headset needed for replacing a C'Dale headshock- Mtbr.com
Results 1 to 5 of 5
    Oct 2018
    i have a friend who would like me to replace his headshock on his Cannondale Jekyll and im curious what headset i need for a standard 1 1/8 steerer
    the head tube on this thing looks enormous and nothing i have seems to fit.
    TIA
    https://www.treefortbikes.com/Proble...dshok-Headtube
    You would need to use the adapter above in addition to a 1-1/8" headset to install a 1-1/8" fork on a cannondale with a headshock. Also a good idea to measure axle to crown height on the old headshock to find something that will set him up in a similar riding position
    83 Ritchey Everest
    95 Bianchi Mega Tube ti
    2015 Kona Operator Supreme
    2019 Kona Process 153 CR 29
    Bikes in jeans
    Reputation: jestep's Avatar
    Quote Originally Posted by Special Eye View Post
    TIA
    You should still be able to rebuild it if it's not completely trashed as well, in case that's a consideration.
    WTB: Med Bontrager Ti Lite, PM Me...
    Sep 2014
    A simpler way would be to keep the current external cups and replace the bearings with the Cannondale KP058 kit. I also offer head angle reducing headsets compatible with those cups: https://www.pinkbike.com/buysell/2118769/
    IIRC the headshok head tube, with cups removed, is a 49mm standard (49.6mm inner diameter) There may be 1,1/8" headset for that size.
    Oct 2020
    headset needed for replacing a Cannondale Headshok
    Your choice of a reducer headset will depend on the current installed headset. The Cannondale KP058 is a 1.5" SI (System Integrated) reducer to use a 1 1/8" fork. The Cannondale KP205 is a 1.5" SI reducer for a tapered fork. The Cannondale KP119 is another 1.5" SI reducer for for a 1.5" steerer tube. The standard 1.5" headset (with the SI on top) uses a different set of headset reducers, e.g., the HD232 for 1 1/8" steerer tubes, etc. You can find more details at:
    https://docs.google.com/spreadsheets...=0&output=html
  1. Headshock Headset cups?
    By Mongo40 in forum Cannondale
    Last Post: 07-10-2014, 05:28 AM
  2. Replacing Headshok with non-C'dale 1.5" fork.
    By chestnut in forum Bike and Frame discussion
    Last Post: 02-01-2014, 05:03 PM
  3. Replacing Headshock with Traditional Suspension Fork
    By cdouble in forum Shocks and Suspension
    Last Post: 08-29-2013, 05:00 PM
  4. Replies: 7
    Last Post: 02-27-2006, 11:26 PM
  5. Repair Manual Needed For Lefty Headshock??
    By tmachalek in forum Cannondale
    Last Post: 07-16-2004, 12:35 PM
Members who have read this thread: 22
