    Hi!!!
    Reputation: BelaySlave's Avatar
    New question here. Are Yeti's bearings proprietary?
    http://www.yeticycles.com/Store/Deta...45&category=11
    Does anyone know if these bearings are specific to Yeti or are they common type of bearings? The reason I ask is because probably in the "off-season" I will end up getting the suspension bearings replaced and I was wondering if I should just order them from Yeti or hope that the LBS (www.CustomMtnCycles.com) will have bearings that will work on the 575.
    Nick
    EDIT
    Looks like I can get these from EnduroForkSeals.com.
    Idaho Biking Yahoo! Group
    Support these shops: www.CustomMtnCycles.com & Reed's Cycle
    Reputation: flipnidaho's Avatar
    if...
    you're going to be off the Yeti for a while in the off season, take it to Reeds and have them put the new bearings in. They should have the Yeti bearings in stock.
    Reputation: Egika's Avatar
    Interesting question...
    I would like toknow this as well since I have a lot of different bearings on stock at work...
    So, again: Are they some kind of standard? Which size?
    Thanks,
    Egika
    trail "cleaner"
    I'm pretty sure you can find them here
