Thread: 650b rims
    Village Idiot
    Oct 2007
    650b rims
    is there a good list as to whats available out there ?
    Whats the minimum spoke count you could use and still have a good stable rim ?
    Just have a daft idea running around in my head
    Village Idiot
    Oct 2007
    Best place to buy 650B Blunt rims?
    Mr.650b - Mr.27-5
    Reputation: Kirk Pacenti's Avatar
    Quote Originally Posted by equinox
    I think SpeedGoat has some... or have your LBS contact Velocity directly.
    QBP and others will be stocking them for 2008.
    Jan 2005
    650b rim choices
    Kirk,
    What are your thoughts on the weight/stiffness, tire compatibility for the following rims:
    Velocity Blunt -480 gms
    Velocity Synergy -Weight 430gm?
    Sun Cr-18 -weight? availibility?
    Finally, I am working on a wheel build using the Americam Classic 130 hub, DT 14/17 revolution spokes and Blunt Rim. Wheel weight appears to be about 800 gms, which does not seem that light. Any thoughts on a possible lighter stiffer build for a 170 lb rider?
