BB For 2017 Stache 7- Mtbr.com
Results 1 to 13 of 13
    I'd like to replace my stock BB with this Wheels Mfg BB: https://wheelsmfg.com/bottom-bracket...nks-black.html
    My crank set is the stock Sram X1 1200 with a PF 92 BB. Will the above Wheels BB work with my crank?
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Looks like it!
    Australia
    Reputation: bataleon's Avatar
    Jun 2015
    Yep. I've got the same wheels BB on my 7.
    2019 Stache 9.7
    ̶2̶0̶1̶6̶ ̶S̶t̶a̶c̶h̶e̶ ̶7̶
    Quote Originally Posted by bataleon View Post
    Just ordered mine, looking forward to swapping out the plastic press in.
    Australia
    Jun 2015
    It's very well made and there've been no more clicks and creaks since the install. I went for the angular contact bearings too.
    2019 Stache 9.7
    Mar 2011
    Excellent choice. Their pf30 thread together bottom brackets are great, so I can imagine the pf92 will be no different.
    Just received my BB today, looks like a quality unit. The bearing width / depth on the drive side is not as wide as the non drive side. Basically a fatter bearing is on the non drive side. Is yours like this as well?
    Just to be clear, I know diameter is 24 & 22. Talking about the actual width of bearings.
    Australia
    Jun 2015
    I don't remember, but having a look at their install PDF the bearings do appear to be different widths, with the fatter being on the non-driveside. Yours sounds correct
    https://wheelsmfg.com/tech/PDF/BB869...STRUCTIONS.pdf
    2019 Stache 9.7
    Live Free & Ride
    Reputation: NH Mtbiker's Avatar
    Will the Stache only run a 24mm crank spindle diameter? I was hoping to be able to run a 30mil crank, but not sure with the way its not completely round in the shell. I did not see a BB92 thread together unit with a 30mm spindle bearings on their site, so probably a no-go. I think I would much rather go thread together over PF any day!
    17 Fuel EX 9.9 (in progress)
    19 FM 279 carbon gravel
    17 Stache 29+
    14 GT Zaskar 100 9r
    https://kettleheadbrewing.com/
    Reputation: huckleberry hound's Avatar
    Feb 2015
    Quote Originally Posted by NH Mtbiker View Post
    For a thread together BB your choice is either 24mm or GXP Sram. The shell diameter is too small for thread together 30mm. I don't believe that there are any thread toghether DUB BBs yet. The 2019 Stache 7 and 9.7 uses Sram DUB PF which is a 28.99mm crank that is supposed to be the best of both worlds as far as weight and durabilty.
    I have used the standard Wheels Mfg. BB92 bottom bracket, not the thread together type now for a couple of years without issue.
    Change begins by doing something different.
    Live Free & Ride
    Quote Originally Posted by huckleberry hound View Post
    Good to know, thanks! I might be willing to try the new DUB interface if it does indeed fit the PF92 on the 2017 alum Stache. Guess I won't know until I pick up the BB and try it out. These have been out since Jan, so there should be some real time feedback by now I would guess. I have always favored Shimano cranks, but might be willing to move over to SRAM if it holds up long-term.
    17 Stache 29+
    14 GT Zaskar 100 9r
    Live Free & Ride
    Here is the message I sent and then received from Wheels Manufacturing, hope this helps clear things up for the Stache:
    I have a 2017 Trek Stache alumn. frameset, it is new with no existing bottom bracket. I believe it has a press fit 92 BB and wanted to see what you recommend. The Stache has a unique bb shell that protrudes inward due to the tire clearance, thus the shell is not perfectly round internally. I would like to run a 30mm spindle, either race face or another. Please advise on the correct BB for this frame.
    Wheels response:
    Hi there. here you go.
    https://wheelsmfg.com/bottom-bracket...-for-30mm.html
    Also found these on RWC-Enduroseals site:
    https://www.enduroforkseals.com/prod.../pf41/Cinch30/
    17 Stache 29+
    14 GT Zaskar 100 9r
    Feb 2015
    Harold uses the Enduro bearings. https://www.endurobearingsonline.com...ucts/bb86-4130
    You can read about his experiences here.
    http://forums.mtbr.com/drivetrain-sh...es-985030.html
  1. 2017 Stache 5 - Black with Manatou Fork
    By Sandman29 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 11-19-2017, 12:39 PM
  2. New Stache 7 or used Stache 9?
    By Lookbiker in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 01-15-2017, 07:17 PM
  3. Replies: 15
    Last Post: 12-23-2016, 08:43 PM
  4. Replies: 12
    Last Post: 11-21-2016, 08:14 PM
  5. 2016 Stache 7 or 2017 Stache 5
    By lebnjay in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 09-01-2016, 10:31 AM
Members who have read this thread: 10
