Page 41 of 75 FirstFirst ... 31 37 38 39 40 41 42 43 44 45 51 ... LastLast
Results 1,001 to 1,025 of 1867
  1. #1001
    Feb 2012
    i will post them up as soon as i get my 10 post count !
  2. #1002
    Feb 2012
    Yeti SB-66A
    __________________________________________________
    Frame, Fork & Shock
    Frame: Yeti SB-66A (Large) Turquiose
    Fork: Fox 34 Float 150 FIT CTD w/Trail Adjust
    Rear Shock: Fox RP23 w/Kashima (8.5"x2.5")
    Drivetrain
    Crankset: Shimano XTR M980 175mm
    Bottom Bracket: Shimano XTR
    Chainrings: Shimano XTR 33T
    Chain: KMC X10SL Gold
    Pedals: Shimano XTR M985 Trail
    Front Derailleur: cSixx HD XC Guide
    Rear Derailleur: SRAM X0 Type2 10spd (med cage)
    Rear Shifter: SRAM X0 10x Trigger
    Cassette: Shimano XT M771 10spd (11-36T)
    Gear Cable: Jagwire L3
    Brakeset
    Brakes: Shimano XT M785
    Adapters: Shimano F180P/P2
    Rotors : Shimano XT RT86 Ice-Tech 6-Bolt 180F/160R
    Controls
    Handlebar: Azonic World Force 2" Riser
    Grip: Generic Blue Lock-on
    Stem: Thomson X4 (70 x 0o)
    Headset: Cane Creek Forty
    Saddle: WTB Rocket V Titanium
    Seat Post: Thomson Masterpiece Inline 30.9 x 350mm
    Seat Clamp: Salsa Flip-Lock 35.0
    Wheels & Tyres
    Front Rim: ZTR Flow 26" 32 Hole
    Rear Rim: ZTR Flow 26" 32 Hole
    Front Hub: Hope Pro II Evo
    Rear Hub: Hope Pro II Evo
    Spokes: DT Swiss Comp
    Skewer: Shimano XT M780
    Front Tyre: Schwalbe Hans Dampf 2.35 Evo Snakeskin TL Ready TrailStar
    Rear Tyre: Schwalbe Racing Ralph 2.10 Evo TL PaceStar
    Tubes: Stan's 35mm Valves, 25mm Rim tape and Tire Sealant
    Total weight - 13.52 kg
  3. #1003
    Feb 2012
    some more pics
    decided to run 1x
  4. #1004
    Just Ride!!!!!
    Reputation: mecam's Avatar
    Something different. Looks good.
    What psi are you running on the rear?
  5. #1005
    Feb 2012
    Quote Originally Posted by mecam View Post
    yehhh I cased that one ! lol
    run approx 32-35, but the paper thin side wall of the RR gave way in that very photo! cut it on a small sharp piece of rock and had to walk back to the car after that very photo.
    more from the day
  6. #1006
    Reputation: joel63's Avatar
    May 2012
    Adam, where did you get that protector for the down tube ? Looks different than the one Yeti sells for the carbon bike.
  7. #1007
    Reputation: adamkob32's Avatar
    Oct 2012
    Company called Rock Guardz in the UK, Rockguardz - Real Carbon Fibre MTB Rock Protectors
    It works pretty well at protecting that part of the frame. Doesn't attach with any kinds of glue or stickies either.
    --Adam
  8. #1008
    May 2012
    Quote Originally Posted by adamkob32 View Post
    --Adam
    Thanks !
  9. #1009
    May 2010
    Just recieved my chip kit and shimano axle. No instructions though and I don't want to mess it up. Anyone have a link to how to install the kit?
  10. #1010
    Quote Originally Posted by mblittle View Post
    http://www.yeticycles.com/pdf/manual...anual_SB66.pdf
    Page number 26 and 27.
  11. #1011
    Reputation: hugerooster's Avatar
    I'd be interested in hearing if you notice a big difference once you upgrade. I'm on the fence with whether to go that route myself, since it'd be $100 for the thru axle and chip kit, and then another $80 for the 142mm King axle. I also bought 2 extra 135mm QR hangers awhile back that would then be useless. At the same time I'm going to be doing some big mountain riding this summer. Anyway, some before and after impressions would be helpful.
  12. #1012
    May 2010
    Has anyone installed the 12x142 adapters on 2012 or newer Mavic Crossmax wheels? I was using the QR end caps that just pushed in by hand and when I removed those the shimano thru axle doesn't seem to need the supplied 12x142 adapters. I don't see how they are supposed to be installed bc the instructions with the wheels are complete garbage.
  13. #1013
    Oct 2012
    I'm on 12x142 with Mavic Crosstrails. I am using the red mavic spacers that came with the wheelset to get the 142mm. I think the hubs on both crosstrail and crossmax are the same.
    To be more clear the axle will foot through the wheel fine but you need the end caps ton change the wheel from 135mm to 142mm.
  14. #1014
    May 2010
    I finally figured out you have to remove the end caps (cassette must come off as well) and install the 12x142 adaptors. The problem is that the end cap on the non drive side looks like it shouldn't come off but it does pop off. I used some channel locks to get a grip on the very tip of it and wrapped it in a napkin so it wouldn't scratch. The drive side QR end cap is removed by taking off the cassette first and then using a 17mm wrench to spin it off.
    The non drive side 12x142 adapter just pushes on by hand and the drive side has threads.
  15. #1015
    Oct 2012
    Ahhh ok makes sense. That's different then my crosstrail then. Endcaps just slide on both sides and held in place by a little oring.
    --Adam
  16. #1016
    May 2010
    There was an o-ring holding the non drive side on but it was tough to get off by hand so I had to use the channel locks. It was not threaded on though, just kind of stuck. I haven't taken off the drive side yet b/c I didnt' have a cassette removal tool.
  17. #1017
    --Adam
    well, they can thank you for the endorsement, I just ordered up a guard for mine. Can't wait to get it, my downtube takes a beating.
  18. #1018
    May 2010
    At Uwharrie National Forest
  19. #1019
    Mar 2013
    Hi Jacopo
    Great looking Yeti. I'm about to build one up and I'm thinking of going with the Monarch plus & Lyrik Forks. How are yours performing, are they what you expected?
    Cheers
  20. #1020
    Reputation: Just J's Avatar
    Feb 2005
    These bikes look fantastic, was drooling over a carbon a couple of weeks back but I just can't get a test ride.
  21. #1021
    Reputation: da peach's Avatar
    I got a test ride and left as an owner...
  22. #1022
    Feb 2005
    I might have to try harder!
  23. #1023
    Reputation: socalMX's Avatar
    Picked up a large alu frame! Comes with the CTD (had one on a previous bike & liked it a lot!) and I will also be running a Ti-coiled RC4 for the rough days! Im stuck on the fork! I have a 2013 Talas 130-170 RC2, I know I know, Talas is crap! Not this one! The RC2 is a nice fork! I was the biggest Talas hater in the world but that was the crappy RLC versions! I could also go with a 34 160 CTD fork???
    I will be keeping my ASR-7 as well!!! Build should be done soon, cant wait!
  24. #1024
    IMBA south west
    Guest
    quick question - what size seatpost clamp does the SB66 (alu) frame have?
  25. #1025
    Just Ride!!!!!
    Quote Originally Posted by IMBA south west View Post
    34.9
  1. Yeti Build / Pics Thread Index
    By crisillo in forum Yeti
    Last Post: 12-14-2014, 06:19 AM
  2. Yeti 575 2010 build Sram xo build
    By britishboy in forum Yeti
    Last Post: 05-02-2011, 04:28 PM
  3. Replies: 19
    Last Post: 02-15-2009, 04:46 AM
  4. Full build pictures of Yeti SS and Yeti FR bike
    By ryan_daugherty in forum Downhill - Freeride
    Last Post: 04-22-2008, 03:23 PM
  5. Replies: 8
    Last Post: 05-13-2007, 03:52 PM
