2006 Specialized Stumpjumper Expert rear shock replacement- Mtbr.com
Results 1 to 2 of 2
    Jul 2020
    I currently have a 7.5x1.75 rear shock. If the eye to eye and stroke is the same, can I just replace it with any shock? I was planning to get the Rockshox Deluxe Select Rear Shock 190mmx45mm Debonair if it fits
    Sep 2019
    That would fit. Eye to eye is the most important, and a slight increase in stroke is normally fine. I'd say you're probably good with any 7.5x2 (190x51) shock as well, although...
    There is a possibility that a longer 2" stroke shock will cause the rear wheel or rear suspension to make contact with the frame at full compression - investigate that for your bike.
  1. Replies: 3
    Last Post: 07-31-2020, 04:59 AM
  2. Replies: 2
    Last Post: 06-03-2016, 11:27 AM
  3. Replies: 10
    Last Post: 06-23-2013, 01:08 PM
  4. Stumpjumper FSR Expert 2006 or Stumpjumper FSR Elite 2007?
    By mateencleaves in forum Specialized
    Last Post: 05-02-2007, 05:55 AM
  5. Stumpjumper FSR vs. Stumpjumper Comp vs. Stumpjumper Expert
    By colorado_mark in forum All Mountain
    Last Post: 07-29-2006, 04:12 PM
Members who have read this thread: 9
