Page 10 of 20 FirstFirst ... 67891011121314 ... LastLast
Results 901 to 1,000 of 1925
  1. #901
    Reputation: Dazzler2409's Avatar
    Jun 2012
    good point well made
    Steed: Yeti SB-66
    Support the Air Ambulance service in your region you never know when you might need it...
  2. #902
    Quote Originally Posted by chrisv8 View Post
    Some epic builds in here, certainly put mine to shame.
    Dazzler - I managed to shear one of the Ti shock bolts, well it snapped in my street after I dropped off a kurb when testing the build out, did it up to the required torque as stated in the manual using a digital torque wrench, I just replaced the full mount/pin with a stainless one.
    Love the bike, but I get the impression i'm going to get through a lot of bearings (4x Switch and 2x upper link so far) not a problem as they are fairly cheap to buy and easy to fit but still a bit of a pain on a frame with a couple of grand price tag.
    I don't know if anyone else has had issues with mounting a chainguide on the SB? I ended up having to mill 2.5mm off the ISCG mounts to get the chainguide to sit right. I don't know if it's a bike issue or an issue with the Blackspire Stinger. The other option was to add an additional spacer to the BB cup but it would have thrown the chain line out.
    Spec:-
    2012 SB-66 Frame (Medium)
    Fox 36 Van R Forks
    Fox RP23 Kashima shock - Swapping this for a Push tuned Van-RC as soon as it arrives
    Hope Tech V2 - 203/185 Floating rotors - Goodridge hoses
    SRAM X9 Mech + Shifters, Goodridge cables
    XT DM Front Mech
    SDG I Beam Post + Bel Air saddle
    Easton EA70 Bars + ODI Rogue grips
    Truvativ Hussefelt 50mm Stem
    DT Swiss 440 hubs on Mavic EN321/DT E540 Rims
    Maxxis Minion ST DH-F / Maxxis Highroller 60a Rear
    Rough weight with the coil - 35lbs maybe.
    I'm not trusted to add photos until I get to 10 posts, I've uploaded a couple to my gallery though.
    Nice build you have there, may I know what is the down tube protector that you are using? How to obtain 1? Thanks.
  3. #903
    Availiable on UK ebay - search for Rockguardz.
    Just bolts onto the bottle cage mounts.
  4. #904
    Thanks man, nice but expensive stuff.
  5. #905
    Cam
    Reputation: Cam_C's Avatar
    I've been enjoying seeing all of the SB-66's you all have been posting while patiently (and impatiently) waiting for mine to arrive.
    Finally, as of today, it's here and built! So I thought I'd share. I went all out and went carbon. I didn't go all out on the components as I think XT is pretty high quality and the $ you save not going XTR can be better spent elsewhere. So this is the Race build kit. I've got a KS Lev dropper post to add to it and I will likely replace the wheels some time soon with some wider rimmed version.
    So far I only got to run it around Golden Gate Park for the last hour of daylight, but I can already tell this thing is a shredder. I can't wait to get it out on the real trails this weekend and open it up full throttle!
    Cheers!
  6. #906
    Reputation: yeti575inCA's Avatar
    Dec 2011
    Quote Originally Posted by Cam_C View Post
    Cheers!
    nice...
  7. #907
    Mar 2012
    Chris,
    I just had the Ti bolt snap on me when i did a tear down the other day to get rid of some annoying creak. Was using the recommended TQ spec as well... what did you use as the steel replacement for the shock mount? It's too late for me at this point because I needed a new bolt ASAP since I was sending my bike with my sister on her drive to BC. I had to rush order a ti bolt and I got reamed pretty good.
    Flying out of dreadful illinois and riding the yeti in Squamish next week! Stoked! Might have to head up to whistler one day... how did the yeti fair up there?
  8. #908
    Reputation: Splatt2801's Avatar
    May 2012
    Hi Everyone
    I need some help and advice. I have just received the ISCG mount for my yeti sb66 and fitted to the BB I place of the 2.5mm spacer. The problem I am now having is when I fit MRP 2x chain guide the middle ring is too closer to the back plate.
    I have tried all spacers variations but my chain still rubs flush on the back plate. Installation guide shows it should be flush with the BB but It just doesn't work.
    My cranks are XTR dual rings 40/28. Has anyone else had similar problems. I'd like to keep two rings on the front hence buying this chainguide. Any thoughts or solutions.
  9. #909
    Reputation: Dogboy's Avatar
    Quote Originally Posted by Splatt2801 View Post
    Hi Everyone
    The ISCG mount does not replace the 2.5mm spacer on the drive side. The BB width *with the ISCG mount is 73mm, so you still need the spacer on there.
  10. #910
    May 2012
    I have also tried tried it with the ISCG mount, then the 2.5mm spacer but the chain still seems to rub the back plate.
  11. #911
    May 2012
    Hey guys.
    I have worked it out. This needs to be removed to fit it. It is the cap surrounding the BB frame section.
    Now it fits perfectly. No rubbing and smooth. So chuffed.
  12. #912
    I would like to show you my SB-66, I've build it a few month ago.
    Frame: SB-66 Lime M
    Fork: Fox 36 Talas 160 Factory
    Shock: Fox RP23
    142x12mm Axle
    Headset: Acros
    Stem: Easton Havoc 50mm
    Bars: Easton Haven Carbon 710mm
    Post: Rock Shox Reverb
    Brakes: Hope M4 203mm/180mm
    Cranks: XT
    Shifters: XTR
    Front Der: XT
    Rear Der. XTR
    Wheels: Easton Haven UST
    Tires: Schwalbe Fat Albert UST
    Pedals: Blackspire Sub4
    Hope you guys like it.
    Attached Thumbnails Attached Thumbnails Yeti SB-66 Build thread-img_1606.jpg
  13. #913
    Reputation: bikeboardorblade's Avatar
    I'm curios as to the difference the braided hoses make, as opposed to regular hoses. Any thoughts or insights there?
  14. #914
    Reputation: mtbnozpikr's Avatar
    Quote Originally Posted by bikeboardorblade View Post
    There are some reasons but honestly think that the main reason is the bling factor on them. There will be slightly less deformation in the brake lines when you squeeze the lever which would translate to a more firm, crisp lever feel, they are more durable, and are more resilient to kinking.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  15. #915
    Well, they are blingin! I have been looking for a crisper feel. Thanks
  16. #916
    Who makes the saddle on LEIF's lime SB?
    Put that in your pipe and smoke it!
  17. #917
    It's a Specialized Henge Comp
  18. #918
    Hello all,
    I'm new to these forums, just ordered an SB-66 Race this past weekend, waiting for it to arrive. Yesterday the guy at the LBS called to say that Yeti had changed the spec on the front fork to the 2013 Fox line. He says this means that I will get a Fox Float 34 rather than the 32. Since the 34 has a 160mm travel rather than the 150mm travel of the 32, does anyone think that this is a big deal from either the geometry or weight point of view?
    Apparently this change also means the price has gone up by $100. I've got a call into the LBS to see if the rear shock is upgraded to the 2013 CTD as well, and to see if it's the version with or without the Trail adjust.
    Matt
  19. #919
    Dec 2011
    Quote Originally Posted by mattnj View Post
    Hello all,
    Matt
    Hi Matt, I just got my XT race with the 34 Fork, it comes with the spacer in the fork putting it at 150mm travel, its an easy removal if you want to go up to 160mm. Hope this helps
  20. #920
    Jun 2012
    Go with 160mm 34's, I have and it's great.
  21. #921
    I've gone down the 34 route as well. Pics to follow!
  22. #922
    Jun 2012
    The axle to crown on 36 is much longer than the 32 but 34 is closer (same?) so the 160mm travel is negligible.
    The 36 fork is approx 25 mm longer irrespective of the extra 10mm travel, that was the reason some people (Yeti included) dropped the travel to 150mm to try get geometry back inline but was still a degree slacker.
    The 34 should be a perfect fork for the SB.
    I am with 36 Talas so can drop for climbing and get by any issues of the longer axle to crown dimension. At full travel it is noticeably light on front end with steep terrain. The CoG gets pushed back very easily when seated with the seat tube angle as it is combined with front end height at full travel on 36 fork.
    Steed: Yeti SB-66
  23. #923
    Jun 2012
    Quote Originally Posted by Welchy View Post
    Should have said I went for Talas forks but wish I went for Floats now, not had the need to drop them down.
  24. #924
    Thanks for all the replies everybody! Nice to know that the 34 is a good choice for the bike and that I can change from a 150mm travel to the 160mm travel if I want.
    weeman32 - did your frame come with a Float CTD shock, and if so did it have the Trail Adjust feature or not?
    Looking forward to getting the bike, hopefully in about a week.
  25. #925
    Dec 2011
    I got mine last week, it's a Carbon. And yes it came with the CTD Trail Adjust shock, absolutley love it! Forks and shock work well together :-).
    Regards
    Phil
  26. #926
    Good news, thanks. Carbon, congrats I'm jealous. It was out of my price range though.
    Matt
  27. #927
    Has anyone spent time with both the 150 34 and the 150 32? I was quite disappointed with the stiffness (or lack thereof) of the 32 after coming off of a 36.
  28. #928
    thanks LEIF for the info.
    I can't believe I didn't say this earlier... NICE BIKE!
  29. #929
    Hey everyone, new here and just recently purchased the sb-66 xo/x9 package. Absolutely love how the bike rides an handles but i just find the handle bars to be a little to wide, it came with the Easton Haven CF 720mm handlebars. I would like to buy another bars that are shorter in width but i at the same time not compromise the ride quality or the whole geometry of this bike. What would u guys recommend. Thanks again
  30. #930
    Reputation: CLAW's Avatar
    Cut'em
    Quote Originally Posted by jMac5 View Post
    I'd recommend cutting the bars that you have. If you don't have to the tools to do it at home, take it to your local shop and they can do it for you. It will be much cheaper than buying a new set of bars.
  31. #931
    Reputation: DJ Giggity's Avatar
    The Havens are some of the nicest bars out there. No need to upgrade there. Give them a bit of time before cutting. You can't go back once you cut them and 720mm is not that wide.
    Only two infinite things exist: the universe and stupidity. And, I am unsure of the universe
    - Albert Einstein
  32. #932
    Quote Originally Posted by CLAW View Post
    Thought about cutting it man but i wasnt sure if it was safe to do in regards to the bar becoming weak when cut. Anyways, how much do i cut in the sides if was going to cut it ?
    Quote Originally Posted by DJ Giggity View Post
    Good point too man cuz iv only ridden it once ur certainly right about not being able to go back once its cut
    Thanks again
  33. #933
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    Haven's are 711mm not 720mm
    http://www.eastoncycling.com/en-us/m...n/haven-carbon
  34. #934
    Chilling out
    Reputation: bear's Avatar
    My advice is to slide the grips/brakes/etc in-board 1.4" at a time to find the sweet spot you are looking for, before cutting or replacing. The Yeti lock-on (and any lock-on grip for that matter) really make this easy. Just don't poke yourself with the protruding bar.
  35. #935
    I've finally finished the built I wanted for my SB66!
    Frame: Medium Yeti SB-66 White
    Fork: Fox 34 160mm Talas CTD
    Shock: Fox Float CTD
    Headset: Chris King Inset 2
    Stem: Thomson X4 50mm
    Bars: Easton Havoc Carbon 750mm
    Post: Thomson Masterpiece 30.9mm
    Seatpot Clamp: Thomson Seatpost Collar 34.9
    Seat: Yeti Team Devo WTB Saddle
    Brakes: Shimano XTR Trail BL-M988 (F/R)
    Rear Shifter: Shimano XTR i-Spec
    Cranks: Shimano XTR Trail M980
    Chainring: Shimano Saint 36T
    Chainguide: e*Thirteen TRS+
    Chain: Shimano XTR CN-M980
    Cassette: Shimano XTR CS-M980 11-36T
    Rear Der. Shimano XTR RD-M985 Shadow Plus
    Wheels: DT Swiss Tricon XM1550
    Axle Kit: 12x142mm Shimano M988 Thru Axle w/ Yeti X12 Chipset
    Pedals: Shimano XTR PD-M985
    Tires: Maxxis Minion DHF 2.5 Front & Maxxis Ikon 2.2 Rear w/ Tubeless Kit
    Extras: Yeti Frame Protectors, Yeti Grips
  36. #936
    Jan 2009
    Quote Originally Posted by kickbike View Post
    Hi there,
    Mind sharing where on earth did you get that Yeti Devo saddle? I've been searching hi and lo for it The Yeti Rocket Vs are easily available online but is too large for my liking.
    Thanks.
  37. #937
    Quote Originally Posted by Proxyserv View Post
    Hi there,
    Thanks.
    Those are Team Only! got it from a friend who knows a guy...who race for...the same story!
  38. #938
    Jan 2009
    Ahhh...you've got connections
    BTW, nice build
  39. #939
    Longing for dirt
    Nice build Kickbike! Hiw much does your bike weigh?
  40. #940
    Oct 2007
    Cool-blue Rhythm My SB66c
    EDIT: Moved this post to the carbon build forum:
    SB66 Carbon build thread - Page 10 - Mtbr Forums
  41. #941
    Chilling out
    m1neral, I love that picture, that's great stuff!
  42. #942
    Jun 2012
    Bear +1
    Steed: Yeti SB-66
  43. #943
    Quote Originally Posted by joe_soma View Post
    no idea, I'll get it for you
  44. #944
    Reputation: Bubbolo's Avatar
    May 2012
    My SB66
    This is my first post here, my name is Jacopo and i'm from Italy
    Here you are my SB66 just after a ride in Monte Morello, the mountain near Florence (Italy), it's not clean, but i love it
    Frame: Small
    Ammo: RS Monarch Plus RC3
    Headset: Cane Creek tapered
    Fork: RS Lyrik Air DH, 170mm, maybe one day i'll try it at 160mm
    Stem: Funn Funduro black, 45mm
    Bar: Funn Fatboy orange cut a 730mm
    Commands: Shimano XT
    Brakes: Formula R1
    Disk: Alligator 180-160
    Crankset: Shimano XTR, 165mm, 26/38
    Pedals: Shimano XTR Trail
    Der: Shimano XTR
    Rear der: Shimano XTR
    Cogs: Shimano XT 11/36 10v
    Wheelset: Crank Iodine black/orange
    Seatpost: Blacx Jewel AM 110mm
    Saddle: SDG Duster Ti white/grey
    Grips: Yeti of course
    Other stuff: E-Thirteen Heim chain guide; FRM 142mm rear axle (replace the heavy Shimano, it weights 47 gr less); vintage Crud Catcher as down tube protection
    Weight is 13,9 Kg with Maxxis High Roller LUST 2,35 and Stan sealant
    Happy riding !
    Cheers
    Jacopo
  45. #945
    I Like Bicycles
    Reputation: Thimk's Avatar
    #1 Norco Aurum LE
    #2 Yeti SB-66
    #3 Evil Sovereign
  46. #946
    I really like your color scheme a lot. Nice job on a good looking build.
    2012 Intense M9
    2008 Look 595
  47. #947
    Jun 2012
    Not one the same...
    Great rides Bubblo and Thimk. Amazing how unique all our builds are!!!
    Got mine finally finished to orginal custom spec I ordered. Has took some time to get the white rims, chain device, correct chain rings and 12/142 axle & mounts sorted but they got there in the end. Its like getting a new bike since I have been riding with wrong (black) wheels and without other bits mentioned.
    Steed: Yeti SB-66
  48. #948
    There's some excellent custom builds in here!
    How are you healing up Dazzler?
    Mine is finally built and ready! I'm a very happy man. Weighing in at just under 31lb and burly enough for the DH runs.
    Frame: Medium
    Shock: Cane Creek Double Barrel Air
    Headset: Chris King
    Fork: 2013 Fox 34 Float CTD 160mm
    Stem: Easton Havoc 35 (50mm)
    Bar: Easton Havoc 35 Carbon
    Brakes: Shimano Saint & XT Ice-tech Rotors
    Crankset: Shimano XTR, 165mm, w/ 34t Gamut Race Ring
    Chain Guide: MRP G2 SL
    Pedals: Crank Brothers Candy
    Rear Der: Shimano Saint w/ Clutch
    Cassette: Shimano XT 11/34 10SPD
    Wheelset: Mavic Crossmax ST
    Tyres: Maxxis Minion DHF 2.3 (Front), Maxxis Ardent 2.3 Lust (Rear) - Both Tubeless
    Seatpost: RockShox Reverb
    Saddle: Specialized Phenom Expert
    Grips: ODI
    Cables: Gore Ride On (Gear) & Goodridge (Brakes)
  49. #949
    Jun 2012
    Thats the dogs-do-dah's BZ!!!! A lot of peeps will be interested in the CCDB performance as much written on its progressive nature.
    I am doing great thanks, fitness and climbing is well ahead of pre-broken leg levels, descents are just about back on track after gaining confidence and getting used to SB. It is an amazing machine and only just having got suspension (FR & RR) dialled I am just starting to really reap the benefits. I had both ends to firm and slowly reduced spring rate and compression. Loving the levels of control and flow the bike gives. It feels so composed is best way to describe it.
    How you fettled? How you finding the SB?
    Steed: Yeti SB-66
  50. #950
    Jun 2012
    oh and how do you make your SB stand up????
    Steed: Yeti SB-66
  51. #951
    For those who have spent time on the new 34s, how do they feel in terms of stiffness? After a few 36s the 32 felt way too flimsy. I'm thinking a 32 or 34 with a 20mm axle would have been money.
  52. #952
    Quote Originally Posted by Dazzler2409 View Post
    It's just well trained!
    Managed to get it built just in time for the gravity enduro at Dyfi Forest. Nice rocky, fast descents to tune the shock in. The CCDBAir feels amazing to me, small adjustments make big differences to the handling. Although some suggest a Monarch for the frame, I had a good offer from the cane creek and that decided it for me.
    The bike as a whole is confidence inspiring. I haven't ridden anything yet where I felt that I needed the DH bike. If anything the lighter bike is easier to handle. I just need to get a few more rides in to get the shocks all dialled in. I was expecting alot more pedal bob during climbs on the 66 frame, I can't say how much is down to my settings on the ccdbair but it pedals really well.
    Glad to hear you're getting back on the trails Dazzler, time has flown, it seems only yesterday I put my hand in a cast!
    As for the 34's - I was unsure whether to go for 36's again. I spoke to the guys at Mojo in the UK and over a few phone calls the team riders all suggested the 34 as it supposedly offers more control in the corners. I honestly can't notice too much difference between the 34 & 36, although the 34 feels a lot more plush and stable than the 2012 float 32 on my hardtail. That combined with the 1lb weight saving over the 36 swayed the decision for me. I'm also very impressed with the CTD.
  53. #953
    The_Afterman
    Reputation: Zinglespeeder's Avatar
    Quote Originally Posted by Bubbolo View Post
    Frame: Small
    Brakes: Formula R1
    Der: Shimano XTR
    Happy riding !
    Cheers
    Jacopo
    Hey Jacopo,
    If you don't mind me asking, how tall are you?
    "Don't stop when you're tired. Stop when you're done"
    -Mojo HD
    -Niner AIR 9 Carbon SS
    -Zion 737 EBB SS
  54. #954
    Nov 2012
    To the M-Size-Riders: How tall are you? I´am 6' (182cm) and didn´t know what size is better. Medium or Large? I ride more technical trails.
    Sorry for my bad english.
  55. #955
    Jun 2012
    Hi Osbow,
    I am 5'10" (1.79m) and ride a medium. It is perfect for me with a short 50mm stem. It has a real good long reach for a medium. I think a 70mm stem would be perfect for you especially if you prefer a more technical ride, more XC I would consider Large.
    As for bad language... We all speak the same lingo on the Yeti thread no matter where you come from
    Steed: Yeti SB-66
  56. #956
    Reputation: GlennW's Avatar
    Jun 2012
    I'm 5'7" and riding a medium SB66, which I totally dig the fit & riding position of. Depends how you like your bike to fit... I have a mate who's 6" and rides a medium 575 and really likes it.
    Not really doing much Ridin' or Diggin'
  57. #957
    Nov 2012
    Hey Dazzler2409,
    thank you for your feedback! My size is terrible. I´am always between the sizes. :/
    What do you think about the combo: Large with a short 35mm stem?
    Just another question: Does the Shimano XT FD-M786 Downswing fit?
  58. #958
    Quote Originally Posted by osbow View Post
    It uses a direct mount derailleur - 786-D.
  59. #959
    Jan 2011
    @osbow - What do you think about the combo: Large with a short 35mm stem?
    I ride a medium and with the longer top tube of the SB66 find myself most comfortable on a 35mm stem. It's great for descending, but I do catch myself fighting to keep the front wheel down on steeper climbs. Alternately when I run a 50mm stem it definitely climbs better, but gives up a bit on descending.
  60. #960
    Nov 2012
    hey brkel, how tall are you?
  61. #961
    Jan 2011
    osbow - hey brkel, how tall are you?
    I'm 5'-9" riding a medium SB66. With a medium frame I find it takes a conscious effort to re-centre your body wieght (forward on the turns / centered for jumps) wereas on a shorter TT bike it seems to happen more naturally.
    I do find though for steep, rooty, rocky sections the long TT / wheelbase make for a very stable bike and allow you to carry some extra speed through those sections.
  62. #962
    yep
    Reputation: yboc's Avatar
    Nov 2012
    Hey guys, I'm going to be getting my first bike next spring and I'm leaning towards an SB66 right now. I'm trying to come up with a build for one, but I don't know much about all the components yet so I need some help. I'm 6'2, 200lbs and looking to do basic AM with both climbing and descending and my budget is $4000. The frame locally is $1700 so I'm trying to figure out what sort of build I can do for $2300. Anyone willing to help me get an idea?
  63. #963
    Quote Originally Posted by yboc View Post
    Its doable. It takes time and what I would recommend doing is making an Excel spreadsheet, and then listing each part and then pricing each part out. Here's an example:
    Attached Files Attached Files
  64. #964
    Jun 2012
    It's a wide open question yboc which the answer is very dependant on your riding style, trail types, etc.
    I spread my budget wisely and invested in all non-consumable items with a for a fairly burly build including 36 talas, hope hoops (Stans Flow rims) hope M4 brakes, Renthal bar/stem, Joplin 4 dropper. I went with SLX complete drive train (2x10) which I can upgrade as it wears out. This allowed me to pump money in to the bread & butter stuff you wouldn't likely replace. A wise punt I think as drive train is consumable and can be upgraded over coming years...
    This is a very strong heavy build that isn't a quick as a more XC orientated light weight buil but gives me a good confident ride. I ride without much finesse and @ 220lbs (me not bike!) it felt better suited for me.
    A 32 fork for XC tilt, 34 for XC/AM and 36 for AM/FR is a good guide. I would suggest 2 foot, 4 foot and 6 foot drops respectively should categorise reasonably well!?!
    Steed: Yeti SB-66
  65. #965
    Jun 2012
    Haha... Bikeboard' I did very similar spreadsheet (without the weight) to help derive the optimum build for me when I was spec'ing up my SB. Quick easy to juggle components about to balance budget across the build. I really enjoy this process, which was my first custom build. I spent many weeks with not too much hurry as I was laid up with broken leg so helped me through a rough spell.
    All good now that bike is built and I am back in the saddle loving every mile!!!
    Steed: Yeti SB-66
  66. #966
    Dazzler2409, I have to say this spreadsheet has been quite fun to piece together until buying time comes. I wouldn't call me a weight weenie by any means, but I figured while I was at it I'd add it on and see about where I'd be at. I'd say your categorization of forks is fairly accurate, I just wish I could get a non CTD Fox 34.
  67. #967
    Jun 2012
    To be fair I may have gone for a 34 fork had they been an option when I got mine. Not sure about the simplicity of the CTD though? I prefer the scope of the RC2 FIT to tune the perfect custom handling. I think the CTD detracts from the ability to do this. I am heavier build and therefore CTD doesn't allow to tune for this without FOX service centre tuning, I would imagine the D to be under damped?
    Steed: Yeti SB-66
  68. #968
    yep
    Nov 2012
    Thanks guys.
    I will definitely do a spreadsheet to kind of get an idea of what parts to get. Right now I'm still trying to learn about all the different parts, and trying to get an idea what might work best for me.
    I live in Utah, so there's quite a bit of mountain trails and also a lot of desert ones down south. As far as what kind of riding I'll be doing, its vague I know but I really think I'll be pretty versatile with it. Definitely some lengthy trail rides with climbs, and some technical and speedy descents as I progress too. I come from a offroad motorcycle background so some jumping, and flowy riding is also something I'd like to do.
    I honestly have so many questions about parts, I don't even know where to start.
  69. #969
    Dazzler, it sounds like we have similar concerns with the 34. While I haven't ridden one myself, the general consensus from other is the that all the tuning "options" end up limiting the its ability to be fine-tuned, which I think would only be magnified for those that are lighter or heavier than what the fork was tuned for.
    yboc, if it helps I'm up in Ogden. Where do you normally ride? I think a SLX kit is a great way to go. As a kit the weight is just a bit more than XT, but the breaks are arguably just as powerful and the cranks just as stiff. If you can fit a Reverb into the build it is definitely worth it, especially with all the ups and downs Utah has. Its the best upgrade I've made to a bike thus far.
  70. #970
    Dec 2011
    Guys moving into a sb66 frommy 575... I have the 2012 xt 3x cranks and plan to ad a bash guard in place of the big ring. What's the right xt or xtr front derailleur to run with that set up..
    Mr. Knowitall
    Reputation: hssp's Avatar
    Quote Originally Posted by yeti575inCA View Post
    none
  72. #972
    Dec 2011
    Lol don't have the legs or lungs for that set up!
  73. #973
    Reputation: adamkob32's Avatar
    Oct 2012
    I'm having problems finding an SB-66 Alloy Frame Medium in the Turquoise color. Anyone see any available lately? Thanks.
  74. #974
    Mar 2012
    I just bought a Carbon on Saturday. Went in wanting the Aluminium one. It was going to take about 2 months for the dealer to get an alloy version. Apparently everyone has been scooping them up like hot cakes, combined with a low number (in comparison to other brands) made.
  75. #975
    Nov 2012
    Did anybody use the Iscg Tabs for a Chainguide? What is the advantage over a Iscg an BB-Mounting?
  76. #976
    Jun 2012
    I just used mine this week, just went for a Blackspire Stinger, fitted and works a treat although will give it a proper run at the weekend. I think it fits better using the ISCG.
  77. #977
    Mr. Knowitall
    BB mount is a halfway solution when you have no ISCG. Not really holding things well in place.
  78. #978
    Jun 2012
    Have you considered going with a stock build? They are are hard to beat for value. Those dont suit folks with strong feelings about many individual components, but that doesn't sound like you (yet). I just got the Enduro plus and aside from the wheels and crank I'm fine with the spec considering the cost. The crank I was able to swap out at no cost, and I'm guessing the wheel upgrade will cost me about $200 (selling stock wheels and buying what I want). Just a thought. Not as fun as picking out each part, but for a given budget you might end up ahead.
  79. #979
    Nov 2012
    I´am looking for a headset for my sb-66 I can use for my frame? I have the Fox F36 Float R 160 fork.
  80. #980
    Chris King InSet 2 Headset
    Will fit a treat assuming your forks have a tapered steerer...
  81. #981
    Just Ride!!!!!
    Reputation: mecam's Avatar
    When you guys got your frames, did you re-torque all the pivot axle bolts, pinch bolts, etc to 90-in/lbs? That seems awfully lot, no? I would think 70-in/lbs would be enough.
  82. #982
    Reputation: drbelleville's Avatar
    Quote Originally Posted by mecam View Post
    I wonder if the Torque values seeming higher than expected to you perhaps may be attributed to some of the fasteners being Titanium?
    Yet there are no changes between the manuals (2011-2013) as far as torque values are concerned on the SB66
  83. #983
    Just Ride!!!!!
    Quote Originally Posted by drbelleville View Post
    I broke two of the Titanium M6x1x12mm shock bolts already torquing them at 90in/lbs so I just torque them at 70in/lbs. Many other SB66 owners have broke the same screws also and some have switched to stainless steel. I'm just wondering if the specified 90in/lbs on the manual is really mandatory.
  84. #984
    Oct 2012
    Finally finished up my SB66. Weight came in at 31lbs.
  85. #985
    Bike all done, no more upgrades (we all know that's not true). X-Post All Mountain.
  86. #986
    Oct 2012
    So just want to verify that I have the rear hyrolic line run correctly. I was just going over the bike now after the first ride on Sunday and noticed some markings on the Switch piece. The line also had some rubbings on it. Is this normal, is there a better way to run that line?
  87. #987
    Chilling out
    Quote Originally Posted by adamkob32 View Post
    ... I was just going over the bike now after the first ride on Sunday and noticed some markings on the Switch piece. The line also had some rubbings on it. Is this normal, is there a better way to run that line?
    I have a hard time imagining a better hose routing, but had the same problem on my SB95.
    My fix was to zip-tie the hose to the vertical member of the rear triangle, so it wouldn't move at all.
    Ugly, but no more rub.
  88. #988
    May 2010
    Long time lurker, first time poster. I demo'd a SB66c with full XTR and Fox 34 fork before building my bike. After the demo I knew I wanted a SB66 but didn't have $7000+ for the carbon xtr version. I was able to build mine for about $4000. Everything on it was new and I got the fork second hand but it was a takeoff from a new bike and the steer tube was uncut.
    This was my first bike build and I was able to put everything together without any professional help other than youtube videos. I bought the frame from Competitive Cyclist (on special for $1760 with CTD shock) and most of the parts from Jenson. A lot of the parts were discounted b/c they didn't include original packaging so that helped on the price a lot.
    Frame - Size Large (color is white)
    Headset - Cane Creek (installed by CC before shipping)
    Fork - Fox Float 150
    Shock - Fox CTD
    Wheels - 2012 Mavic Crossmax ST
    Brakes - XTR Race
    Rotors - XT Ice Tech (160 r and 180 f)
    Shifters - XTR
    Cranks - 2x10 XT
    Cassette - 10 spd XT
    Chain - XT
    Front and Rear Derailleur - XT
    Bars - Easton Vice
    Stem - 70mm Thompson
    Seatpost - Easton Vice
    Seat - WTB
    Pedals - CB Eggbeaters
    Grips - Yeti Logo ODI
    Tires - 2.35 Nevegal front / 2.2 WTB Velociraptor rear
    I'm installing a Bionicon V.02 chain guide this weekend and will report back on how it performs. Sorry for the crappy pic but I haven't had a chance to take some good ones. I have about 5 rides on the bike and I'm very happy with it. My last bike was a 2009 Fuel EX 8 that I owned for 3 years so that's all I really have to compare it to.
  89. #989
    May 2010
    Has anyone used a chainstay protector or tape to protect the painted part of the upper and lower chainstay on the drive side? My chain doesn't cause a problem but sometimes the sole of my shoe will rub and it's surprisingly hard to get the scuff marks off especially on white paint. My temporary solution is to wrap black electrical tape around the area where my shoe rubs.
  90. #990
    Rides a Bike
    Reputation: fishboy2807's Avatar
    Frameskin can help there
    Yes, in fact I developed a kit that protects the frame from this exact issue (boot scuffing and other general chips/scrapes etc). Cheers Alan
    Quote Originally Posted by mblittle View Post
    Frameskin™ Bike Protection Film
    Protect your plaything!
    www.frameskin.com
    Supporting Kowalski Brothers Trailworks
  91. #991
    Rides a Bike
    That would be great, as I am thinking of carrying this product and was interested to see what people thought of it. Alan
    www.frameskin.com
  92. #992
    Chilling out
    Quote Originally Posted by fishboy2807 View Post
    I've been using the Bionicon since June when I got my '95 and like it. It's not what I call "DH" worthy - I just don't think it's up to that level of (ab)use, but as an XC/AM device I think it's good.
    I have an MRP XCG bash on my machine on the ISCG tabs, I like that they're separate, but if I get into much enduro/superD racing I would not be surprised to need a more solid tensioner/guide.
  93. #993
    Oct 2012
    Just got done with the mid-winter tear down and rebuild here, upgraded to XT Shadow+ rear and a Fox DHX RC4 coil (300lb) in the process. I wish it would get a little better around here for a ride. Hoping on getting out on Monday to try out the new goods. Current weight now is 32 lbs and with a 120lb rider I'm pretty happy with that.
    --Adam
  94. #994
    Nice build. The DHX-RC4 makes the SB66 so good it's silly.
  95. #995
    ill be buying a double barrel air pretty soon to replace that rp23. just am not getting at all the ride i want out of that thing.
  96. #996
    Ride TAS
    Quote Originally Posted by treestump View Post
    I have seen your bike out and about a couple of times and that trail you are about to go down at Kate Reed is awesome for this type of bike. Mine is set up a bit different but rips the new trail at Trevallyn.
  97. #997
    Quote Originally Posted by morebravo View Post
    Yeah awesome. There aren't many of them around here. Have you got one of the other black ones from Sprung? It works pretty well for the trails around here, wish I had a set of Fox 34s though! What are you running on yours?
  98. #998
    Anyone have experience on the carbon version? I've ridden one twice now and really have a good time on it. Any noticeable differences?
    And also, I've browsed through a few pages and it looks like most are ~30lbs mark. Any builds get any lower than 30?
  99. #999
    Feb 2012
    Long Long time lurker
    but heres mine !
    Yeti SB-66A
    __________________________________________________
    Frame, Fork & Shock
    Frame: Yeti SB-66A (Large) Turquiose
    Fork: Fox 34 Float 150 FIT CTD w/Trail Adjust
    Rear Shock: Fox RP23 w/Kashima (8.5"x2.5")
    Drivetrain
    Crankset: Shimano XTR M980 175mm
    Bottom Bracket: Shimano XTR
    Chainrings: Shimano XTR 33T
    Chain: KMC X10SL Gold
    Pedals: Shimano XTR M985 Trail
    Front Derailleur: cSixx HD XC Guide
    Rear Derailleur: SRAM X0 Type2 10spd (med cage)
    Rear Shifter: SRAM X0 10x Trigger
    Cassette: Shimano XT M771 10spd (11-36T)
    Gear Cable: Jagwire L3
    Brakeset
    Brakes: Shimano XT M785
    Adapters: Shimano F180P/P2
    Rotors : Shimano XT RT86 Ice-Tech 6-Bolt 180F/160R
    Controls
    Handlebar: Azonic World Force 2" Riser
    Grip: Generic Blue Lock-on
    Stem: Thomson X4 (70 x 0o)
    Headset: Cane Creek Forty
    Saddle: WTB Rocket V Titanium
    Seat Post: Thomson Masterpiece Inline 30.9 x 350mm
    Seat Clamp: Salsa Flip-Lock 35.0
    Wheels & Tyres
    Front Rim: ZTR Flow 26" 32 Hole
    Rear Rim: ZTR Flow 26" 32 Hole
    Front Hub: Hope Pro II Evo
    Rear Hub: Hope Pro II Evo
    Spokes: DT Swiss Comp
    Skewer: Shimano XT M780
    Front Tyre: Schwalbe Hans Dampf 2.35 Evo Snakeskin TL Ready TrailStar
    Rear Tyre: Schwalbe Racing Ralph 2.10 Evo TL PaceStar
    Tubes: Stan's 35mm Valves, 25mm Rim tape and Tire Sealant
    Total weight - 13.52 kg
  100. #1000
    Feb 2012
    dammit !
    cant post pics !!!
  1. Yeti Build / Pics Thread Index
    By crisillo in forum Yeti
    Last Post: 05-22-2017, 01:27 PM
  2. Yeti 575 2010 build Sram xo build
    By britishboy in forum Yeti
    Last Post: 05-02-2011, 04:28 PM
  3. Replies: 19
    Last Post: 02-15-2009, 05:46 AM
  4. Full build pictures of Yeti SS and Yeti FR bike
    By ryan_daugherty in forum Downhill - Freeride
    Last Post: 04-22-2008, 03:23 PM
  5. Replies: 8
    Last Post: 05-13-2007, 03:52 PM
Members who have read this thread: 32
