Small (155mm?) crank suggestions- Mtbr.com
Results 1 to 19 of 19
    Sep 2015
    Hi all,
    I am building a 26er for my daughter. The frame is 41x92mm BB92 bottom bracket. I think 155mm crank length is about right (possibly a bit too long but I don't want her to outgrow it too soon.
    Any suggestions of cranks given the frame and what BB should I get to go with them?
    Thx, Lloyd
    Moderator Moderator
    Reputation: 2melow's Avatar
    There are three pretty popular upgrade options, but all seem to be GXP style BB:
    Trailcraft Direct Mount 152mm
    https://www.trailcraftcycles.com/pro...-mount-cranks/
    Brood Styx 155mm
    https://spawncycles.com/brood-eldorado-syx-155
    SRAM NX 155mm
    https://www.amazon.com/Sram-Nx-Crank.../dp/B01BZBTDSC
    Trailcraft are the most expensive, but have an alloy bottom bracket spindle to keep the weight low and come with an alloy chainring. They are about 150+ grams lighter than a SRAM NX 155mm which uses a steel spindle and comes with a steel chainring. Not sure if light weight is important or not, but that's about 1/3 of a pound. More pics with weights here https://www.pinkbike.com/buysell/2425155/
    For BB, since you have BB92 I think you will need a BB92 to BSA 24mm spindle BB adapter.
    https://wheelsmfg.com/bottom-bracket...nks-black.html
    Best thing to do is to figure out what cranks you want then contact Wheels Mfg to verify you are getting the right BB. But I think the one linked above is what you need.
    Hope it helps!
    Front Range Forum Moderator
    Sep 2015
    Very helpful. Thank you.
    Bikes in jeans
    Reputation: jestep's Avatar
    The NX is a good one for the money. It and the Brood are GXP and not straight 24mm so if you do go that route, make sure to get the appropriate 24/22 bottom bracket or adapter and not a straight 24mm one.
    WTB: Med Bontrager Ti Lite, PM Me...
    Sep 2015
    Thank you Jestep. So I am going to for a trailcraft 152mm crank which "use a BSA (Shimano standard) 24mm spline", primarily because it is substantially lighter than some of the alternatives.
    I am still confused about which bottom bracket and what the pros and cons of the various choices are at https://wheelsmfg.com/bottom-bracket...indle_dia=7121.
    I have 2 questions:
    1) Can someone help me decide among:
    -ABEC-3
    -Angular contact
    - Thread together ABEC-3
    - Thread together angular contact
    2) Are there alternatives to these Wheels mfg bottom brackets that might be lighter or less expensive?
    Here's a link to the trailcraft crank:
    In case anyone else is reading this I found a few others in the 152mm to 155mm range. Here they are:
    1) SRAM NX 1x X-SYNC™ Crankset 30t (not bad choice but heavier than trailcraft)
    2) Trailcraft 30t ($170 incl cog and lightest)
    3) Suntour 1x ZERON 30T Aluminum Crankset hollowtech 2 (quite heavy but least expensive)
    4) Canfield Brothers*DH 83mm Crank with BB (heavy not sure weight)
    Bikes in jeans
    Quote Originally Posted by lloydus View Post
    I have 2 questions:
    -ABEC-3
    -Angular contact
    If it's for a kid, I'd just get this one and skip the angular contact bearing setups which are better but probably overkill for a light rider. https://wheelsmfg.com/bottom-bracket...no-cranks.html
    Someone should be able to confirm but you should be good with this with a standard 68/73 24mm spindle crankset like the trailcraft.
    Sep 2015
    Have to update this post. There are two good alternatives.
    1) Brood Bike co Styx direct mount crank is 155m and 590grams excl BB and chainring for $115. Add on a light chainring for $36 and 50g and you are all in for $151 at 640 grams for a 155mm.
    2) Trailcraft who have a $159 price for a 152mm crank with a 28t chainring weighing a total of 573 grams.
    Good enough choices.
    suntour XCR cranks are about 40 bucks. I went with one for my kid, in 155mm.
    Sep 2015
    I was interested in a single speed crank that would fit a BB92 frame. I could not find a Suntour XCR 155mm using a google search. I could find a Suntour XCT 152mm however this was a triple and not a single. I looked on the suntour website at ChainwheelÂ*- SR SUNTOUR Cycling and could only find one single speed crank. It is the ZERON ZERON-1X which is available in 152mm but when I went to find one for sale on the web I was not successful. Also it has a minimum 30t chainring.
    I've got a very lightly used Trailcraft square-taper 2x+bash setup, if that interests. 152mm arms w/BB.
    Works great as a 1x with the RaceFace 30t NW ring, but we're keeping the ring...
    Sep 2015
    Sorry the frame for my build is BB92 so can't go square taper. If I did there'd be lots more choices!
    Reputation: SRvancouver13's Avatar
    Hey Lloydus.
    You can find our crank and crank parts on our North American website.
    www.srsuntour.us
    Let us know if you have any questions.
    Best, Nick
    [email protected]
    SR SUNTOUR North America
    Jul 2014
    Plenty of BMX cranks using square taper and 5x110/130 chainring fitment, such as Sinz, if you wanna go down that route. 145/150/155 arms.
    Mar 2016
    I'm looking at these for my son. 152mm 899 grams. comes with the BB.
    https://www.srsuntour.us/products/ze...nt=45338041742
    Sep 2015
    Quote Originally Posted by 53sled View Post
    I finally ended up going with a more expensive and lighter product. Trailcraft 152mm cranks (511 grams) and trailcraft 30t chainring (71 grams). Total cost $159. You can choose among 26t, 28t, 30t and 32t chainrings.
    Sep 2015
    Update: Trailcraft 152mm cranks are working well. They are part of a super light weight hard tail bike - and best of all (according to my daughter) it's BRIGHT PINK.
    Nov 2020
    Anybody got some updated suggestions for shorts cranks for BB92? The Trailcraft ones are out of stock, and I cannot find anyone who stocks155mm SRAM SX (I’d like a 12 SRAM ideally). This is for a kids bike build on a chinese carbon 26er import frame (BXT). All help much appreciated!!
    Bikes in jeans
    Quote Originally Posted by bikingben8000 View Post
    Looks like the 165's are available in a few places if there's any chance those would work. I'm guessing it may be a wait based on manufacturing problems right now though. I couldn't find any of the 155 NX's either, seems like a major shortage of short 2 piece cranksets everywhere.
    Sep 2015
    Shimano is a good bet for 165mm but less than that will be difficult with 2 piece. Best to get in line with Trailcraft.
  1. wicked good deal on kids push bike kids woot
    By MattyBoyR6 in forum Arizona
    Last Post: 03-30-2011, 11:48 AM
  2. B-day Idea for kids and big kids..
    By SKULLY in forum California - Socal
    Last Post: 07-26-2006, 07:09 PM
Members who have read this thread: 34
