Help??? setting up v brakes on nos fork with no vbrake studs or stops, but has holes- Mtbr.com
Results 1 to 6 of 6
    Reputation: x3speed's Avatar
    Folks got a new old stock 140mm M. bomber that I need the small vbrake studs for with the little holes for the stops. Where can I find those? Thank you in advance.
    Too many bikes, not enough time...
    Sneaker man
    Reputation: mik_git's Avatar
    need to search for canti or v-brake Bosses.
    I got some rear ones from paragon machine works a while back, i think they do fronts as well...as im sure many places do, just can sometimes be tricky knowing the size/thread etc.
    All the gear and no idea.
    Anyone else seen these, a link would be great
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    Quote Originally Posted by x3speed View Post
    The previous post has the info you need.
    Also, check online or your bike shop for Problem Solvers canti studs. You'll want M10 not M8 unless you want to go super old school and run U brakes/cantis.
    Amolan
    Pretty sure those are very Marzocchi fork specific studs. I think these require the type with a plastic stand off spacer that is built in.
    Had a set awhile ago, sold them. You can contact Marzocchi Mark: https://www.mtbforksbymark.com/
    He wound up with all the older Marzocchi stuff when the US service center closed.
    Thank you so much, I emailed him
  1. Replies: 82
    Last Post: 11-28-2015, 10:19 PM
  2. Replies: 5
    Last Post: 05-06-2013, 08:06 PM
  3. What to do w/ holes left by V-brake studs?
    By reactiontime89 in forum General Discussion
    Last Post: 04-13-2008, 02:32 PM
  4. SPAM: NOS 1" SID, NOS Arch Supremes, Hershey Long Necks
    By twisneski in forum Vintage, Retro, Classic
    Last Post: 11-22-2004, 07:39 PM
  5. removing vbrake studs from 02 Z1?
    By bayarearider in forum Shocks and Suspension
    Last Post: 10-26-2004, 09:13 AM
Members who have read this thread: 37
