My SB after a bit of a rebuild and respec:
Large black SB-66, bought August 2011
New pivot bearings throughout after replacing warranty recall Switch link bearings
Fox RP23 Factory Kashima Adaptive Logic Boost Valve shock with 0.6 cu in air chamber reducer. Medium rebound, medium compression, 175psi boost valve.
Chris King Inset taper headset
Bos Deville 140mm fork
Mavic Crossmax SX wheels
Front: Bontrager XR4 Team Issue TLR 2.35
Rear: Maxxis Ignitor LUST 2.3 (had lying around)
XTR M980 Trail crankset double 38/26
XTR M985 Shadow Plus RD
XTR M980 FD 2x
XTR M988 Trail brakes
XTR M980 i-spec shifters
XT cassette 11-36
RT86 Ice-Tec 203mm front rotor
RT86 Ice-Tec 180mm rear rotor
Rockshox Reverb seatpost
Selle Italia SLR Kit Carbonio Flow (had lying around)
Easton Haven 55mm stem
Easton Havoc 750mm carbon bar
Yeti lock-on grips
Nukeproof Neutron flat pedals
The Bos fork at 140mm keeps the same axle to crown as the Fox 32 150mm, so this should be rocking a 67 degree head angle. The Bos makes much more effective use of its travel than the Fox as well, so this seems to be a very good match for the back end of the SB without ending up slacker than standard.
The aim was for an ultimate trail build for UK use on the North Downs and at trail centres. I've been spending some time on a 1x10 setup on a Devinci Dixon which I like for its simplicity and security. I plan to get my fitness up so I can ride everything on a 34T or 36T single chainring but 2x10 makes sense for now.
