1.5" road tire on 38mm inner rim- Mtbr.com
Results 1 to 8 of 8
    Sep 2019
    Can I possibly fit a 1.5" road tire on a 38mm rim for road biking purposes?
    Feb 2007
    Not safely.
    Sep 2019
    Whats the minimum safe width?
    Reputation: Fairbanks007's Avatar
    Quote Originally Posted by sy333 View Post
    That rim is already just about 1.5" wide, a 38mm rim is more typically used for a 3.0" tire +/- a few tenths either way. Go to the web site of the rim manufacturer, they usually have the range of tire widths a rim is designed to work with listed.
    Feb 2007
    With a tube on the road, I personally would feel ok with a 2.2" tire on an i38 rim. It would flatten the profile a ton and expose the sidewalks to glass and whatnot, but it would probably work. You're better off getting a second wheelset for the road, if possible. If not, get a 2.6-2.8" tire with a fast tread and deal with the compromises.
    Dec 2017
    I'm also inclined to say no, but the real question is, why would you want to run a tire that narrow? There are a ton of 2.1-2.3" tires out there that would be faster than any 1.5" tire, and while not an ideal fit on that rim, they'd certainly be closer.
    Jan 2009
    I think because of the profile/construction of a road tire you can run the tire width to rim width closer than mountain and not get a funny profile. For example I put a 45mm slick on a 30mm rim and it look and handles well. So maybe a tire like a schwalbe Super Moto or Surly ExtraTerrestrial.
    Sent from my Pixel 3a using Tapatalk
    Reputation: roughster's Avatar
    Dec 2017
    Grab a cheap set of wheels for this application:
    http://www.bikesdirect.com/products/...heel-deals.htm
    https://bikeisland.com/cgi-bin/BKTK_...ls&ProdID=2847
    2020 Turbo Levo Comp
    2019 Strive CF 8
    2018 Farley EX 8
  1. Road oriented ~38mm tyres?
    By HollyBoni in forum Gravel Bikes
    Last Post: 05-19-2019, 02:50 PM
  2. rim width ID choice ??? ID 33.6 or 38mm for 27.5 with 2.8
    By mojomatt in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 02-22-2019, 02:11 PM
  3. Whats the smallest tire i can put on a 38mm internal rim?
    By evan.c in forum General Discussion
    Last Post: 08-09-2018, 02:42 PM
  4. looking for 2.3 tire recommendations for a 38mm od rim.
    By Imho4ep in forum Wheels and Tires
    Last Post: 05-03-2018, 09:49 AM
  5. Do it all tire 38mm-45mm size range
    By Tinman in forum Bikepacking and Bike Expedition
    Last Post: 12-16-2013, 07:18 AM
