Page 1 of 3 123 LastLast
Results 1 to 100 of 215
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Yeti, are you listening!
    Seems like every other thing I read regarding Yeti bikes these days is about folks scrambling to locate and buy a 66 before it's too late. People are driving hours across state, making phone calls to online dealers and scouring the webbernet in search of the last remaining stock of what quickly is becoming an iconic bike for you guys. I bet the R&D on this bike lasted nearly as long as the production run itself, and in such a short time the 66 has been praised from every spectrum of the MTB community. From reviewers to demo'ers to owners, this bike has received almost ubiquitous praise. Why oh why must the end come so quickly? Just as I was contemplating moving on from 3 generations of 575 ownership....whoosh, GONE.
    There had better be something special in the works to justify a replacement, and if I know you guys at Yeti, then there certainly is
    ...can't wait
    Reputation: Just J's Avatar
    Feb 2005
    I know that Yeti have been pretty vocal on the speculated demise of the SB66, they have stated on these very pages that the bike just wasn't selling in great enough numbers to warrant a further production run and if that changed then they would consider re-running production on the frames. I think what you are witnessing on the internet is people scrambling about trying to find close out frames with huge discount prices which is fair enough in my book.
    I'm pretty sad to see the SB66 go, it'd be nice if Yeti could keep it in their product line but times they are a changing, I guess. I know that if I had the spare readies, I'd be putting one in my garage, and I also know where I can get the perfect 66c in my fave colour combo. We shall see how that one pans out though...
    Fix foot pain, gain skills you forgot you had and have more fun whilst doing it!
    http://www.mcssl.com/app/?af=1681397
    Reputation: bpnic's Avatar
    Aug 2005
    Lets start a wish list thread for it's replacement.
    27.5
    Carbon from the start (with aluminum released just behind)
    160mm
    NO Fox 34! PIKE, PIKE PIKE!
    1 x 10
    <17" chainstays
    67 degree HA
    13.5" bb height
    low and semi long TT ( sb66 was .5" too long)
    Standard or Direct mount rear derailleur option
    ISCG-05 tabs
    Stealth and external dropper cable routing
    73mm threaded bb
    142 rear
    I'd hit it, but I bruise like a peach.
    Long live the ASR-7
    Reputation: Doba's Avatar
    Nov 2008
    What happened to the Rockshocks spec bikes? I'd love to see a Yeti from the factory with a Pike up front.
    Aug 2005
    Quote Originally Posted by Doba View Post
    +1!
    Reputation: Dogboy's Avatar
    My wish list would be pretty short.
    Geometry the same with the exception of a slightly steeper seat angle - this would reduce the effective TT a little but Reach would remain the same.
    Same travel.
    Stealth dropper routing.
    DLd
    DLd is offline
    Feb 2005
    Re: Yeti, are you listening!
    Quote Originally Posted by Dogboy View Post
    Same travel.
    +1. Ended up having to slide the seat way forward to put the power down. Otherwise, carbon, 27.5, and through some sort of black magic, a water bottle cage in the front triangle. Pike stock on a 1x11 build would be nice.
    Sent from my HTC One using Tapatalk
    Fall is here. Woo-hoo!
    Reputation: ciocc's Avatar
    Dec 2005
    Not necessarily true and it depends whether or not your setup is optimized for climbing. A steeper seat angle will increase the ETT if you want to maintain the same "knee over the pedal axle" position. It is because when the angle is steep, it will put your knee in front of the axle. You will need to use an offset seatpost or slide the saddle back in order to achieve that optimal position. As a result the ETT will be longer. Similarly, a slacker seat tube angle will reduce the ETT.
    Int'l Sales - PIVOT
    Reputation: John P.'s Avatar
    Yes, we're listening. In response to your concern that we're retiring a bike at the peak of it's popularity, our actual sales numbers contrast all the anecdotal evidence pretty sharply. For much more on this, please read my posts here:
    Ode to the ASR-5 (Post #5)
    and here:
    No more 66 from Yeti... (Post #62)
    We're working on tons of new bikes right now, and as always, some will make it to production, and some will only make it to the Team or prototyping stage (the 303WC Carbon is the most recent example).
    Thanks for all your input and interest in Yeti. Please rest assured your voices are heard.
    JP
    PIVOT Cycles
    Please Email rather than PM: johnp AT pivotcycles DOT com
    Instagram: @heyjohnp
    Quote Originally Posted by ciocc View Post
    Yes, absolutely true. I shouldn't have to qualify my statement with "all things being equal", but of course that is implied. I wouldn't ever be using an offset seatpost to achieve a knee-over-pedal-spindle "optimal" fit position that is almost entirely irrelevant to proper mountain biking.
    Reputation: terrible's Avatar
    I think we are going to see a more 66-ish 650b in the future. I also think it will still be aluminum. At least until the sales show a need or demand for a carbon version.
    After riding a 75 and a 66 I don't see why a "sb76" wouldn't sell like crazy. It could be even more of a do it all bike than a 66 already is.
    My only personal wants are:
    13.5"+ bottom bracket
    good cable routing (nothing inside the frame anywhere)
    no frame/tire contact
    integrated down tube guards for mud/rock protection (make it optional)
    No matter what I'm sure whatever comes after the 66 will be just as good if not better. We may have to get used to the "bigger" wheel but it isn't like the 650 is huge compared to the 26. I've only got a couple rides on a 650 so I'm no expert but I don't have a problem with making one my next bike.
    "I'm the fastest of the slow guys"
    Chilling out
    Reputation: bear's Avatar
    IMO, don't look for major RockShox stuff happening *at the same price/performance points* as the leading Fox stuff unless Yeti and Fox part ways, team-wise.
    EDR
    Jun 2005
    Quote Originally Posted by John P. View Post
    Yes, we're listening. In response to your concern that we're retiring a bike at the peak of it's popularity, our actual sales numbers contrast all the anecdotal evidence pretty sharply..
    JP
    Thanks for chiming in JP. My post was more of a rhetorical question and I didn't fully expect you to reply.
    I'm also fully aware of why the bike is being retired. I don't live in a shell and I realize that things that don't sell aren't going to stick around. Your sales numbers punctuate my point. Super great bikes, across many manufacturers, are going to be sent to the trash bin simply because of the new wave of wheel sizes. My post was more of an emotional plea, and an expression of my sadness that such good bikes will be retired simply because of the new fashion in frame sizes. So many people will never know what they're missing. At the same time I remain optimistic about the future of mountain bike design.
    Take care, can't wait to see what types of bikes will be coming out over the next two to four years.
    Dec 2005
    I know what you are saying and that's why I said it depends ... If one sits on the saddle the majority of the time (like XC), my theory holds true. Nevertheless, IMHO, reach is a more important factor than ETT in choosing an AM bike.
    DLd
    DLd is offline
    Feb 2005
    Well, no. The ETT is simply a measurement of the bike horizontally from the center top of the head tube to the center of the seat tube. Certainly if the seat tube angle was too steep you would slide your seat back to accomodate and vice versa. This would in no way change the ETT as you're not cutting tubes and rewelding the frame. What he was saying was that if they made the seat tube angle steeper, maintaining the same reach, the ETT as measured would be shorter, and you wouldn't have to slide the seat forward as much as you have to with a slacker seat angle. Anyway, for the same reach, a slacker seat tube results in a longer ETT, and a steeper seat tube results in a shorter ETT. This is why if you're comparing bikes by ETT you have to also look at the seat tube angle. Otherwise you may look at a bike thinking it has a nice long ETT, when in reality it just has a really slack seat tube angle, and by the time you slide the seat forward into a useful position the bike feels short and cramped. Not trying to be a stickler. I just wouldn't want people to think it worked the wrong way and order the wrong size bike based on that.
    It's interesting that Yeti is discontinuing a bike that had such great success under Graves in the EWS. I watched a recent interview with him and when he was asked if he was going to change wheel sizes for this years EWS, he said "no".
    EDR
    Jun 2005
    Quote Originally Posted by Squib38 View Post
    It's interesting that Yeti is discontinuing a bike that had such great success".
    Great success is all relative. It's like a movie or a TV show that gets great critical acclaim but nobody watches it so its cut after season or two. It's a shame.
    Dec 2005
    Quote Originally Posted by DLd View Post
    Fair. My definition (apparently is different from everyone else, so my bad) of the horizontal distance between the center top of the head tube to the center of the seat tube is called Virtual Top Tube.
    I was just saying the same thing. Thanks for explaining in detail.
    Int'l Sales - PIVOT
    Quote Originally Posted by eatdrinkride View Post
    Graves and the rest of our Enduro riders will be on the 66C for most or all of the 2014 season.
    PIVOT Cycles
    Reputation: Swissam's Avatar
    I think the biggest problem is not the new wave of wheel sizes, it's the price point. People just don't want to pay $6k for a bike in today's unstable world economy. Here in Switzerland we live in an economic bubble with some of the best wages of anywhere in the world yet all you see out on the trails are Canyon and YT bikes. People just don't want to pay that much for a bike. Period.
    DLd
    DLd is offline
    Feb 2005
    From what I heard it wasn't just relatively low numbers. The number was more like zero for both 66a and 66c orders from dealers, and they had to decide whether to do another production run or not. I still may try to find a large. I just got an ARC carbon and I'm pretty happy with it. A 66 would cover all my bases for anything more than xc.
    It was 12. There where only a dozen orders for the 26" super bike.
    DLd
    DLd is offline
    Feb 2005
    Quote Originally Posted by terrible View Post
    Sad face. Awesome bike. The fact that they're going all in on Enduro on a bike they're not even making anymore makes it seem like this was a decision they weren't ready for and didn't want to make. Maybe increased demand from a good enduro showing will lead to a resurrection?
    EDR
    Jun 2005
    I don't think the Enduro season will make one bit of difference one way or the other. The general public pays no attention to racing. Heck, I am an avid mountain biker and I pay no attention.
    Feb 2005
    Graves came 2nd in the Enduro World Series and 3rd in the DH World Champs on what was essentially the same bike, if that wasn't good enough showing then I don't know what would be? 26" is dead, that's an absolute fact, I'm just excited to see the SB76c which will happen as a result of all of this.
    Chilling out
    JJ, it isn't that the bike doesn't show well, it's that the lemmings are being told 26 is dead and the listen because they have no brain cells of their own.
    It's the same problem that kept 29ers a fad for ten years.
    Oh, wait, 29ers are *still* just a fad.
    Feb 2005
    Quote Originally Posted by bear View Post
    OK maybe me saying they're dead was a poor choice of words, but as far as new 26" bikes being launched, well that's just not happening. As I say, I'd love a '66, I'm definitely not an elitist wheel size fascist or a "lemming" come to mention it!
    DLd
    DLd is offline
    Feb 2005
    Quote Originally Posted by Just J View Post
    I like lemmings. With a little bit of Sriracha sauce, they're delicious!
    What about the evil uprising? New 26 inch and a strong candidate for bike of the year. I'd be interested to know how the 650b bikes are selling. I don't have any hard numbers but from what my LBS says they are not selling as well as they hoped. They also have a top range SC Bronson that has sat in the window for almost a whole year now. Even at 20% off no one is buying it.
    Feb 2005
    Quote Originally Posted by Swissam View Post
    Interesting, yes the Uprising is a very good 26" but it's not a high volume seller, I wonder how well the Trek Fuel 26" still sells, that would give a much better indication I'm betting...
    Int'l Sales - PIVOT
    Not a knock on Evil at all (hell, I literally founded the company!), but I wonder how many they're selling? I sincerely hope it's a lot, because that company is my baby.
    SB75's and 575's are each selling more than 50:1 over the 66.
    I've got no agenda here, guys. A year and a half ago, you could not find a bigger advocate of 26ers than me, and I'm still in love with my 66C. I'm just trying to give you hard data and facts.
    JP
    PIVOT Cycles
    50:1! Ouch, that is very surprising. Not to complicate things further...but I often wonder about the role of the consumer here. Bike shops place orders...consumers more or less have to buy what's offered. So even if they want that 26, they are forced to go 27.5. I find with the 27.5 movement, the companies are driving demand more than consumers (although this is always the case to some degree, just more pronounced in this case).
    I frankly don't really mind one way or the other. I don't see 27.5 as all that different, so it's quite a bit different from having to make the move from 26 to 29.
    EDR
    Jun 2005
    Quote Originally Posted by chunkylover53 View Post
    I agree. I do not see 27.5 as all that different from 26. Which makes it all that more frustrating. Change for the sake of change. Change for the sake of taking more of the consumers dollars. My $800 Lyrik fork is now useless on a new bike. My wheels tires, useless.
    Feb 2005
    JP
    We appreciate it, as ever John, I don't think there are many companies willing to give such an honest appraisal of what's happening in the market at the moment. Thank you
    Int'l Sales - PIVOT
    Quote Originally Posted by manbat View Post
    Bike companys probably don't like the idea of someone going out and just buying a frame to go with all the 26" gear they already have lying around...
    I've written this about a dozen times in other threads, but the thing that many people are failing to realize here is that this is a market-driven business. Do you think we like the staggering thought of blowing through piles of inventory and completely redesigning every bike we make to accommodate a new wheel size? Hell no. It's much easier to just tweak what we have and use the knowledge that we've already gained about 26ers and roll with that.
    But if there's almost zero demand for a product, how do you guys propose we sell it and stay in business?
    A lot of people are quick to chime in and claim there's some sort of grand conspiracy going on here to squeeze every last dollar out of your wallets, but here's the dirty little secret: there's no one smart enough in the bike industry to orchestrate something like that. Seriously. I've been in the business for 14 or 15 years now, worked with some brilliant people, and have tons of respect for my peers and colleagues. That being said, I haven't met any one person (much less a group of people) who could force feed you guys this stuff if there was just no demand for it.
    If you don't believe me, stop past your local shop and ask them how easy it is to basically clear out tons of inventory to make room for a new standard. You'll hear the same thing.
    At the end of the day, 27.5 has come about because there's massive consumer demand for it . . . and for good reason - properly designed 27.5 bikes are crazy fast and tons of fun to ride.
    JP
    PIVOT Cycles
    EDR
    Jun 2005
    JP
    JP, speaking for myself I personally think you're misreading my posts. I realize it's a market-driven business, that's what's so frustrating. The market is being moved towards a new style of bike for no apparent reason. I do not blame Yeti or any other manufacturer for this. Its marketing, it's what the new people to the sport are told they want .. They think that 26rs are out of date. I totally understand why what is happening is happening. Hence, all the frustration.
    I understand the market and why what is happening is happening. I've read all of your post's at one time or another I'm sure. If I was a fly on the
    The wall at Yeti meetings over at headquarters I bet I'd hear a lot about how this is a tough transition for you folks as well. The change feels like it's being forced upon all of us whether we like it or not. This includes the manufactures and the buyers.
    Aug 2005
    I'm sticking with this ripper.
    Attached Thumbnails Attached Thumbnails Yeti, are you listening!-win_20131227_155654.jpg
    Reputation: viteaux's Avatar
    Oct 2007
    I would tend to disagree. I don't believe there is some bicycle illuminati, the editors of Mountain Bike Action, the CEO of Specialized and the moderators of Pinkbike all in collusion, using Jedi mind tricks to force us to buy stuff. The only constant in mountain biking is change. Manufacturers are only going to make what consumers are going to buy, or they go out of business. I love my sb66, and bought it after demoing it, a 75 and a 95.
    I think it is so cool that we can even have this dialog amongst ourselves and a Yeti executive!
    Reputation: reformed roadie's Avatar
    Where are you? The shop near me that carriers SC is selling Bronson's like hot cakes.
    JP
    John, I literally am joining the tribe today, as my 575 is due to arrive by day's end.
    I am on here and Pinkbike a bit (too much, esp. since the weather is not cooperating at all this winter.)
    I still blows my mind that people have this notion there is some sort of conspiracy within the industry to make a change and force consumers to buy something they don't want.
    To back up what you said, someone on PB did some research to prove someone wrong about this and instead found sales numbers that backed it up: 29ers up 100%, 26" down 20%. This is not the industry forcing anything, it is consumers speaking with their money. (I think it was Rocky Mt. sales numbers)
    Personally, I have been riding a 650b converted Blur LT and Nickel for over 3 years. On occasion i have ridden both bikes with 26" wheels again and there is no question the 650b offers a better ride.
    I am sure most of the people crying about this have never ridden one.
    I am also curious if they were crying when tapered forks made straight steerer frames obsolete, just as disc brake made post mount only frames obsolete before them...
    EDR
    Jun 2005
    Nobody's crying. The vast majority of us are long time riders and long time Yeti owners. We're having adult discussion about the recent change within the industry, and how it makes me personally a little bit bummed.
    Welcome to the tribe!
    Ok no one's crying.
    But can you explain to me who is forcing this on everyone? I am with viteaux: there is no illuminati, conspiracy, collusion or anything like that going onů
    I have been riding since '86 - when bikes were total crap by today's standards.
    Things have been evolving since then, some times incrementally, some times dramatically.
    Oct 2011
    RR, I think the vast majority of people upset by the 66 going away are owners who know what everyone else is missing. It makes many reactionary when something we feel is so good is not wanted anymore by the new bike customers. Many people that are in the market for a "new" bike unfortunately want what is new and hot and that is 650b right now. Those of us that ride a 66 or 66C know that it is the geometry and the linear/rising/linear suspension that is the magic and 650 wheels are only going to improve that bike marginally. The 95 is a great option for maximum roll over and best of 29er traits in a classic Yeti package and between the 66 and 95 there is not much room for improvement. I appreciate that Yeti evaluates the market and only brings out bikes that fit their culture. That said I am not sure the 75 is what people think it is, certainly not a 650 version of the 66. I am sure that will come but for now it is my 66C/ARC C/575 650 that will cover the bases.
    Single Track Addict
    Reputation: bulletboy's Avatar
    Sep 2004
    Quote Originally Posted by reformed roadie View Post
    Ok no one's crying.
    Maybe it's aliens?
    Will ride singletrack for food...
    Quote Originally Posted by bulletboy View Post
    Maybe it's aliens?
    clearly...
    Quote Originally Posted by Tinsley1 View Post
    I hear you. I agree, the "problem" is that the SB75 is not what people think it would be, a smaller wheeled version of the 95, rather than a larger wheeled 66.
    In some respects, I can understand, as Santa Cruz suddenly discontinued the APP bikes (Nickel and Butcher) that I was a big fan of. Ironically, I think that design may be the way to make a bike with more progressive geometry that the Bronson lacks due to constraints of the VPP design. ( sorry for the tangent, I know this is a Yeti forum)
    I have to believe they are working on a SB76 that will be as good or better than the 66.
    Reputation: SicBith's Avatar
    JP
    Certainly that is due to the walls broken down by 29ers. It made the decision to buy a 27.5 easy for me as a customer so the dealers are going to give the people what they want. The hard part was finding out Yeti chose to slot the 27.5 575 where IMO a SB bike would take market share from companies which are already there (Santa Cruz, Rocky Mtn, Pivot) 575 is again IMO settling, not leading a trend like the SB66 and SB95 did when they were introduced. I know that sounds harsh, but I've supported this brand since Volant owned them and it bums me out to see Yeti settle or worse introduce something in April which their dealers won't be able to sell until July.
    you can get passed a dog... nobody fuks with a lion
    Mar 2006
    What I can't figure out is how an entire company that prefers 26inch versions of theirs bikes (lunch time ride) can be so unanimously wrong about which bike to ride given the option.
    I personally think John is right, most of the buying public is probably demanding the 650. We are a popcorn society that is easily influenced by the latest shiny object. How can something so new, so quickly obsolete a wheel size that has been around for so long?????
    Feb 2012
    Quote Originally Posted by SicBith View Post
    Why is it settling for yeti to take a tried and true design (the 575) and apply it to the new wheel size?
    575 is a great bike design...I've owned two of them, and still ride one occasionally But if I'm going to bring out a high end trail bike with 6" of suspension my choice would not be a single pivot. The design has great merits, but technological it is being out paced by other suspension designs (SB as an example) which deal with pedal bob, absorbing terrain while braking, influence of pedaling on suspension and other issues which come with single pivot bikes.
    BANG!! That's the sound of a hammer hitting a nail on its head.
    EDR
    Jun 2005
    That very well may be. I personally have never thrown a leg over one and I started this thread.
    When I had a warranty replacement for my 2008 575 I tried to get Yeti to let me upgrade to a SB 66. This was 2012 and at that time that bike was so hot they couldn't fulfill my request. So I opted to upgrade to a 2012 complete new 575 frame but I really wanted to move to a 66.
    Like I've said before, I have no doubt that Yeti will come out with some fantastic 27.5inch bikes for us to ride. I'm just slow to accept change, especially when it seems like it happens overnight.
    My ONLY issue with 27.5 is that I have no spare parts, forks, rims, tires, spokes. And with forks being almost $1K it's a tough change to make.
    We do have an sb75 in the house and it is a good bike but it isn't meant to be like a 66.
    It must do something if most WC DH teams are going to 650b, or at least experimenting with it.
    RE: increasing sales profit, what does being stuck with unwanted inventory do to a company's bottom line?
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Pray tell, who exactly is doing all the marketing?
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    DLd
    DLd is offline
    Feb 2005
    Quote Originally Posted by Berkley View Post
    Marketers!
    Reputation: MTT77's Avatar
    Aug 2010
    I know everyone is sad to see the 66 go away. But look on the bright side -- now when you roll up to the trailhead, and guys see you on your 66, they'll be like "Oh man, you got the 66! Lucky b@stard."
    I swear, everyone was scooping up the closeouts here. On our last big ride I think we saw at least 4 SB66Cs, counting the two my friend and I ride. And we don't have a Yeti dealer. my friend is having a heck of a time selling his SB66A, I think if he wants to sell it he'll have to take a big loss.
    Quote Originally Posted by MTT77 View Post
    JP
    John,
    This phenomenon of 26 vs 27.5/29 debate is growing tiresome and troubling at the same time.
    I am still assembing my XLSB66C so I have no riding comparison yet. Just the knowledge that in testing the wheel sizes, I preferred 26". The Long TT of the Yeti 66 geo was a MAJOR selling point for me.
    The lack of sales is indicative of the insanity of the digital media driving trends and fads at speeds never seen before.
    I see no advantage to 27.5 when making a objective comparison for the riding I do. None. But the media and subsequently the mfg seem to be forced to offer only 27.5's. Very Wierd. I don't know anyone who has one. I see the 29er guys pretty regularly, but no 27.5's.I guess I will eventually out of default.
    Your sentiments echo Dave Turner's as well. (I own several Turners). The market sales shift was frightening. I was very disappointed in the discontinuation of the 5 Spot for similar reasons.
    I will continue on 26ers for the forsseable future and if the SB66C does not perform to my needs an Evil Uprising is next up on my list for sure, but wish it had as long a TT as the 66.
    vto
    vto is offline
    To Yeti, I say this...
    Please build a trail blazing SB 27.5 carbon. The SB66c came out a year too late for me.
    I have a 26" AM and a 29" cross country. I love your switch technology. Problem is I couldn't sell my DW link 26" to get the 66c without a huge loss. My money is as good as yours if you build another Holy Grail.
    Very sad, what a tremendous bike. What's even more sad is you have to look at the hot patch on the tires or model on the bike to tell if it is a 26" or 650b when you roll up to the trail head.
    To quote my riding partner, 650/27.5 is like "mid grade gas" which is generous since it's not even middle between the two sizes.
    Apr 2013
    I completely understand this a demand driven industry and it ties up to some physical factors that people are considering too when buying new bikes specially with the hefty price tags. Here are some facts, the bigger wheels go over obstacles better because of the bigger diameter, they also roll faster and less effort is needed so there will be some appeal to less experienced riders with maybe less physical condition because it will be a better option to handle the trail. There's also the intermediate riders who will prefer a 27.5" because it corners better than the 29" and it behaves almost like a 26" with all the nimbleness. Then the good old trusty 26" will always appeal to all those ridders who know how to shred in the trail and care less about the tire diameter because after all " Is not the bullet is the shooter who makes the difference" but like JP from Yeti said why keep manufacturing a bike that has a 50:1 market to the newer trends.
    I see a 27.5" incarnation of the SB-66 Carbon in the near future.
    Comments like this indicate you have no idea what you are talking about, which may explain your inability to understand Yeti's (John P.'s point). How about starting up a bike company and seeing how it goes?
    Chilling out
    Quote Originally Posted by hillharman View Post
    Must be why my favorite bike of all is my SB95, which I had to wait six months after ordering to get.
    Were I buying this year the hard choice would be carbon '95 *now* or wait to try the carbon '75 (which I assume will come out eventually).
    I really should use more emoticons to highlight my sarcasm, sorry.
    Sorry my sarcasm detector must be on the fritz.
    Chilling out
    Mine breaks quarterly.
    Cheap Chinese knock-off I got off eBay.
  67. #67
    Reputation: kragu's Avatar
    Curious to know how much Yeti (and other brands) spent marketing the 66 vs the 75 / 95. Surely there's demand for the bigger wheel sizes, but I wonder how much Yeti would put into selling an "old" bike like the 66. Seems a perfectly reasonable thing to do - to focus on marketing your newer bikes, but it had to have contributed to this 50:1 ratio.
  68. #68
    Quote Originally Posted by profro View Post
    My understanding is that dealers are organized and pushing for 27.5 so everyone has to buy new bikes. Same goes for tapered steerers. This is from a good friend who runs/owns a shop.
    27.5 is also a good way to deny that the 29 "stuff" wasn't a scam. 29 is great if you didn't grow up on a bike. Not so great if you did. But by adding 27.5 they can reasonably argue bigger is better.
    Yeti really needs to adapt a mainstream bike for non big mountain application. Riding in Colorado is the best, no doubt. But I would no it want the same bike in Co that I would here in TX. Here a sb66 would be overkill, it's too heavy for the $$ and terrain.
    The sb75 is too long in the rear end, and way too heavy. Yeti needs an SB75 frame with 130, 17" stays, a bottle mount and about a 6-6.5lb alloy frame (w/shock) and it would sell all over, not just for big mountain areas.
    Again these are my opinions, but what do I know!
    believe in yourself! I believe in you!
  69. #69
    Reputation: Andrew8404's Avatar
    Quote Originally Posted by Grizzy View Post
    Why is everyone a critic? Leave Yeti and JP alone ha ha. Yeti has a full lineup of bikes to choose from! They don't need to do anything other then make great bikes which they will do no matter what size wheel it is. Guys we are in good hands! Yeti has yet to let us down and I'm sure the next bikes will be great.
  70. #70
    Big Gulps, Alright!
    1. "Organized" is not a term I would use to describe most bicycle dealers.
    2. Your friend is not representative of the general populous. In fact, I'd dare say he's the opposite of most shop owners, who recognize that more standards means more overhead. Overhead being one of the toughest challenges as a shop owner.
  71. #71
    Quote Originally Posted by root View Post
    .. my friend is having a heck of a time selling his SB66A.
    Is it size Small in White? I'm interested.
  72. #72
    Ok no one's crying.
    There is a conspiracy and it gained traction via websites such as this and others at speeds the industry has never seen before. A fad became the defacto std overnight with almost no warning.
    26" is dead this year, it will come back.
  73. #73
    Quote Originally Posted by Andrew8404 View Post
    Dude. You clearly don't get it. That's OK. Just go ride your big heavy wheeled wagon bike and be happy.
  74. #74
    Quote Originally Posted by chasejj View Post
    Umm, I have a SB66c and have no intention with going to a bigger wheel. Clearly you don't get it. JP kudos to you for putting up with all our nonsense. I don't know how you do it!
  75. #75
    Quote Originally Posted by gamalierlozada View Post
    27,5/29 are heavier, weaker, accelerate slower, turn slower. I love how everybody now talks about how the heavier wheel rolls easier. Nonsense. It is just heavier and almost all that weight is on the outside of the wheel. This has been a bad thing forever and just because a few mfgs have decided they can ignore it does not change physics.
    29's are a legit option for a rider who wants or needs the rollover for carrying racing speed or just to feel safer in rough terrain. 27.5's are as another poster put it the equivalent of Midgrade gas for your truck. A waste of money since it is neither high octane but almost costs as much.
    This is why 26" are far from dead in the long term.
  76. #76
    Mar 2013
    I won't buy sh66 because in the future it would be very difficult to purchase wheel and suspension fork. I rode sb66, sb75 and sb95 out of these three bike I personally like the ride of sb75 and sb96. However I was disappointed that the sb75 only comes with 5" travel I was hoping to have at least 6" travel. What's wrong with yeti, how come they did not put 6" travel in sb75?
  77. #77
    That's the point - you're just looking at it from a different angle. Bike shops aren't selling bikes in the numbers they need to maintain their grotesquely oversized shops and owners lifestyles. To sell more bikes they decided 26" is obsolete. So in two years and want a new fork for 26 bike there will only be a few low cost options. Will you start thinking about a 27.5 bike then?
    So at this point, are they selling new bikes they wouldn't have otherwise?
  78. #78
    Oct 2011
    Quote Originally Posted by rave81 View Post
    Yeti did not make the SB75 to be a 650 version of the 66, it fills out their line with a nice trail bike with all the sb95 pros that will fit a smaller rider or a rider who still wants a more flickable trail bike. John P and others have mentioned this and I am sure in time a new version of the 66 will come out and blow people away as the switch system did years ago.
  79. #79
    Apr 2013
    I never said anything about heavier wheels. I said "THE BIGGER WHEELS GO OVER OBSTACLES BETTER BECAUSE OF THE BIGGER DIAMETER" (ROLLOVER)
    I currently ride a 27.5" (Bronson C) and was thinkering the idea of getting a Yeti 575 26" to build it as an all out cross country bike even when i know most of the XC crowd rides 29" but I'm sure I can smoke their asses up hill, in the corners and even maybe downhill depending on the terrain!
  80. #80
    The Fastest of Bananas
    Reputation: FastBanana's Avatar
    Aug 2013
    Physics much? They do rollover terrain better. I like 26", but its not like 29 has no advantages.
    Sent from my LG-LS995 using Tapatalk
  81. #81
    Quote Originally Posted by kragu View Post
    Yeti spent a considerable amount of marketing effort on the SB66 when it was released because it was their first Switch bike and a major change for the company. They also promoted the SB95 (albeit a little differently because the Switch story had already been explained). They really haven't promoted the SB75 in a similar fashion. It's been covered in a few magazine reviews, but there hasn't been a targeted edit created for it and its spot on their site is pretty basic - a few pictures and standard spec stuff. Contrary to the rife tinfoil hat speculation on this thread, the demand from the retail/consumer perspective is simply there and hasn't been "drummed up" artificially by Yeti.
  82. #82
    Int'l Sales - PIVOT
    Guys-
    Lots of interesting opinions in here, and we welcome them all.
    Just a quick note on our marketing - it's pretty rare that we spend much time or marketing dollars promoting any one model. Instead, we tend to promote our unique technologies and our brand as a whole through things like the race team, web features (Lunch Ride, etc.), and Tribe Gatherings. We feel that once people can relate to our brand and what we're about, you all are smart enough to take a look at our line and decide which bike is best-suited to your style of riding.
    And if we don't make something that's up your alley, that's cool too. We always hate to lose customers to other brands, but we'd honestly be happier with you on another bike than on a Yeti you aren't in love with. Our theory is that we're constantly evolving, and if we don't make something now that you like, chances are we'll have a bike sometime soon that you can't live without. Over the long run, that sort of passion builds stronger relationships with our customers.
    JP
    PIVOT Cycles
  83. #83
    Apr 2013
    Pretty straight forward answer! I appreciate your sincerity sir. I will be great if some other companies will take some time hearing their customers and interacting like you are currently doing. Kudos to you and Yeti!!
    Guys-
    JP
  84. #84
    Jan 2014
    JP[/QUOTE]
    On that note... are there any SB75 reviews worth mentioning? I've seen several that tend to compare the bike to the SB66 which I personally believe its comparing apples to oranges. I have not yet come accross a review that talks about the SB75 for what it is and not for what it isn't. In any event, I already ordered mine... I think that -at least in paper- it is a going to be a great bike for me!
  85. #85
    Reputation: 8 1/2's Avatar
    Exactly! If you for example compare Yeti to Santa Cruz, you see that Yeti's got SB75 and SC has Solo as a 125mm trail bike. Yeti brings the SB76(?) , SC has Bronson (150 mm bike)
  86. #86
    Aug 2013
    I second the Yeti SB76. It would most likely be my next bike if they make it.
  87. #87
    Reputation: Joules's Avatar
    I've come to soften my anti 650 stance a little; I still see no advantage to the *slightly* bigger size, I still can't tell a difference between it and 26 on bikes I've ridden, but I don't think it's a disadvantage worth mentioning either.
    When the 66s went on crazy sale I was thinking about getting one and moving parts from my 575, when I realized I'd have to buy at least a new rear wheel (for the thru axle) and fork. Well, there went my rational for preferring 26: that all my old parts were now obsolete, they are anyway.
    I'm not going to run out and get a 75 or any other 650 bike any time soon, but please Yeti, the top tubes are way too short. Please fix this before I'm ready for a new bike in 1-1 1/2 years The geometry of the 66 was just about perfect... I guess 650 makes you shorter?
  88. #88
    Feb 2012
    Quote Originally Posted by 8 1/2 View Post
    New SC Heckler = New Yeti 575
    Both proven single pivot designs with approximately 6" of travel redesigned around 27.5 wheels and with similar price points.
  89. #89
    Aug 2010
    Quote Originally Posted by Joules View Post
    Why do you have to buy a new wheel? Lots of hubs are convertible, and if yours is not, then all you really need is a new hub. And why a new fork? You can run a straight steer tube on a tapered headtube, you just need the right headset (which you'd probably need anyway).
    26" parts are not obsolete -- there is still a market for them. Oh, and because of this line of thinking, there are a ton of great 26" parts available used from people who have jumped on the 650 bandwagon
  90. #90
    Yeti let themselves down making a 5" 27.5 trail bike. It's not even in the travel ball park with its competitors and it's heavier. There is something else coming soon. JP didn't like it when I said the SB75 is a band aid to get them through this year. They know what the SB75 is and isn't. Hopefully they will come with what the market is asking for. Yeti sold the SB75 in well, but I know a few bike shops which are worried about selling it out.
  91. #91
    you're not gonna smoke a SB95 up a hill on a post 2009 575. The SB95 will be half way through a blu** when you get up there. Climbing on the newer 575 was never a strong suit. Corners yes, downhill maybe, climbing....no way.
  92. #92
    Really? Really????
  93. #93
    Aug 2005
    I'm not sure who's has the pleasure of spending quality time on all three wheel sizes, but I was lucky enough to have. I've always been a 26" guy, as in like the last 15 years. I spent two plus seasons aboard a sb66 and loved it 99% of the time. I also spend a riding season on each a Mojo HD 27.5 and an Sb95. All three bikes were built similarly with a 150mm fork.
    I know this is all relative, but I can honestly say without a shadow of a doubt, that the 95 is the fastest bike (for me, and I'm 5'10" tall) in almost every category, at least every important one. This includes everything from long uncomfortable climbs to shuttle runs at the mountain.
    The 27.5 was my least favorite, and that says something, because the Mojo HD is one hell of a bike. I just found it combined the crappier traits of each wheel size, not so much the best.
    Just a humble opinion here guys, but I hope it helps someone choose.
    BTW, Backcountry has Sb66a frames in most colors and sizes due to what looks like a new delivery.... and they're still on sale. And still collecting dust. Crazy, cause it'll always be a killer ride.
  94. #94
    Really? Really????
    Agreed. Crazy talk.
  95. #95
    Reputation: ridetheridge's Avatar
    Well, this will be quite interesting to watch. I've never seen so much "luke warm" welcome to a bike from Yeti as I have on the SB75 on this forum ! There are a lot of knowledgeable people on this forum.. that have definitely helped me out with past decisions, so I definitely respect everyone's opinions. However, sometimes I wonder if this forum is really an indication of the general public. I would have to say, maybe not ? Couple of examples that make me question this are; SB66 has nothing but praise on this forum, but according to Yeti.. had about zero demand. Also, as much talk as here is on this forum on carbon SB95 and carbon bikes in general, you would think everyone "owns a carbon bike". The reality is, when I go riding (and I ride in a very popular mountain biking area here in CO), I rarely see a carbon frame. Maybe 1 in ten if that much. When I go to my LBS here who is a primary seller of Yeti bikes, their best seller was the entry level SB95. The reality is most people cannot afford or want to spend $5K or more on a bike. Interestingly, the price point on the entry level SB75 is $2900. So, for less than $3K you can get a good all around bike. If the "general" public buys into this, then it will be a hot seller. But it will be the "general public", IMO that will make or break this bike. I personally believe the demise of the SB66 occurred because of it's unfortunate introduction smack in the middle of the 27.5 and 29er movement.
    As a side note on the SB75, I'm wondering if people that have ridden all three maybe have certain expectations that are not met. For example, if you ride the SB75 and expecting the rollover capability of the 95, it wont' happen. At the same time you might be expecting the nimbleness of the SB66ů that wont' happen either. So I can definitely understand individuals not pleased with it (I may very well be in the camp as well). On the other hand, if the expectations are "Does it have a bit more rollover capability that the SB66 ?" Probably yes. "Is it more nimble than the 95 ?" Probably yes. In that case, the individual may walk away with a more favorable opinion. So, in essence it might have a lot to do with one's "expectations" going in.
    Anyway... interesting discussion.
    The Mtn Bike App --> http://mtbphotoz.com
  96. #96
    Aug 2005
    I purchased and spent time on the three bikes in this order. Sb66a, Mojo HD 27.5, Sb95a.
    I spent most of my time on the 66, followed by the HD 27.5. I figured I'd love the 27.5 HD, but just didn't. It felt slower than my 66 with almost no perceivable help in the rollover department over the 66.
    I then built a Sb95a (without ever riding a 29er) and was blown away. Wide bars and rims + a new Pike 150 have dialed it right in.
  97. #97
    Feb 2014
    Those of us on enthusiast forums (for anything, cars, stereos, bikes, games) are never a representation of the general public.
    This is an itty-bitty niche, relatively speaking. Companies survive on average Joe Consumer buying their "normal" less expensive stuff day in and day out, not the rare big purchase from people like us.
    Making a dollar a hundred times is always more than making fifty one time.
  98. #98
    Quote Originally Posted by bpnic View Post
    I spent most of my time on the 66, followed by the HD 27.5. I figured I'd love the 27.5 HD, but didn't. It felt slower than my 66 with literally no help in the rollover department over the 66.
    Interesting. I have simliar story in I owned a 575 and demoed a SB66. While I liked the SB66, it wasn't enough for me to sell my 575. A year later I got the chance to demo a SB95 (first 29'er for me as well). I knew immediately I wanted one. Bought it within 2 weeks. That bike is so much fun
  99. #99
    Reputation: No Name's Avatar
    I voted with my wallet and went with a 66C. As long as I can continue to buy quality rubber in 26" and can procure enough parts to handle breakage over the next 3-4 years the thought of a 27.5 or 29 won't even enter my mind.
  100. #100
    Apr 2013
    Enjoy! The SB-66 is a uber sweet ride.
  1. What are you listening to right now?
    By Hutch3637 in forum Off Camber (off topic)
    Last Post: 10-07-2017, 02:23 PM
  2. What are you listening to? V 2
    By AZ in forum Off Camber (off topic)
    Last Post: 01-04-2013, 05:19 PM
  3. what are you listening to NOW?
    By shekky in forum Off Camber (off topic)
    Last Post: 05-12-2012, 12:49 PM
  4. 10/15/10 Drinking, listening to??!!
    By bad_andy in forum Colorado - Front Range
    Last Post: 11-12-2011, 04:48 PM
  5. I'm not listening...!
    By GilaMonster in forum Arizona
    Last Post: 08-11-2011, 07:48 PM
