27.5x2.8 all-rounder tires?- Mtbr.com
Results 1 to 8 of 8
    Jan 2020
    Greetings. First post here! I am ditching my 3.0's in favor of 2.8's. I'm looking for a predictable tire with good grip, and fast rolling ability. I ride mostly hard/loose over hard. I think Minions are overkill for my trails. I was thinking Rekons, or XR4 front/ XR3 rear (maybe even XR4 f/r). Any opinions on these combos? Should I be looking at something else? I ride a hardtail, so ride quality is important, too. Thanks for any suggestions.
    Sep 2019
    I'm interested to hear what others advise.
    I've just got back into MTB after a 20 year hiatus and am on a Trek Roscoe 8 that came stock with 2.8 Schwalbe Rocket Rons. They've been fine for the local loose over hardpack and rock gardens. Been having fun on berms, jumps and drops with them.as well.
    At 16 psi front and 18 psi rear I've had enough grip so far and also relatively comfortable (for a hardtail with only 120mm travel. However in really steep stuff they feel close to breaking loose and now I'm getting a lot faster and traveling to more intense trails overseas I'm looking for a more aggressive set of tires with better grip, especially on the front...
    Sent from my SM-N960F using Tapatalk
    Mar 2017
    I have a SC Chameleon that I run 27.5x2.8 tires and for all but the muddiest times of the year I run the Rekons FR & RR. Great tire for almost all conditions. Lots of folks like the Bonti's to but I can't speak to them.
    I run the 3C compound on both ends because of the rocks and roots in SWPa and do not feel any rolling resistance. If you would like a bit more speed you could use a dual compound on the rear.
    I don't think you could go wrong with either combo from what I've read on the Bonti's but I prefer the Reckons.
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    Quote Originally Posted by Slowandfat View Post
    Rocket Ron, XR2 are a couple good choices where aggressive tread is not necessary. Either will roll fast and efficiently. I have two bikes that wear the RR liteskin tires and the ride quality is very nice. If more durability is in order, snakeskin or XR2.
    The XR4/3 could be a great combo too.
    I'm not ready to ditch 3.0 at this point since the size works better for the places I frequent.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    WTB Ranger or Terravail Coronado. XR2 is a great expensive option.
    Reputation: vikb's Avatar
    Rekon 2.8" front & rear or DHF 2.8" front and Rekon 2.8" rear. Both good choices. The DHF up front doesn't slow you down much and really adds a lot of traction in the turns, but dual Rekons are good if the need for speed is more important.
    Safe riding,
    Vik
    www.vikapproved.com
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Bulldozers.
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    Mine came with 3.0 and NobbyNics but the 2.8 should be available for RocketRon.
    I like my newer rear that is RocketRon and will do the front when it needs to be changed.
    A tad bit tighter knobby surface than NN, not super deep and smooth, fast roller with traction when you need the bite.
    The old Tsali from Performance was a good one too , similar to the small block tread but not sure of size options. Running 2.2 on my old 26'rs
    "Before you criticize, you should walk a mile in their shoes. You'll be a mile away from them and you have their shoes"
  1. Constant flats! 27.5x2.1 replace 27.5x2.25?
    By scutchins in forum Wheels and Tires
    Last Post: 10-01-2019, 07:40 AM
  2. 27.5X2.4 vs. 27.5X2.8?
    By askibum02 in forum Wheels and Tires
    Last Post: 04-24-2018, 07:21 AM
  3. tallest knobs on a 27.5x2.4/2.5 tire, for a 29/27.5 (b9er) project?
    By phoenixbikes in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 06-27-2017, 05:31 AM
  4. New Ibis Mojo 3: 27.5x2.8 inside 27.5 frames?
    By natzoo in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 03-17-2016, 06:47 AM
  5. opinions on all rounder tires for my CC
    By lukehooligan in forum Surly
    Last Post: 02-03-2013, 11:28 AM
Members who have read this thread: 94
