26" tyre width on 2007 Rockhopper- Mtbr.com
Results 1 to 3 of 3
    Jun 2020
    Hi All,
    I picked up a 2nd hand Rockhopper recently (UK Spec - see bottom of post for details) and was wondering how wide I could go on tyres?
    Currently it has bald 26 x 2.1 on it but crashed twice recently so need to replace. I'm not overly bothered by width other than the fact that there aren't many choices at 2.1 wide hence wondering how much wider I could safely go?
    Thanks,
    GC
    FRAME New for 07 M4 manipulated alloy frame, butted ORE DT, disc only, forged dropouts w/ replaceable 98954020 derailleur hanger
    FORK RockShox Tora 302 SL, 100mm, 32mm Cr-Mo stanchions, alloy steerer, mag lower, coil spring, preload adjust, lockout w/ rebound adjust
    HEADSET 1 1/8" threadless
    STEM Specialized 3D forged alloy, four bolt, 31.8mm, 7 degree rise
    HANDLEBARS Specialized 31.8mm XC Rise, 640mm wide, 8 degree back/6deg upsweep
    GRIPS Specialized Enduro, dual density, Kraton
    FRONT BRAKE Avid Juicy 3, hydraulic disc, 6" G2 Clean Sweep rotor
    REAR BRAKE Avid Juicy 3, hydraulic disc, 6" G2 Clean Sweep rotor
    BRAKE LEVERS Avid Juicy 3 hydraulic
    FRONT DERAILLEUR Shimano Deore M-530
    REAR DERAILLEUR Shimano LX
    SHIFT LEVERS Shimano Deore SL M511
    CASSETTE Shimano HG-50, 9-speed, 11-34t
    CHAIN Shimano HG-73, 1/2" x 3/32" w/ missing link
    CRANKSET Shimano FCM-442-8, Octalink Spline, 9-speed, replaceable rings w/ alloy outer
    CHAINRINGS 44A/32S/22S
    BOTTOM BRACKET Shimano ES-25, Octalink Spline, cartridge bearing, 68 x 118mm for 50mm chainline
    PEDALS Specialized alloy 1pc, 9/16"
    RIMS Specialized/Alex, RHD 26, double wall, disc w/ eyelets
    FRONT HUB Specialized Hi Lo disc, 32h, CNC flange and disc mount, QR
    REAR HUB Shimano FH-M475L, cassette, disc, 32h, QR
    SPOKES 1.8mm (15g) stainless, black
    FRONT TYRE Specialized Fast Trak, 26x2.0", DC, 60TPI, aramid bead
    REAR TYRE Specialized Fast Trak, 26x2.0", DC, 60TPI, aramid bead
    TUBES Specialized schraeder valve
    SADDLE Specialized Body Geometry, MTB
    SEAT POST Specialized alloy micro adjust, 30.9mm
    SEAT BINDER Specialized forged alloy w/ Q
    Ride what you like!
    Reputation: MattiThundrrr's Avatar
    Jul 2019
    Shoot that's a nice one! Can't give you exact numbers of what will fit your bike, but I've put 2.25" tires (knobbies and also slicks) easily on a 93 or 94 HardRock without trouble. I probably could fit bigger.
    The revolution starts now
    When you rise above your fear
    And tear the walls around you down
    The revolution starts here
    Class Clown
    Reputation: dundundata's Avatar
    2.3
  1. Replies: 3
    Last Post: 12-07-2018, 03:36 AM
  2. halo vapour 26" recomendations for tyre width
    By how many bikes 1967 in forum Wheels and Tires
    Last Post: 03-05-2018, 02:48 PM
  3. Tyre volume, width and rim width?
    By daniel.moller.7370 in forum 29er Components
    Last Post: 07-19-2015, 06:17 AM
  4. 2007 Jamis Exile 26" vs 2008 GT Peace 26"
    By djembe975 in forum Singlespeed
    Last Post: 07-10-2008, 10:57 PM
  5. Tyre width vs rim width
    By SMartS in forum Turner
    Last Post: 08-25-2006, 11:55 AM
Members who have read this thread: 16
