27.5in Rigid Fork options- Mtbr.com
Results 1 to 3 of 3
    Mar 2018
    I am planning on building a Kona Explosif up and I would like a rigid fork option. Are there any 27.5 tapered rigid forks that are boost with 15mm thru axles? I want to be able to swap between a 120mm Pike and a rigid fork. I don't want to go custom as I am trying to keep the cost of this build down initial by doing a rigid single speed then later adding a suspension fork and a multigear setup.
    Reputation: boomn's Avatar
    It looks like Pike 120mm a2c is 512mm, and with 20% sag it would be 488mm.
    If you want to keep the length of the rigid fork close to the sagged height of a 120mm 27.5" fork, the best options are probably 29er or 29+ forks.
    For example: Surly Krampus 110 steel fork is 483mm a2c
    Mar 2018
    Quote Originally Posted by boomn View Post
    Thanks. That looks like it should work.
    It looks like the KM or a Niner steel fork should work too.
    Ragley Big Wig, Sunday Soundwave (BMX), 91 Schwinn High Plain (single speed "gravel" bike), Nashbar CXSS (on trainer)
  1. my 5.5in fork bottom out at just 3in, pls help.
    By inter in forum Shocks and Suspension
    Last Post: 03-29-2012, 12:57 PM
  2. ellsworth evolution 5in.travel or sultan
    By trlrdr in forum Turner
    Last Post: 08-16-2011, 02:46 PM
  3. Replies: 1
    Last Post: 01-17-2011, 11:02 AM
  4. Coiler and 5in fork??
    By mtnbiker662 in forum Downhill - Freeride
    Last Post: 06-10-2007, 11:24 PM
  5. Replies: 3
    Last Post: 12-17-2004, 09:10 PM
