Results 1 to 10 of 10
    Nov 2014
    Opinion on 3 forks Rock Shox Psylo, Rock Shox Recon Air 327, or SR Suntour XCM 100
    My brother left some old bikes in my parents garage and I'm in the process of making 1 good bike. These are the 3 forks in the garage I have to choose from. Which would you recommend. I'm not a hardcore rider and I ride a lot on the streets. Which would be the lightest? The Rock Shox Recon Air 327 (solo)? I'm about 155lbs and which one would be most reliable as I'm sure parts and seals maybe harder to find.
    off a 2006 GT Zaskar Expert
    RockShox Recon 327 2006 Front Shocks Reviews - Mtbr.com not sure if this is the right one.
    Looks like this one
    Rockshox recon 327 Singletrack Forum
    RockShox Psylo XC 2003 Front Shocks Reviews - Mtbr.com
    Reputation: cerebroside's Avatar
    From what I've heard both the Psylo and XCM are notoriously bad, so I'd go with the Recon (IMHO). You will probably want to rebuild whichever one your choose just based on how old they are.
    Silence! I kill you!
    Reputation: Jorgemonkey's Avatar
    I had a Psylo and replaced it with a Pike. Big difference. I'd probably go with the Recon as well.
    My photography website:
    Scott Mosher Photography
    Reputation: dietz31684's Avatar
    I came to say recon, but it looks like everyone beat me to it!
    The recon chassis is really pretty good. The damper is really pretty bad.
    If you install a later black box/dna rebound unit (drops right in!), it becomes a good chassis with a good damper, for very cheap!
    Nov 2014
    Thanks everyone for the input, looks like this is a no brainer.
    Even the cheaper MoCo damper would be a big upgrade.
    Sent from my VS980 4G using Tapatalk
    Reputation: White7's Avatar
    Feb 2015
    Not sure if it's been mentioned,,,but Recon
    I think the Psylo is not so bad, a lot better than the XCM... Recon is the best of the three, though.
    Class Clown
    Reputation: dundundata's Avatar
    i have a recon but it's a bit newer and was able to upgrade the dampers, but you need to make sure they fit. even stock with an oil change, new seals etc. it should be pretty good
  1. What to do with a 02/03 Rock Shox Psylo SL/Race?
    By lyra in forum Beginner's Corner
    Last Post: 12-09-2013, 04:06 PM
  2. Need help with Rock Shox Recon SL forks
    By lucmac in forum Shocks and Suspension
    Last Post: 11-03-2013, 09:08 AM
  3. help w/ rock shox psylo rebuild
    By mrowe27 in forum Shocks and Suspension
    Last Post: 09-09-2013, 05:23 AM
  4. rock shox tk 30 gold solo air, recon silver or suntour epicon x1?
    By TheStapl3r in forum Shocks and Suspension
    Last Post: 07-29-2013, 01:31 PM
  5. Rock Shox Recon Silver Vs Suntour Raidon LO R Air Disc Blk/White 29
    By joepa150 in forum Shocks and Suspension
    Last Post: 07-24-2013, 05:16 PM
