V-Brake Questions from a Total N00b- Mtbr.com
Results 1 to 3 of 3
    May 2020
    I recently purchased a 1989 Miyata SportRunner. It's my first MTB in a long while. I am looking to get rid of the orginal canti's that came with it. I purchased some 95mm Tektro 930AL V-Brakes. I thought I had done my checks about this purchase beforehand, but apparently I missed something. The wheels are 26". I am curious, am I gonna run into problems with this length of v-brake and should get some 107mm instead, or will it be alright? Thanks for your help!
    Reputation: J.B. Weld's Avatar
    Standard v-brakes will work but you'll need new brake levers, v-brakes have a different pull ratio than canti's.
    I brake for stinkbugs
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    Quote Originally Posted by portagekix View Post
    These are halfway between a mini-v one would use on a Cyclocross bike and standard V one would use on a mountain bike. Potentially they may work with your current brake levers but will be limited in tire size that you can use. If you upgrade to the longer arms you will be able to use any mountain bike tires size but as JB Weld noted they will not work with cantilever brake levers, which pull too little cable. You will need to upgrade to a v-brake specific lever. The shorter arms pull less cable to hit the rim so might work with your levers, guess it just depends on whether you plan of hitting dirt or just pavement and dirt paths, and what tire you want to use to do so.
    MTBR Posting Guidelines
    calories>electrons
  1. Fork help for 29er n00b (not mtb n00b mind you..)
    By idrinkwater in forum 29er Bikes
    Last Post: 07-30-2014, 05:26 AM
  2. N00b reporting in with first n00b question - cranksets
    By iltridente in forum Beginner's Corner
    Last Post: 12-28-2011, 01:09 PM
  3. n00b 29er, tire tube questions?
    By Waltah in forum 29er Bikes
    Last Post: 08-08-2011, 05:19 PM
  4. total n00b
    By joshtotheb in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 06-22-2008, 11:48 AM
  5. Total n00b clyde
    By FlyByWIre in forum Clydesdales/Tall Riders
    Last Post: 04-26-2008, 12:58 PM
Members who have read this thread: 23
