Will older xx1 crankset with direct mount boost chainring work for boost- Mtbr.com
    Posted in sram forum but figured someone here may know since I hope to use it for a 29+ bike with boost hubs.
    I have an older xx1 crankset and was wondering if I used the direct mount sram x-sync chainring that is boost compatible (3mm offset) if this will work for frame that is set up for boost? I wasnt sure if just a chainring change will work or if I have to buy a brand new boost compatible crankset. Thanks
    Frame Building Moderator
    Reputation: Walt's Avatar
    Yes, just swap the chainring and you're good.
    -Walt
    Thank You Sir!!!
    May 2012
    Walt is correct.
    But you may want to try it with your existing non-boost chainring. I swapped back to a non-boost ring as it improved my chainline and the chain still cleared the tire.
  1. Replies: 1
    Last Post: 04-27-2016, 06:25 PM
  2. Replies: 7
    Last Post: 04-10-2016, 10:27 AM
  3. HOPE HUBS Pro 2 Evo/Pro 4 BOOST IS NOT BOOST!
    By yamaha46 in forum Wheels and Tires
    Last Post: 02-12-2016, 08:48 AM
  4. Boost or non-boost fork for 5010v2?
    By furball in forum Santa Cruz
    Last Post: 02-03-2016, 09:10 PM
  5. Boost 110 fork mount?
    By backcountryj in forum Cars and Bike Racks
    Last Post: 07-30-2015, 01:26 PM
