Pivot bearings question- Mtbr.com
Results 1 to 10 of 10
    afa
    afa is offline
    Feb 2019
    Hi all! Hope this is a good section for this problem. So I have a specialized enduro 2006 bike that has some need to be replace bearings. One of them is the double back to back on the shifter side, itbis griped, doesn t move.
    I have 3 questions (sorry&#128515
    How can I get the old bearings out, they look stuck.
    Could I still use the bike till my new bearings arrive? It is big danger to damage the bike?
    Do these bearings look good for my bike? I don t know this blue brand:
    https://www.ebay.com/itm/Specialized...3912103?_ul=ES
    Thank you so much!
    Reputation: fredcook's Avatar
    Not stuck, but press fitted maybe.
    You didn't quit riding because you're old, you're old because you quit riding.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    No idea, I had a 2014 enduro though that had horst-link bearings that were all but impossible to remove. There were two on each side and no "lip" to punch them out with, but the frame material was in between them, so it was flush, but if you tried pounding them both at once, they wouldn't go because the frame was in between them. Horrible design, one of those "cheap" manufacturing decisions where the bike/part is just intended to be disposable and crap out after a few seasons. That was my first and last specialized bike in a long time for that reason. Post some detailed pictures of what you are talking about and we can hopefully help. Most bearings have the specs on the bearing itself.
    afa
    afa is offline
    Feb 2019
    Thank you very much for the answer. On the bearing is "6902 - 2RS NBK"Pivot bearings question-20190422_144209.jpg This is the caseing in between what looks like 2 beaings has a metal imb but it is imposibe to fit in any tool.
    May 2010
    I had no trouble getting mine out with one of these:
    https://www.amazon.com/Goplus-Bearin...dp/B0752W1VP2/
    Wanna ride bikes?
    Oct 2013
    Not sure if this is the right bike, but these guys do complete bearing kits. https://www.enduroforkseals.com/prod...s/SBKSPE3.html
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    afa
    afa is offline
    Feb 2019
    Thank you "OneSpeed" that s the bike! (I have diffrent fork tho, mine is mazzorchi)
    The other question is still on: how can I get the double back to back bearings out? It can be done without a puller?
    Wanna ride bikes?
    Oct 2013
    Yeah, buy a bearing puller or pay a shop to do it.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Quote Originally Posted by afa View Post
    You will need a blind hole bearing puller to get the back to back bearings out, this has a piece that grabs the bearing from behind so you can pop it out. Some auto parts stores rent or loan these. Also consider a bearing driver set to install the replacements. You have be careful where you apply force when installing so you don't trash the new bearings. If the bearing presses into the frame or link, only pres on the outer race during installation, if the bearing is pressed onto an axle or stud, only press n the inner race. Also heat is your friend, if you are pressing a bearing into the frame chill the bearing and warm the frame to open up the tolerances.
    2009 Redline Conquest Pro, 2008 Trek Fuel Ex8
    2007 Kona Cinder Cone utility bike
    Yes I spent too much on bikes.
    Reputation: gravityryder26's Avatar
    Feb 2013
    I got mine out with a punch. I got them back in with a socket
  1. Wreckoning pivot bearings/main pivot
    By Scandy101 in forum Evil Bikes
    Last Post: 10-21-2018, 07:21 PM
  2. Cartridge Bearings versus Cup and Cone Bearings
    By caesar148 in forum Weight Weenies
    Last Post: 01-06-2013, 05:51 PM
  3. MV '10 pivot bearings...1 clunky pivot.
    By socalscott in forum Marin
    Last Post: 06-09-2011, 01:06 PM
  4. Bontrager RE-1 Pedal Bearings? Any Pedal bearings?
    By davez26 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2011, 09:35 AM
  5. Replies: 11
    Last Post: 11-03-2008, 12:33 PM
Members who have read this thread: 55
