Rim tape width?- Mtbr.com
Results 1 to 10 of 10
Thread: Rim tape width?
    Jul 2019
    Rim tape width?
    The tape on my WTB rims is about 16mm. Im replacing it while I do the tires. Is that correct or should it be narrower 10mm which corresponds to the dim of the recess?
    Dec 2013
    16mm is fine, maybe 14mm or 12mm if you want new rim tape.
    Jul 2019
    I guess I should have come clean and said I already ordered 10 mm thinking it should correspond to the recess. If Iím going to order again what would be ideal?
    Reputation: J.B. Weld's Avatar
    I'd say the 16mm that was on there is pretty much ideal.
    I brake for stinkbugs
    Sep 2019
    Quote Originally Posted by J.B. Weld View Post
    Yup, that's what I'd use on those wheels.
    Reputation: HotelBravo26's Avatar
    Nov 2019
    WTB recommends on their website you buy 5mm wider than your inner rim width.
    I race XC with a 2005 Raleigh M80. Yes, I really do.
    Sep 2019
    Quote Originally Posted by HotelBravo26 View Post
    That's for tubeless, which is a completely different discussion. For tubed tires, you just need to cover the holes, and you absolutely do not want wide tape that rides up the lips.
    Reputation: MSU Alum's Avatar
    Quote Originally Posted by Autoxfil View Post
    Yeah, you don't want tubes being pushed into the holes.
    Yes but for most rims edge to edge (but not up the sidewall) is best because it will stay in place better. Skinny rim tape tends to wander unless the rim has a well defined inner channel.
    Nov 2019
    Fair point. I didnít realize we were talking tubes.
  1. Replies: 3
    Last Post: 12-07-2018, 03:36 AM
  2. Replies: 8
    Last Post: 10-22-2017, 07:27 AM
  3. 30mm width rim an upgrade from 24mm width rim?
    By metrotuned in forum Wheels and Tires
    Last Post: 07-22-2012, 07:30 AM
  4. Scotch tape for rim tape?
    By Natedogz in forum Wheels and Tires
    Last Post: 08-28-2011, 09:27 AM
  5. Gorilla Tape in place of rim tape?
    By dexetr30 in forum General Discussion
    Last Post: 05-01-2011, 10:41 AM
Members who have read this thread: 26
