Page 1 of 13 1 2 3 4 5 11 ... LastLast
Results 1 to 25 of 316
    Feb 2012
    Yeti SB5c Build Thread
    The "SB5c/Switch Infinty Link" thread is getting a bit jumbled, having to scan through many pages to see any builds. Besides, this bike deserves its own build thread. Hopefully everyone will re-post their builds here. So here goes:
    1st Yeti - I'm part of the tribe.
    Frame: SB5c M
    Fork: Pike 160
    Headset: Chris King
    Drivetrain: XO1
    BB: Raceface Cinch
    Cranks: Raceface Next SL
    Chainrings: Raceface Direct Mount 30t
    Brakes: Shimano XT
    Rotors: Ice Tech 180/160
    Stem: Raceface Turbine 35 (50 mm)
    Bars: Raceface Next 35
    Grips: Raceface Half Nelson
    Seatpost: Rock Shox Reverb 100 mm
    Seat: Specialized Henge Expert
    Wheels: Nox Composites Teocalli 27.5
    Hubs: Chris King
    Rubber: Specialized Butcher/Ground Control
    Pedals: Shimano XTR
    Bottle Cage: Blackburn Camber
    25.25 lbs without pedals
    Rider: 5'8" (on a good day) - 155 lbs
    Changes: dropping fork to 150 and switching out the 100 mm Reverb for a 125 mm.
    NSM
    NSM is offline
    Dec 2014
    Went with a stock X01 build. First FS bike (and my first Yeti) and figured Yeti would do a better job of spec'ing than I could.
    Great fun
    -med frame
    -thompson masterpiece post
    -fox 32 150mm
    -next sl cranks 2x
    -xx r derailleur/xo fnt
    -xo grip shift
    -easton ec70 20mm rise bar
    -syntace force 109 60mm stem
    -reynolds black label wheel set
    -f tire 2.25 racing ralph/r tire 2.1 racing ralph
    -cb egg beater 11 pedals
    -xtr m9000 brakes
    *23.06 lbs
    **Rider: height 5'8, weight 150lbs
    2015 Yeti SB5C
    Shrub1-- nice build. How do you like the XTR m9000 brakes?
    D
    Feb 2012
    NSM- Whats up with your cable routing. Seems like you have to wires going to the drive side. Yeti recommends just the dropper to the drive side. Figure something better out?
    NSM
    NSM is offline
    Dec 2014
    Dickbrown, good question. I need to look into it...
    Quote Originally Posted by Daverino View Post
    If I were to do it again I'd go for the M9020 brakes. Would like a little more power.
    2015 Yeti SB5C
    Reputation: Larsey's Avatar
    Can we add Rider Height, Weight and Stem Length to the builds? Might be helpful for future owners...Thanks
    Quote Originally Posted by Larsey View Post
    revised with height and weight.
    2015 Yeti SB5C
    Mar 2006
    Frame: SB5c med (5'8" 180#, normal proportions... I think, but I could stand to loose a few)
    Fork: Fox Factory CTD 34 140mm
    Stem: Thomson Elite X4 50mm
    Bars: Easton Haven 740mm
    Wheels: DT Swiss XM401 on DT 350 hubs
    Brakes: Shimano XT M785 180F, 160R
    Tires: HR II front, Ardent rear (Ikons are junk)
    Cranks: XT
    FD: SLX
    RD: XT
    Dropper: KS LEV Integra
    Saddle: WTB
    Grips: Yeti lock-on
    ...and MUDHUGGERS!!!
    Pretty much standard spec/not as bling as some on here. Will convert to 1x (for whatever reason LBS built it as 2x) and want to put a Pike 150 on. Wouldn't mind trying longer bars, too? On that note has anyone ridden it with a 140 then went to a 150? Would like to know if it's a significant difference?
    Good job!
    Yeti SB5c Build Thread-yeti-sb5-rear-reduced-size.jpgYeti SB5c Build Thread-yeti-sb5-front-reduced-size.jpgYeti SB5c Build Thread-yeti-sb5-side-reduced-size.jpg
    Yeti SB5C Side Medium
    Rock Shox Pike 140mm
    Renthal Bar 740mm
    Thomson 70mm Stem
    Sram XX1 Gears
    Race Face Next SL Crank
    Mavic Cross Max Enduro Wheels
    Conti Mountain Kings 2.2 Tyres
    Rock Shox Reverb Seat Post
    Bontrager Carbon rail Seat
    Hope Headset
    XTR Peddles
    25.10lbs
    Im 5' 9" and weight 180lbs
    I have had many bikes before and I'm now just starting to put in the miles as I get older and this bikes is proving to bike an amazing trail bike.
    Feb 2013
    2nd Yeti, used to have a 575 back in 2010.
    Yeti SB5C Medium (probably the first in Malaysia!
    Fox 34 Float 140mm
    Easton Haven Carbon Bar 730mm
    Thomson 60mm Stem
    Sram XX1 Groupset
    Guide RSC brakes with ICE tech rotors
    DT 350 W/XM 401 rims
    Maxxis Ardent 2.4 front, Maxxis Ikon 2.1 rear wheels
    Rock Shox Reverb Stealth Seat Post
    Yeti WTB seat
    Cane Creek 40 headset
    Xpedo Spry pedals
    Bike Weight: 26.6 pounds
    Previous bike : Small size 2013 Stumpjumper FSR Expert carbon 29er
    Rider weight: 85kg
    Rider height: 180cm
    The tires came with the bike, the Ardents are fine, but im chucking the Ikons when i have time, slipping and sliding all over the place
    1st ride today with the Yeti, its a totally different beast from my stumpy. I kinda miss my 29er that could bulldoze tru rocks the size of watermelons and 1 feet vertical drops without even feeling it.
    But the sheer accelerative power of the Yeti coupled with the ease in uphill climbs make up for it (but to be honest, im not sure its the 29 vs 27.5 diffrence or the fact that i shave off 2.5kg of weight going from the stumpy to Yeti)
    I'm looking forward to getting my SB5c in the next couple weeks. Building it up for more of an aggressive XC stance, living in the hilly part of New England. First-time tribe member:
    Medium frame in Turquoise
    RS Pike 140mm
    Stan's Crest wheels
    Ardent 2.4 front, Ardent Race 2.2 back
    XTR M-9000 Race brakes- 180mm F, 160mm R
    Race Face Turbine cinch 170mm crank with 32T ring
    X-01 1x11 drivetrain
    Thomson Elite seatpost
    Thomson stem 70mm
    Enve riser bars 740mm
    Terry Ti Fly saddle
    Time ATAC Ti/Carbon pedals
    I'm 5'9" and 150 lbs. Will post pics when it's in my possession.
    Coming from an alloy 26" Giant Anthem X, I'm sure it'll take some getting used to, but I can't wait to learn how to ride it.
    D
    The Giant Yeti Girl
    Nov 2013
    Quote Originally Posted by NSM View Post
    Great fun
    ****ing sexy!
    Stock XT build at the moment
    SB5c Medium
    Suspension: Rockshox Pike 140mm
    Headset: Cane Creek s40
    B/B: Shimano XT
    Crankset: Shimano XT 2x10
    Front Der: Shimano XT
    Rear Der: Shimano XT Shadow+
    Shifters: Shimano XT
    Cassette: Shimano XT 11-36
    Chain: Shimano XT HG-95
    Hubs F-R: Easton
    Rims: Easton Vice XLT
    Tyres: Schwalbe Evolution Racing Ralph
    Brakes: Shimano XT
    Handlebars: Easton Haven Carbon
    Stem: Easton EA70
    Grips: Yeti Lock On
    Saddle: WTB Yeti Volt Team
    Pedals: Time
    Seatpost: Easton EA70
    Height 5'8" and 160 lbs
    Attached Thumbnails Attached Thumbnails Yeti SB5c Build Thread-dsc_0010-1024x626-.jpg
    NSM
    NSM is offline
    Dec 2014
    Adding a little more specificity to my X01 build after getting a fitting. 225 in full kit and 6'1". Large frame.
    Decreased fork oil to a little over 10cc's
    Fork air pressure 110psi
    Rebound 10 clicks from full open
    Rear shock 210 psi
    Rebound 8 clicks from full open
    Rode well before. Rides really nicely now...
    Jan 2015
    Hi,
    Where did you get your 140mm pike? I only find 130 or 150mm?
    Quote Originally Posted by SUB1647 View Post
    Hi,
    FWIW, I got mine with a Pike 150mm, then purchased the air shaft to reduce the travel to 140mm. I think there are a lot of OEM 140mm Pikes out there with certain bikes, but if you get one aftermarket or purchased individually new, they come in 150mm. Not sure about the 130mm-- I suspect those are OEM as well.
    D
    Feb 2015
    Shrub 1-- Very Nice!! How do you feel with a 32 stanchions fork? is it stiff enough?
    I`m deciding between a Pike RTC3 150mm (35) and the new DT Swiss 150 OPM O.L 150mm (32)
    Regards
    Reputation: Simplemind's Avatar
    Quote Originally Posted by ugly View Post
    Just wondered how the rear Mudhugger was working? Since it moves with the rear triangle, does it flex a lot or do you notice it?
    SB5c stock w/ENVE option
    '07 575 XT
    SB95c XTR/ENVE (retired)
    SB95a Pro build (retired)
    Feb 2015
    Frame: SB5c Small | Black
    Fork: Fox 2014 Factory Series 34 TALAS 27.5 150 FIT CTD Kashima
    Brake: Shimano XT M785 Brake | 180F 160R
    Groupset: XTR M9000 1x11 w SRAM XG-1199 XX1 11 Speed Cassette 10-42T
    Crank: Race Face Cinch Turbine Cranks | 170mm | Black
    BottomBracket: Chris King
    Hub: Hope PRO 2 EVO
    Rim: ZTR Arch EX Tubeless
    Tire: Maxxis High Roller II 2.30 F| Ardent Race 2.20 R
    Pedal: Race Face Atlas | Red
    Headset: Chris King | Red
    Stem: Easton Haven 35 | 70mm | Black
    Handlebar: Easton Haven Carbon 35 | 750mm | Lo Rise | Black
    Grip: ODI Rogue Lock On | Red
    Seatpost: Thomson Elite Covert Dropper Seatpost
    Saddle: Specialized Phenom Expert Saddle
    Height 5'6" and 150 lbs
    Quote Originally Posted by Pascualo View Post
    Regards
    Yes Sir, for me plenty stiff. Not an issue.
    2015 Yeti SB5C
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    Quote Originally Posted by febe View Post
    Fork: 2014 Fox 34 CTD 27.5" Kashima 150
    Hub: Hope PRO 2 EVO
    Headset: Chris King| Red
    Pics please... would like to see how the Small frame looks like
    2013 Yeti SB-66A - Fox Float 36 RC2 160/Fox DHX2 coil - 32.3 lbs
    Feb 2015
    Quote Originally Posted by LCW View Post
    Staying in Singapore, just received the frame....
    Most parts are on the way, should be completed by end of Feb.
    Changing to XX1 cassette paring with XTR m9000 Rear Derailleur.
    Can't wait to ride it and post the complete bike pics.
    Attached Thumbnails Attached Thumbnails Yeti SB5c Build Thread-11005655_10205935325001420_1035020093_n.jpg
    LCW
    LCW is offline
    Nice! I'm liking the raw black
  1. Yeti SB-66 Build thread
    By KTMDirtFace in forum Yeti
    Last Post: 5 Days Ago, 04:05 PM
  2. Yeti SB5C / Switch Infinity
    By burndtjamb in forum Yeti
    Last Post: 6 Days Ago, 06:02 PM
  3. Yeti SB5c vs SB6c?
    By dglove in forum Yeti
    Last Post: 3 Weeks Ago, 11:54 AM
  4. Yeti SB5C vs Cannondale Trigger
    By Zatoichi in forum Yeti
    Last Post: 04-27-2015, 01:23 PM
  5. Devinci Troy vs Yeti SB5C
    By dmo in forum Devinci
    Last Post: 10-01-2014, 12:02 PM
Can't find it? Just search our site!
