2014 Breezer Repack
Printable View
  • 05-15-2016
    Aresab
    I did at first when the chain was new, but now not so much. Once in a while it will come off, but it's good by me, I don't even notice any more. I'm staying 10 speed for quite a while...
  • 05-17-2016
    RangerMadeKnives
    Good to know. I read all the way through the Sunrace wide range cassette thread and I've pretty much decided I'm going to go with the Sunrace CS3 11-42, XT M8000 RD, Race Face NW 32T and SRAM X1 chain. I'll probably keep my OEM Deore 10-speed shifter for now.
    Bob
  • 05-19-2016
    lzcztq
    Originally Posted by SMUAlien View Post
    I rode a 2016 Repack today and liked it a ton. Was a Pro flavor and had a Pike on the front. Bike was just buttery smooth. I am now thinking I want one and I keep adding it to my cart on Pricepoint, but not pulling the trigger. I am torn between Pro and Expert model. Is the Fox stuff really that bad? I don't like the 3x10 drive train on the expert. I kinda wish I could get a Pro, but have the XFusion shock on it... unless you guys think that 34 float is OK. The Pike was just.... amazing, so I'm pretty sure anything will feel lesser compared to that. I am not sure I want to spring for the the bike with the Pike though, I could have gotten it for 2500 out the door, which is still quite a bit more than what PricePoint has. So long story short, 2015 Pro (with fox and dropper?) or Expert?
    Thanks to this thread I have pulled the trigger the trigger on an Expert through Pricepont. I honestly wanted to go with the Pro and get the Fox damper upgraded since Fox is offering the upgrade for around $100. After comparing prices at other sites seeing Pricepoint is sold out of Pro's I figured I could upgrade the Expert to at least the Pro level of build and still make out pretty good. I'll do the Roughcut damper($250) and update some components. I also got a WTB i23 wheel set from them too on sale for ~$80 so I can go tubeless when it gets to me. Can't wait til it arrives and compare back to back with the 08 Enduro SL it will be replacing.
  • 05-19-2016
    mjs1231
    wheel upgrades
    if your going to upgrade do this
    wtb asym i35 rims @ 27.5 and a 160 mm pike up front
    the bike will take both sizes and this way you can run up to 2.5 in tires without roll over and low pressure with tubes and sealant.
    rims are 70.00 and a bike shop will lace up new ones for you for 70 or so bucks
    ride it like u stole it
  • 05-26-2016
    lzcztq
    Got my expert this week and it's just about together :). Couple of questions for existing owners:
    1. There weren't any cup/cone spacers for the front brake mount as shown in the Shimano exploded diagram. Is that the norm for everyone else?
    2. There are some adhesive pads that look to serve as a form of chain stay protection however the form doesn't seem to fit right. Can anyone let me know where they are to be installed.
    thanks in advance for any support!!!
  • 05-26-2016
    jhatfie
    I am no bike assembly pro, but I got my expert together the other day. I was confused by the 180mm adapter instructions as well, but checked with PP and their mechanic said to just use the 2 provided screws, no washers required. Seems fine.
    I was not 100% sure at first, but the adhesive pads will fit on the chain stay. The two pieces are cut in such a way so they nearly meet at the pivot point.
    Mine also came with what appears to be an extra centerlock disc lockring (like the one used on the rear wheel). The cassette and front and rear discs all have their specific lockrings already installed. I also have what appears to be a cassette spacer in the same bag....not sure about that either.
  • 05-26-2016
    lzcztq
    Thats exactly what I needed to know. Assured now that nothing was missing. Much thanks for the feedback!!!
  • 05-27-2016
    Danibee
    Originally Posted by scooderdude View Post
    If you're in the SF bay area, Endless Cycles in Castro Valley has one in stock.
    It's good to hear Endless has a full suspension in stock. When I was purchasing my last bike they had said they leaned more toward HT and didn't generally keep fs stocked because they'd sit. I'd have certainly been interested in the breezer. Good people in that shop. I'd spend money there.
  • 05-30-2016
    linvillegorge
    Originally Posted by linvillegorge View Post
    Anyone else having a helluva time doing tubeless setup on the stock wheels and tires (Expert build)? I've taped the rims, used sealant, tons of soapy water, using a compressor and I'm not even coming close to getting the beads to seat. Tired of getting pinch flats on the rear with tubes but a tubeless ready wheel set and tires aren't in the budget this season so I really need to get these to work. Any suggestions?
    I give up. I've tried everything I can think of. Do u Ling up tape, lining the rim with half a tube, hell I even tried the old Jeeper trick of igniting ether inside the tire. Nothing comes close to getting these things to seat.
    With no money in the budget for a tubeless ready setup this season I guess I'm just going to have to run stupid high pressure in the rear this summer. I've blown through three more rear tubes. Hell, at some point, buying a tubeless ready setup is gonna be cheaper than buying new tubes on a weekly basis.
  • 05-30-2016
    damnitzhym
    I never got the Vigilantes to seat on those sx23 rims. I mounted Nevegal Pro X instead. I had to use pressurized nitrogen @ 150psi with the valve core removed to get those to seat on the SX23 rims. I mounted the Vigilantes tubeless on my hardtail's Blunt 35 rims pretty easily with less pressure. Go figure
  • 05-30-2016
    linvillegorge
    Yeah, basically it's a crap shoot when trying to setup non-tubeless ready stuff up tubeless. Sometimes it works, sometimes it doesn't. Seems like the SX23/Vigilante combo is a loser. I may try to grab some tubeless ready tires and see if I can get them to seat on the SX23s. If they don't, oh well. I'll just hang onto them until I grab a new tubeless ready wheelset. After a double layer of tape plus a tube liner, these damn things ought to hold air. Holding air wasn't the issue though. At no point did I even get those Vigilantes even close to seating.
  • 05-30-2016
    CogHog
    Just in case someone might be interested I have a 2014 breezer repack expert frame for sale with headset and bottom bracket. Will also include the front derailleur, stem, seatpost clamp, and ritchey handlebars for $550 total. Oh and it has an xfusion O2 RL shock mounted as well.
    Frame is in great shape, let me know if interested.
  • 06-04-2016
    mjs1231
    yo
    what frame size? if xl i will buy it from you
  • 06-04-2016
    CogHog
    Sorry I should have put that in the post.
    Unfortunately it's a medium 18.5" frame.
  • 06-08-2016
    Slowupfundown
    I've had the repack for a bit now and I've gotten a few rides under my belt. Really enjoying the bike.
    Mods I've done so far
    -Ghetto Tubeless conversion- I have a "trick" to get these to seat that I've also had to use on other bikes.
    - 40mm stem
    - x-fusion dropper post- I've had reverbs in the past, I'm really liking the x-fusion. The "360 degree" lever is great and easy to use.
    - 1x race face 30t chainring- a must for me. No dropped chains, simplicity.
    So here's my "trick" for getting the tubeless to seat on non-tubeless ready wheels that are stubborn. Use a bead of elmers glue on the outside where the tire meets the rim. let it sit for about 10 minutes or so to get a little tacky, and I use my finger to get a "seal". This allows the air to seal and be trapped in the tire and it will instantly inflate any stubborn ghetto setup. Once its seated just wipe up the glue with a rag. Thats it!.
  • 06-08-2016
    Slowupfundown
    Here's a pic at WhiteRanch trail, a pretty technical trail with a bunch of steep drops. The bike was buttery smooth and I felt great.
  • 06-08-2016
    Skeeter97
    Glad you're enjoying it! I'm still extremely pleased with mine. Only thing left to do is go 1x. Just need a bit more leg strength before I do
  • 06-14-2016
    loop2kil
    This was from my first ride at Hard Labor Creek State Park's Red Loop.
    I've probably got about 80-90 miles on mine so far now and couldn't be happier. I'm running it completely stock at this point, haven't even messed with going tubeless yet. I did find a better way to mount a water bottle by using the mounts underneath the bottom tube. I thought it was going to cause problems but so far it works really well.
    Attachment 1076340
  • 06-14-2016
    ttimpe
    I am interested in your frame! Please message me.
  • 06-25-2016
    csuder99
    Breezer Repack Pro 1 yr review
    Summary: Very good riding bike with a few flaws.
    The bike is a 2014 Repack Pro model that I got off PP in June last year when there was an 15% off 'grads & dads' promo. I'm neither but still got the bike for under $1900 shipped. The list price however is $3600 which is way more than what it's worth. For comparison a (female) friend just bought a Carbon Juliana Furtado C for that money.
    Good:
    Climbs very well for a 160mm travel bike. Feels a little more compliant than my previous DW Turner. It also wanders less when it's steep, which maybe the result of the overall longer wheelbase. Although some reviewers don't like the head angle it works very well for me on the way down. It's not a Giant Reign or SC V10 though.
    Decent components, SLX shifters/cranks/hubs where many companies go cheap, low level Shimano brakes which have less bling and adjustments but work as well as the more expensive ones.
    Frame hasn't made a peep in one year of riding. I'm solidly in the clydesdale category and I have broken frames before but no issues here.
    Bad:
    It's heavy. I personally think this is the main issue that keeps it from being a success. 3-4 lbs less with a carbon front triangle and swing link the bike would be a hit. It does carry its weight well and with the rider standing to loose a few pounds it does not bother me much, but lighter riders may perceive it as holding them back.
    Horrible paint job. After a year it has more chips and scratches than my 2010 Turner.
    Wheel build. I already broke 4 spokes in the rear, the wheel might have been true from the factory but spoke tension was all over the place. Trying to get the centerlock rotor off I had to resort to an impact wrench, a first for me and I've removed plenty of cassettes and rotors.
    Had two Pivots come loose but caught it time.
    Ho-humm:
    OEM WTB Vigilante tires. Not really bad but the replacement Maxxis Ardents do better.
    Single side lock-on grips are ok but the lock ring is different from the popular brands so forget about replacements. Need to buy complete new grips.
    Repairs: The rear shock blew on ride #3 but that's on Fox and not Breezer's fault. Fox turned it around quickly and no issues since. Went through three sets of brake pads and just replaced the tires and large front chainring.
    I bought the bike thinking if I don't like it I just use it as a build kit and sell the frame but it turned out it's really a nice riding bike. Certainly worth the closeout prices.
  • 06-27-2016
    james.stoup
    I thought I was the only one on the Front Range with a Repack!
  • 06-27-2016
    james.stoup
    Good:
    Bad:
    Ho-humm:
    One other thing to mention (I love the bike btw). There are a few other things I'm not crazy about with the bike.
    1. The rear triangle flexes like nobody's business. Take the wheel off and remove the rear shock. Squeeze right where the rear axle goes and you'll see what I'm talking about. More $$ spent on bushings cause of this.
    2. I wish there was more room for a piggy-back shock. Not much space. Would also be nice if I could get a water bottle in the frame somewhere.
    3. The CTD mine came with was awful. Horrible chatter or way too much bottoming out. A bike tune made it all better, but definitely didn't like the stock CTD on it.
  • 06-28-2016
    Aresab
    1: I don't notice it flex, in fact feels quite stiff compared to my Jamis XCT Carbon bike. The design of most bikes includes the shock and hardware as well as the axle to make it stiff so I'm not sure a test like this demonstrate the stiffness. They use bearings and collets in the pivot points something I have not seen often on bikes.
    2: I have not tried a piggyback, but mine (large) appears to have enough room. They did have "some" thought for a water bottle I believe. Mine came with a bolt and aluminum spacer for the bottom of the front downtube. The other bolt I believe is the lower cable mount. I have not tried it, but it looks to be the setup for a water bottle cage.
    3: Yeah CTD = SUX! Mine is the expert model, I really like the XFusion stuff. I've upgraded the front fork to the HLR Roughcut Damper and it's just great.
    I'm really happy with my repack. It's now 1x10 with a Saint shifter, Sunrace 11-42 and tubleless running 2.3 TR DHF Minions on the stock cheapie wheelset using a Stans Enduro kit. I put Deore brakes and a 60mm stem and finally and X-Fusion dropper. I absolutely love riding the bike.
  • 06-28-2016
    loop2kil
    2. I was able to get a bottle mount underneath the bottom tube . It's not perfect but it works fine for me.
  • 07-24-2016
    billyM
    I've been enjoying my PricePoint closeout Repack for about 4 months now and really can't say enough for the bike and components. The thing is an absolute tank going down, an honorary XC bike on the climbs, and the X-Fusion shock and fork have been a pleasure in all scenarios.
    Much like Aresab, the moment I pulled it out of the box the chainrings and cassette came off and a OneUp RADr cage, Sunrace 11-40, and 32t narrow-wide went on.
    Attachment 1083858
    ...since then it's been nothing but trouble-free miles (probably 300 or so at this point) from local XC trails to a day at the downhill course along side the 200mm travel bikes.
    Enjoy it out there,
    BillyM
  • 07-26-2016
    james.stoup
    Can you post a picture? I've been trying to get a mount on, but to no avail. I don't want to remove the cable guides and the screw for the cable guides is just a touch too short.
  • 07-27-2016
    Skeeter97
    Loving mine still. Just got done riding Snow Summit playing with all the downhill bikes and the repack held its own just fine. This was initially planned to be a "just for now" bike but I'm so pleased with how it rides I'm debating not building a second bike and just decking this one out. Wheels, XT brakes, 1x11, and so on. Hmmm
  • 08-24-2016
    loop2kil
    Sorry I just saw your post...
    Here's a slightly newer picture while riding the Red loop at Hard Labor Creek. Not the best photo but basically I had to unscrew one of the cable guides and add one of those small mounts for the water bottle cage to screw into. I was able to get both the guide and cage attached so it works just fine. if you're still interested I can try to get a better photo of the cage area.
    Attachment 1089950
  • 08-26-2016
    Nubuck83
    Attachment 1089950
    I've been having the same struggle with mine. Will you please post a closer picture to see what you did?
  • 12-10-2016
    Aresab
    I have not posted to this thread in a while but I am still loving this bike. I did upgrade the fork's damper to the HLR Roughcut and that was huge going over roots and such at high-speed where the fork seemed to pack up (a known issue of the stock RL2 damper). Other than that, approx. every 3 months or so I pull the aircan on the shock to lube the seals which resets the negative air chamber and all is back to awesome.
    I also wanted to add in case the bottle cage mount questions were not solved. Mine came with one space for cage mount to the frame and the second mount used the hole for the lower cable guide/holder. This puts the bottle cage over the cables and cable mount. If your bike did not come with the spacer and screw, I found these on Jenson USA and they should be able to help with the spacing the cage out.
    Problem Solvers Spaceout Cage Spacers > Accessories > Hydration > Water Bottle Cages | Jenson USA
  • 12-10-2016
    mjs1231
    I have the 2015 supercell pro.
    I had the fork serviced for with fox gold 20wt fluid and new wipers ( the tsb ) and now my trail and lockout only work randomly or after the fork is in use for a few minutes.
    it got the seal kit and the gold fluid, thats it. but the lockout and trail modes fail when I first get on the bike.
    sounds like something wasnt bled right, I have burped them and that made them more plush and I can say the damper side ( right side when mounting the bike ) burps alot more than the left side.
    took it back to the bike shop that did it and they said return to fox. how nice.
    any ideas ?????
  • 04-30-2018
    lzcztq
    Anyone running ďPlusĒ tires on their Repack?
  • 05-01-2018
    NoMountainsBiker
    I don't think that you are going to fit plus sized tires on a repack. I'm running the Maxxis Minion 2.4 DHR II WTs on mine and there is not a lot of room left. You could probably do the Minion 2.5 DHF WT if you want a little wider in the rear. I rave been running the 2.4 DHRII WT in the rear and the 2.5 DHF WT in the front and have been really happy with them.
  • 05-01-2018
    lzcztq
    Thanks for the info. I did some rough measurements myself and agree that rear would be tight. I just came across a set of wheels that has 2.8Ďs included and wanted to verify if I could even use them.
  • 10-25-2018
    NuckaMan
    Just wanted to share my thoughts on off-set bushings. I found out about them through reading through this thread. I recently acquired a Transition Sentinel and geometry and 29 wheels really transformed my MTB experience for the better. So with my 2014 Repack in hibernation mode, I decided to overall the suspension and bought a set of off-set bushings from www.offsetbushings.com.
    Wow, I'm amazed what 1 degree HA adjustment and moving the BB a few mm lower does to the bike. It really improved the stability and handling....especially when pointed down. While I'm still over the moon with the Sentinel, I don't think I could ever part with the Repack. Like many others, I bought it off Pricepoint at a killer price....and it has served as a extremely reliable and capable ride over the past several years for me. With my new found confidence in the Repack, gonna give it a go on some local Enduro races with it.
    Hope you guys are all still enjoying the Repack. It's a good bike.
  • 10-26-2018
    NoMountainsBiker
    Wow, I'm amazed what 1 degree HA adjustment and moving the BB a few mm lower does to the bike. It really improved the stability and handling....especially when pointed down. While I'm still over the moon with the Sentinel, I don't think I could ever part with the Repack. Like many others, I bought it off Pricepoint at a killer....and it has served as a extremely reliable and capable ride over the past several years for me. With my new found confidence in the Repack, gonna give it a go on some local Enduro races with it.
    Thanks for the info on the offset bushings. I plan to do the same when I replace the not so great Fox Factory Float shock. I'm still riding the hell out of my Repack and it hasn't skipped a beat.
  • 10-29-2018
    Aresab
    I 'm thinking of trying the offset bushings as well, although I like the bike in current form. Can you confirm the sizes that you ordered. I think my measurements from a few years ago were: 8X22.2 and 8X38 but I 'd appreciate the confirmation.
    Thank you!
  • 10-29-2018
    NuckaMan
    I didn't have to specify any dimensions when I placed my order, just the Make and Model of bike and shock. I believe they have made them for the Repack in the past so they are familiar to what to make. Be sure to order a Pair as you need to install the off set bushings on both ends of the shock.
  • 10-29-2018
    lzcztq
    Great feedback!! Can you comment on the the impact to steering? I always assumed that the downhill stability would have a negative impact on steering quickness..
  • 10-29-2018
    NuckaMan
    There is a ever so slight steering quickness reduction, but that was one of the issues I was trying to resolve by going with wider bars, little longer stem, etc. The stock geometry, especially the HA, really made the bike twitchy for me and when things got really technical and fast, it was not a confident bike to push on. This was even more so apparent when I took a bike like the Sentinel, which has essentially a DH geometry, and was able to basically barge through same sections with ease and confidence.
    With a 1 degree slackened HA, I feel ALOT more confident now and feels more stable to me. I'm ok with a slight reduction in steering quickness.
  • 11-05-2018
    Aresab
    I was curious, did you let the air out of your shock to see of the seat stay brace contacts the seat tube with the offset bushings installed? It seems pretty close on my large Repack in stock form. Iíve placed my order but got to thinking and would hate to damage the frame.
  • 11-07-2018
    NuckaMan
    Yes, I check the suspension at full-stroke to verify clearance and no issues. this was on a Medium frame.
  • 11-07-2018
    Aresab
    Cool, just received my shipment today. Will be a few weeks before I can try so I was curious. I really enjoy my Repack, not sure I really needed the bushings but what the heck. Mine is a large expert, it has a Monarch RC3 + and Mattoc 160, what version / suspension are you running?
  • 11-07-2018
    lzcztq
    Thanks again for the feedback! Installed them last week and didnít notice a major difference in steering response [emoji106][emoji2535]
  • 03-26-2019
    Chargerhemi06
    Anybody still rocking their repack?
  • 03-26-2019
    lzcztq
    On a regular....
  • 03-26-2019
    Chargerhemi06
    On a regular....
    Too bad they discontinued the repack and supercell, I was curious if they were going to redo the geometry and design.
  • 03-26-2019
    lzcztq
    Itís sad but I know that the Fuji Auric was very similar to the Repack (travel, suspension concept, and same parent company) therefore I assume it was a business decision to focus on the Fuji line.
  • 03-26-2019
    rdub315
    Sold mine about a year ago to a riding buddy. It was always just a tad too large for me, and I came across a deal on another bike that I couldnít pass up.
  • 03-26-2019
    Aresab
    Iím still riding my Expert size lg, absolutely love it. I have a BHS Lynx6 and and KHS 7200 for spring, summer, fall (fat in late fall, winter, early wet spring). And the Repack is my go to most of the time. Iíve added offset bushings, Monarch RC3 Plus, Mattoc Pro fork and relaced the wheels to WTB Frequency I29 and mounted Minion DHF 2.5/DHR 2.4. 35mm bars, 50mm stem and X-Fusion dropper. The bike rips! I have zero interest in replacing it.
  • 03-26-2019
    Chargerhemi06
    Nice, I still have mine. Some people give me funny looks when they see it. I guess they never heard of the name.
  • 03-27-2019
    damnitzhym
    I still have my 2015 Expert and I love it. I've pretty much upgraded it with all Team level components.
  • 03-29-2019
    NuckaMan
    I have moved on to a 29'er trail bike but still have my '14 Team in the quiver. My wife uses it when I take her out on some of beginner trails. Still a great climbing bike and the frame will last forever.
  • 04-01-2019
    amylawrence
    Thanks for the input.
  • 04-01-2019
    jhatfie
    I still have my Repack, I have moved on to a 2018 Trek Fuel EX 9.8, but I set the Repack aside for my son to try to get him riding with me more. It is still a great bike.
  • 07-02-2019
    Sickmak90
    Is going from a 70mm to 50mm stem a safe bet on these bikes? Iím on the lower end of the size spectrum for the medium and Iíd like to shorten the reach a touch.
  • 07-03-2019
    Sickmak90
    So far I have added a cheap dropper, a 30T front ring, a 11-42T rear and a 11s derailleur. I like the bike a lot but it is a touch long. I got a screaming deal on it so I canít complain to much.
  • 07-03-2019
    lzcztq
    One of my first changes :)... Definitely not a problem but stem length is really rider dependent along with seat position(up/down, fore/aft). If possible play with different styles sizes and hopefully you can find your sweet spot!!!
  • 07-03-2019
    Sickmak90
    How much worse will it climb with a 50mm vs a 70mm?
  • 07-03-2019
    tfinator
    If going to a shorter stem improves the fit then it'll climb better, not worse.
    Sent from my Moto G (5) Plus using Tapatalk
  • 07-19-2019
    Sickmak90
    50mm stem, it feels good so far.
  • 07-25-2019
    lzcztq
    Sounds like a good fit! Enjoy
  • 04-14-2020
    Kayoige
    Back from the dead. Just bought a 2015 Expert, Does anyone know the busing and spacer specs?
  • 04-15-2020
    Aresab
    If you are asking about the shock spacers they are 22.2X8 FR and 38.0X8 RR. MY notes were rear 38.5 but when received my caliper showed 38.0. I used Rockshox spacers at first then ordered Offset bushings. If you have the X-Fusion shock the current spacers will work on Monarch, Fox, and Manitou (later versions only) shocks but are the older top-hat design (unless swapped out).
  • 04-15-2020
    Kayoige
    Thank you so much for the prompt reply! Is there a place to order these with decently quick shipping? All my hardware is worn and there is some play.
    Do you have any idea where to find the bolts that connect everything to the frame? My smaller side is pretty much stripped.
  • 04-15-2020
    Aresab
    Is it the hardware or the shock DU bushings that are worn; itís usually the DU but anythingís possible. Iíve ordered from Universal cycles, they ship quick and both appear in stock.
    https://www.universalcycles.com/shop...&category=2641
    My guess on the frame hardware is Breezer themselves; most bikes donít share hardware with others. The bolts are soft, try using the 5mm side to do the turning and just hold the 4mm side.
  • 04-15-2020
    lzcztq
    Breezer and Fuji are owned by the same parent company and the Repack is very similar to the Fuji Auric therefore if you have a Fuji dealer nearby you could ask if they could order OEM hardware.
  • 04-15-2020
    Kayoige
    Thanks for all your help guys, you came up with some great ideas!
