Looking for some riser bars for an old Stumpjumper.- Mtbr.com
Results 1 to 7 of 7
    DAC M5 Beast
    Not sure what fits this stem. Looking to make this bike a little more comfortable for my wife to ride around the neighborhood. Not sure if the size.
    Attached Thumbnails Attached Thumbnails Looking for some riser bars for an old Stumpjumper.-0c43f9da-6c93-4705-82d4-546f8d4da42c.jpg
    Looking for some riser bars for an old Stumpjumper.-83d1c856-bda4-49f0-836d-3c09928ba449.jpg
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Most likely a 25.4mm clamp diameter on the stem, so you need a 25.4 mm riser bar.
    https://www.universalcycles.com/shop...p?category=516
    Keep in mind, the more rise the bar has, the harder it is to get it through the clamp on the stem. There are a few tricks you can try.
    Thatís why modern stems have removable face plates. Those types of stems are fine for flat bars, which were all the rage back when that bike was made.
    Also, changing to a wider bar will rise will likely require replacing cable and housing as well. There probably isnít enough length to move the shifters and brake levers up and/or out very much.
    DAC M5 Beast
    Thanks. All good points I hadnít considered. Any suggestions are welcomed.
    Reputation: x3speed's Avatar
    Ritchey Rizer just put one on
    Too many bikes, not enough time...
    DAC M5 Beast
    Just ordered some - SC comp
    Nov 2016
    Buy her this pretty Rockhopper!
    Attached Thumbnails Attached Thumbnails Looking for some riser bars for an old Stumpjumper.-00r0r_2fv4bdbq3sa_1200x900.jpg
    Dec 2013
    Get riser handlebars, 4" and 5" are common, along with a new stem that rises higher gets you even more height.
    JensonUSA
    Modernbike
    Amazon.com
    Online classifieds for used riser handlebars
  1. Flat bars vs Low Riser bars on 29er?
    By Okie Dokie in forum XC Racing and Training
    Last Post: 10-07-2011, 08:07 AM
  2. Flat bars vs. riser bars
    By L'il Matt in forum Beginner's Corner
    Last Post: 11-12-2008, 11:42 AM
  3. Riser bars or riser stem?
    By Evisr8r in forum Beginner's Corner
    Last Post: 05-04-2006, 09:22 AM
  4. flat bars vs. riser bars
    By cmatcan in forum General Discussion
    Last Post: 12-13-2005, 02:31 PM
  5. Flat Bars vs Riser Bars
    By rpmrob in forum XC Racing and Training
    Last Post: 05-12-2004, 10:12 AM
Members who have read this thread: 28
