Tire help- Mtbr.com
Results 1 to 6 of 6
Thread: Tire help
    baldeagle72
    May 2020
    Tire help
    I'm rebuilding an 08 Giant Trance x1 and am having trouble with the back tire rubbing where seat post and chainstay meet, had to let air out just to install it. I had 26x2.20 and wanted to go thicker with a 2.40 DHRII but the knobbies are too tall. Should I go back to the 2.2, there aren't many options in that size. Any help appreciated.
    Jul 2017
    Cut the offending pieces off
    Quote Originally Posted by baldeagle72 View Post
    Tried using 2.2's in the rear? For example, I can't use Schwalbe Magic Mary's on the rear (26x2.35) as it rubs from time to time but no problems using it in the front. For the rear, i'm using Schwalbe Nobby Nic (26x2.25) which work just fine (part number #11601030)
    Sneaker man
    Reputation: mik_git's Avatar
    If it is rubbing and that is causing concern, then either a smaller tyre, or find a tyre that says it's 2.4 but is undersize and measures smaller than it says (so basically just get a 2.2)
    All the gear and no idea.
    Reputation: MSU Alum's Avatar
    I have a Pivot 5.7c that I kept for guests to ride with a 26x2.3 Maxxis Aggressor on the back. Much faster than a DHRII. It measures 2.26" wide and my best guess as to height above the rim is 2.2". I have a DHF up front. It's a cheaper option than a Magic Mary front - NoNoi rear (which is a great combo!).
    May 2020
    a 2.40 DHRII but the knobbies are too tall. Should I go back to the 2.2, there aren't many options in that size. snaptube word to pdf vidmate Any help appreciated.
  1. Replies: 16
    Last Post: 05-21-2015, 07:42 PM
  2. Replies: 4
    Last Post: 04-18-2012, 10:48 AM
  3. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum Wheels and Tires
    Last Post: 01-26-2012, 12:54 AM
  4. I need a little tire help, tire fit
    By jormar23 in forum 29er Bikes
    Last Post: 06-10-2011, 05:10 AM
  5. Help help help with front wide tire
    By Dan001 in forum Singlespeed
    Last Post: 07-07-2007, 11:03 PM
Members who have read this thread: 41
