Soma Juice 29er vs Soma B-Side for 27.5 x 2.8- Mtbr.com
Results 1 to 16 of 16
    Jan 2015
    Soma's two 2017 mountain bike models can both accommodate 27.5 x 2.8 wheels. The overall diameter of 27.5 x 2.8 is pretty much equal to a 29 x 2.2. That means the B+ wheel in the Juice is on the small side for what the frame can accommodate (easily 29 x 2.4). The same wheel on the B-Side is the largest diameter the frame can accommodate. I imagine I would need to run the sliding dropouts forward on the Juice and slammed back on the B-Side. Doing so would pretty much make the overall wheelbase about the same and make the chainstays about the same. Differences then might boil down to bottom bracket drop (less drop on the B-Side), different stack and reach measurements and slight variation in head tube angle (B-Side is a degree slacker).
    I'm looking for a steel singlespeed steed for decently technical singletrack. Speed is not that important to me. Climbing ability I would rate more importantly than descending speed. Climbing rocky, rooty, twisty switchbacks is what I want to conquer.
    Which frame would you recommend for my intended use?
    Many thanks,
    Eric
    tranqui_yanqui
    Reputation: schuster.ryan's Avatar
    Oct 2011
    return to the Soma site and you shall see a new steed that posesses the features you desire.
    Santa Cruz Hightower CC 29
    Santa Cruz Chameleon 27+
    Soma Double Cross
    Reputation: grubetown's Avatar
    Sep 2013
    They have this now too
    Valhallen (27.5+) | SOMA Fabrications
    Jan 2015
    Thanks for the note on the Valhallen. Looks awesome. But I'm building this bike around a set of 135/100 wheels, with Paul hubs and Velocity Dually wheels -- already in hand. No Boost on this one, so that leaves the Juice and B-Side.
    Sep 2013
    In the geometry foot notes, it looks like the Juice numbers are based on a 29X2.2 tire which is what you are shooting for. The B-side seems like its a 27.5 bike that can accommodate plus size tires, where the Juice seems like it would handle the plus size tires better. I would lean toward the Juice if I were looking at your style of riding. However, I don't know your body type, which might be a factor in picking which specs you go with also.
    I've got a 2015ish Juice with 2.3 VeeTire Crown Gems on WTB i25 rims and I doubt I could get much more tire in the rear. The dropouts are in their most forward position. Perhaps if I moved them back a bit I could squeeze a 2.4 in there, but I love the way it rides now so I'm not changing it
    Reputation: bikeny's Avatar
    Quote Originally Posted by ericjayowsley View Post
    Many thanks,
    Eric
    I can't really answer your question, but wanted to note that a 27.5x2.8 tire will be closer in diameter to a 29x2.0.
    I think the B side would be a better option, as you will have problems bashing pedals into rocks over techy terrain with the lower BB.
    Jan 2015
    Quote Originally Posted by bikeny View Post
    I was worried about that. In theory, the overall diameter of a 27.5x2.8 is the same as a 29x2.2, but in reality, most of the 2.8s out there measure a bit small. Thanks for the feedback.
    Reputation: seat_boy's Avatar
    Looks like the new Juice has more tire clearance than the older models. I think they also raised the bottom bracket some for 27.5+ use.
    Quote Originally Posted by bucktruck View Post
    http://www.bikingtoplay.blogspot.com/
    RIGID, not "ridged" or "ridgid"
    PEDAL, not "peddle." Unless you're selling stuff
    Jan 2015
    Let me ask the question from a different perspective. If you owned a custom 27.5 Velocity Dually wheelset mated to Paul Disc Hubs (135/100), what steel, singlespeed capable frame would you mount them on? What size tires would you put on them?
    Put 27.5 wheels on a 27.5 frame. Fit the biggest tires you can. Simple.
    Sep 2013
    Go custom - Retrotec, Sklar, Hunter or Stinner
    Of course, that would triple or quadruple his frame cost. Are you making up the difference?
    Quote Originally Posted by grubetown View Post
    Sep 2013
    He has never specified a price
    For 100/135 wheel set, there may not be many inexpensive, new options without going custom.
    Mar 2005
    only 4 months late!
    well....have been riding the singletracks since 1984...after over 100 bikes being 26, 29 and 27.5 fatties and regular I can honestly say I have settled in with the soma b-side,
    can run 2.4/2.6 depending ...and above that seem to get very slow.
    this is for medium hardpack NC woodsy trails.
    the 29er was great at speed (am 6') but the b-side excels at twisty rooty and climbing...not that the 29er doesn't...it actually does all that better except for twisty and ESPECIALLY the berms.
    nothing berms like a 26er(or bmx if you want to go there)...but 27.5 does it MUCH better than a 29er if you have a snake run...with jumps.
    I like all sizes, but the b-side is the best compromise for one bike to do it all imho.
    Has anyone see how big of a plus tire the new B side can take? I know Soma claims a 2.8, but I'm wondering if that's a real 2.8 tire, or something like a WTB Trailblazer 2.8 (more like a 2.5 or so).
  1. Replies: 103
    Last Post: 02-18-2020, 03:07 PM
  2. New Juice vs. old Juice- Is it still the juiciest?
    By archtop44 in forum 29er Bikes
    Last Post: 05-21-2015, 04:00 PM
  3. Will this skewer set fit my Soma Juice 29er?
    By ddublu in forum 29er Components
    Last Post: 12-25-2012, 08:13 PM
  4. Soma Juice 29er sizing
    By ddublu in forum 29er Bikes
    Last Post: 11-29-2012, 01:50 PM
  5. Soma Juice vs Stumpjumper 29er EVO
    By WMBigs in forum 29er Bikes
    Last Post: 01-11-2011, 10:13 PM
