Results 1 to 3 of 3
    Living in a Wasted State
    Dec 2008
    Yeti guys- DT 240s hub conversion question
    Tried searching, both here and on DT's website. Hoping someone can help me.
    I am looking at buying a wheel set from a Yeti AR5, its the 240s/400ex hub/wheel combo. So its currently a 15mm t/a up front. I need a 20mm t/a.
    Does anyone know if the hub spec'ed on this build is the 240s oversized, (which could be converted to a 20mm t/a), or if its the 240s 15/tricon (which doesn't appear to be able to be converted to a 20mm t/a)
    dtswiss.com/getdoc/1d40b543-4340-4f5b-9393-3e98275b1bc4/Tech_specs_Convertion-Kits-Axle-System.aspx
    Is there any way to tell by looking at the hub which the seller has? If its IS its a 240s oversized, and if its a center lock hub its the dt240s 15/tricon?
    Reputation: KentM's Avatar
    Aug 2010
    Send an email to DT Swiss directly. David is great about responding quickly. They are in Grand Junction, CO, so they might be closed now. PM me and I can give you David's email.
    solution
    Hello Backcountry1pr
    I am Paul Guebara
    I am on the marketing and sales team for DT Swiss.
    The hub you have on that wheel set can definitely be converted to 20mm. It is indeed a 20mm oversized hub that we convert to 15mm for yeti.
    No problem.
    If you have any more questions - email me at first initial then last name at DT Swiss.com
    Cheers.
    Paul Guebara
    Sales and Marketing Team
