Members who have read this thread: 45
© Copyright 2018 VerticalScope Inc. All rights reserved.
