Results 1 to 3 of 3
    Aug 2018
    Questions about threaded and threadless forks
    Hi guys. I have a cheap mtb thats has a rigid fork and i want to convert it to a suspension fork. But there arent really that much suspension forks that have a 1 inch steerer tube but i found one. If i replace it why would i need to replace the cups too? I cant use the old cups and bearings?
    Dec 2015
    You got it, threadless and threaded steerers require different headset cups. Some headset brands require only a new top cap (like Cane Creek). The install is easy with the right tools, but I recommend you have a bike shop do it because the specialized tools are expensive. You can get a low-end Cane Creek or Tioga headset, which should be fine, or you can go flashy. The end result will be the same.
    Have fun and be safe, you really donít want to hack something together and lose steering control on a downhill.
    Sneaker man
    Reputation: mik_git's Avatar
    Also, before you go off buying stuff, you want to make sure that you're bike IS 1 inch, not saying it isn't but making sure saves the headache if it turns out to be 1-1/8.
    So then you'll also need the threadless headset and a threadless stem (and make siure that that has the right size to fit your bar - unlikely to not fit if 1 inch but you never know).
    All the gear and no idea.
  1. Threadless or threaded fork
    By jackspade in forum Singlespeed
    Last Post: 06-20-2011, 06:56 PM
  2. Threaded fork with threadless headset?
    By jesseb55 in forum Shocks and Suspension
    Last Post: 03-01-2011, 07:57 PM
  3. Forks, Forks, Forks, Forks, Forks, Forks
    By Ben12321 in forum Beginner's Corner
    Last Post: 05-04-2008, 05:01 PM
  4. threadless to threaded to threadless Y Not?
    By Sasquatchcycles in forum Vintage, Retro, Classic
    Last Post: 11-23-2007, 10:44 AM
  5. Replies: 11
    Last Post: 04-13-2005, 05:48 AM
Members who have read this thread: 16
