    Yeti AS-X rear dropouts...
    Can anybody tell me if a 10mm through axle can be used on an AS-X rear end? I'm looking at upgrading my wheelset as well as stiffen up the back side.
    Bump...
    Nobody??
    Is the AS-X that outdated?
    jddist
    should not be a problem. I believe all 10mm axle solutions out there are compatible with std quick release dropouts. 12mm will NOT work however.
