Results 1 to 5 of 5
    26er to 650B conversion. V-brake question
    Is it possible to convert a 26 HT frame without disc brake tabs to 650B?
    If so what is needed for the V-brakes to work?
    TIA.
    edit, never mind
    Indy, In.
    Niner Rip 9
    Niner Air 9 Carbon
    Karate Monkey SS
    Misfit DiSSent
    If the bike has canti studs, you can use Paul Moto BMX brakes, they allow for enough adjustment that you could run 700c on a 26" frame, if you have the clearance for the tires...
    Avid Single Digit 5 brakes work for me on velocity/weinmann rims. The slots don't allow for quite enough adjustment to get the brake pads right in the center of the sidewall, but it's close enough and I get plenty of braking power. I am thinking about trying these --
    New MTB Road Bike V Brake Front set Green | eBay
    Anyone else run these brakes ?
    Feb 2006
    Quote Originally Posted by phoenixbikes View Post
    The arms look to short to clear a usable MTB tire
