2.8 tires on hardtail... tire pressure- Mtbr.com
Results 1 to 5 of 5
    Jul 2019
    Iím getting from the interwebs that based on my weight (190#s) that I should be in the 15-18 psi range on my 2.8 tubeless. I feel like I understand why this is a good thing in terms of traction... but doesnít that slow you down also in terms of drag?
    Jul 2019
    As a follow up to this ... Iím also using very narrow rims. I upgraded to to the 2.8s from the 2.4s that were factory installed. I noticed that my wifeís bike has very wide rims. Should I be running at a higher pressure based on narrow rims??
    C8N
    C8N is offline
    Oct 2017
    If you are worried about rolling resistance, why did you go 2.8 in the first place?
    What is the internal width of the rim?
    Check your rim manufacturer website. They usually have recommended tire width.
    Jul 2019
    Because rolling resistance is only part of the equation and there were other things attractive about them?
    Quote Originally Posted by C8N View Post
    I don't have a ton of experience w/ 2.8's but this was my initial impression. 2.8 WTB ranger mounted on a 27mm ID rim, yes narrow but I planned on switching to a 35mm ID or larger rim. My goal was more cushion, in the rear, than my current 2.3 tire. After playing with pressures and taking a few trips to the local singletrack I concluded the 2.8 wasn't going to add the cush I desired. Traction was up but it just felt labored putting around. From my experience narrow rims decrease the tires footprint which decreases rolling resistance. Going to a wider rim would probably give a little more cush but better traction and even slower rolling. F-2.6 R-2.35 for the compromise.
  1. 29er Hardtail tire pressure and selection
    By Ldjb15 in forum 29er Bikes
    Last Post: 07-28-2016, 12:54 PM
  2. Hardtail rear tire keeps losing pressure on brand new bike
    By tgrayson in forum Beginner's Corner
    Last Post: 06-01-2015, 02:33 PM
  3. Replies: 16
    Last Post: 05-21-2015, 07:42 PM
  4. How to determine tire pressure for fat bike tires?
    By motorider in forum Fat bikes
    Last Post: 03-14-2015, 08:09 AM
  5. Replies: 3
    Last Post: 03-23-2011, 06:39 PM
Members who have read this thread: 37
