New member 1x10 issue chainline- Mtbr.com
Results 1 to 8 of 8
    Ride on
    Reputation: Kerfree's Avatar
    Oct 2019
    Hey guys new here first post I have a 2008 diamondback xsl trail 1x10 with 38 tooth up front and a sunrace 11x42 cassette when in mid gears on cassette chainline is great when all the way up in 42 tooth getting noise from chain behind crank cause chain is out the far should I shim my crank chainring some to help even though chainline is straight in mid gears like it should be
    Reputation: MSU Alum's Avatar
    Could be a worn chain. How many miles do you have on it?
    Ride on
    Oct 2019
    Quote Originally Posted by MSU Alum View Post
    brand new can see chain go way off line when you look down the line
    Care to share a picture? What crankset/bottom bracket are you using? which side of the BB are the spacers on? Any info would help.
    Ride on
    Oct 2019
    Can do pic tomorrow down with flu the BB is just external bearing hollow tech snail narrow wide chainring in front sunrace 11x42 cassette no spacers but a bracket to mount chaingaurd with tensioner and bashgaurd canít think of anything else at the moment
    Reputation: J.B. Weld's Avatar
    Is the chain straight in the middle cog?
    I brake for stinkbugs
    Reputation: Timothy G. Parrish's Avatar
    Apr 2014
    This bike was originally a 3x. When older bikes are converted to 1x, the single ring needs to be where the middle ring would have been on the old crankset. Most likely, the single ring is now lined up where the large ring would be, and you typically wouldn't ever be in that chainring cassette combo when shifting on a 3x. If your crankset is a BCD 104, just put the ring on the backside of the spider where the middle ring would be.
    Ride on
    Oct 2019
    Itís a new crank and chainring it worked fine as 2x until I installed the the adaptor behind bottom bracket for the chain guide bashplate combo so I measured the adaptor that goes behind BB and itís 3.97 mm so I think if I shim the chainring over 4 mm it should be ok the things that happen in you mind when your sick in bed to make you think clearly ainít it something
  1. SRAM 1000 + BB92 1x10 Chainline Problems
    By warimono in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-09-2014, 12:02 PM
  2. Process 153 1x10 chainline problems
    By warimono in forum Kona
    Last Post: 05-28-2014, 12:08 PM
  3. Slayer 30/50/70 Chainline/Running 1x10
    By shredjekyll in forum Rocky Mountain
    Last Post: 11-05-2013, 10:41 PM
  4. Best chainline for 1x10
    By s-keeper in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2011, 12:28 PM
  5. GXP Chainline chainline issue...
    By notenoughtime in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-11-2008, 08:02 AM
Members who have read this thread: 27
