If I can run 26x4.7" can I assume I can run 293"?- Mtbr.com
Results 1 to 3 of 3
    Jun 2016
    I have a 2016 Rocky Mountain Blizzard -50 with 4.7" Bulldozers. Come spring, I'd like to try a 29+ wheelset and I'm curious about compatibility.
    Fat bikes - more work on the up, more fun on the down.
    "Big Bird" - Rocky Mountain Blizzard -50
    Frame Building Moderator
    Reputation: Walt's Avatar
    If they are true 4.7" tires and radius is in the 380-385mm range, then yes, 29x3 will fit.
    If they run small and you're tight on clearance to the center knobs, then it will be close or no cigar.
    In general, though, unless you have a really unusual frame, anything that will take a 26x4.7-5 will take 29x3.
    -Walt
    Reputation: bikeny's Avatar
    Bonus: It will also fit 27.5x3.8!
  1. Replies: 409
    Last Post: 04-16-2018, 04:44 AM
  2. Panaracer Fat B Nimble 26x4" - actual width?
    By Velobike in forum Fat bikes
    Last Post: 11-24-2015, 12:23 PM
  3. Light "click" or "snap" or "clunk" when pressing down hard on pedals
    By VFXterra in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 07:37 AM
  4. 26x4" rear 29x2.5" front?
    By Chris147 in forum Fat bikes
    Last Post: 07-14-2014, 09:50 AM
  5. Replies: 6
    Last Post: 07-14-2013, 04:38 PM
