Results 1 to 2 of 2
Thread: Yeti Supension
    Yeti Supension
    What type of suspension is on the ASR and Kokopelli? Name? What are its climbing/descending characteristics? Is active under hard braking? Pedal Bob?
    Single pivot with likage actuated shock to change the leverage ratio though the travel.
    Yeti ASR, Kop and 575 are generally stiff in the initial part of the stroke followed by plush in the mid range and then ramps up at the end to prevent bottom out.
    ASR and Kop' are a bit firmer at the begining than 575.
    Chaser.
