Results 1 to 71 of 71
    snickers driven
    Reputation: MTB ABQ's Avatar
    yeti in da house! ASR5
    joined the tribe precisely at 1.15 today, been a long time coming. Meet my new ASR-5, large alloy enduro kit, in gunmetal slate grey. Hooo boy! Upgraded brakes to hayes stroker trails, now she's a rockin
    Reputation: casnell's Avatar
    Noice!
    Nice!!
    Good to see that you got the new fox forks
    Mai
    Mai is offline
    Reputation: Mai's Avatar
    Feb 2006
    Welcome to The TRIBE
    Two roads diverged in a yellow wood and I,
    I took the road less traveled by and
    It has made all the difference. R Frost
    Calm like a Bomb
    Reputation: stunzeed's Avatar
    welcome..sick bike
    Count me in to. Small with the Enduro kit.
    I swapped out the wheels and tires for Stans ZTR Olympic rims with Hope Pro II hubs and Conti Mountain King 2.2 tubeless.
    I'd like it to lose some more weight eventually without going $$ crazy, but aside from replacing my ancient Shimano M521 pedals, seatpost, and handlebar, I'm not sure what I might reasonably do.
    If it ever stops raining in Denver, I might actually get to ride it.
    snickers driven
    thx everyone, I've been having a ball: better climber, better descender, and the jumps! she's so light on her feet, seems she just wants to float off every whoopty-doo. Schweet!
    Reputation: nixgame22's Avatar
    Beautiful bike! Quick question, how tall are you?
    Maintain internal heights.
    snickers driven
    6', 6'-1" in cleats. M definitely too small in the 5, while I was thinking the med 575 could've been built up to fit.
    Quote Originally Posted by Rufhausen
    Hi Rufhausen
    Nice bike, How tall are you? I'm 5.3" so I don't know if the S or XS is the best opcion for mee. Do you know the weight (original and after you modcifications). Also do you know the large of the size of the stem. Thansk!!
    Awesomist™
    Reputation: Full Trucker's Avatar
    Quote Originally Posted by MTB ABQ
    Schweet ride! Great color! Dang, I really really want mine now... at least it's raining in Golden at the moment and the trails are soaked. Boo...
    Quote Originally Posted by twin
    My girlfriend is between 5'1" and 5'2" and she's ridden both the S and XS. We just ordered her the XS, she felt it fit much better. Her good friend is a couple inches taller and got the S. That may or may not be of much help to you?
    The older I get, the faster I was.
    Punch it, Chewie.
    Reputation: cducati's Avatar
    I have the same bike!
    Nice choice.
    The only issues I've had is the the Mavic Cross Ride hubs. They are center lock but come with a 6 bolt adaptor... my discks are 6 bolt. I had both retainer rings come loose! The rear came loose and allowed the disk to spin on the 6 bolt adapter. Not good.
    It's such a nice XC bike! My fist FS bike as well and SUPER easy to ride hard!
    Go get it dirty!
    Oh.... I'm 6 feet tall and went with a medium.
    snickers driven
    dirty deed done!
    dirty? done! put 32 miles on her this weekend, incl her first scratch, sniff. what a fun ride!
    Hey, can you snap a pic of your rear deraileur cable routing as it exits the swing arm?
    I think I may have too much of a loop happening.
    again, SUPER nice bike....
    I'm running the 575 brakes. They are OK, but I can't find much info at all on them. I've got a 180mm rotor and adaptor going on this week. That should help. nice Hayes setup.
    Hi Rufhausen
    I'm 5'6". I demoed the Medium and it just felt a little big while the Small felt perfect in the shop, though there's not a whole lot of difference between the two in terms of geometry.
    Looks like only .2 inches difference in standover height between XS and S, but that's affected by the tires and the stock tires are bigger than what I have. The effective top tube length might be more of a determining factor for you, depending on how long your arms are, etc.
    I don't know the weight before the wheelset/tires swap, but I can feel the difference for sure.
    I'll have to check on the stem.
    Quote Originally Posted by cducati
    Thanks.
    I have a rather large loop that's caused some rubbing as the cable housing enters the rear of the swin arm.
    Time to re adjust.
    snickers driven
    beat me to it, but mine is much the same as ncativo's above. Happy trails!
    Beautiful Bike..
    What does that thing weigh? Is the back end stiff laterally?
    How is the bob going up hill? Do you have to use pro pedal?
    This bike is on my short list and I do not want to spend the extra to go carbon....yours is awesome in that grey.
    snickers driven
    Quote Originally Posted by twelve34
    (edit): 29-30 pounds on the kitchen scale. She's very responsive in acceleration, railing the turns.
    She is a stellar climber, best I've ridden hands down, but I'm certainly no bike guru. No propedal required, tho you can feel her stiffen a bit with it on the lightest of 3 settings. I played around a bit w/ propedal this weekend, ended up just leaving it off for last coupla rides, the last ride a strenuous uphill out and back- Faulty Trail. As for color, she's a matte anodized gunmetal gray, little bit o blue undertone tinting the gray, subtle + super schweet.
    more asr5 ride info here on mtbr
    asr5 review on the blahg
    575 review on blog
    asr5 vs 575 review on blog
    Jun 2010
    Here's Mine In White
    Another new member, had my 5 (alloy) for 2 months/100 miles now and love it. Mine came in at 27.5 lbs (pedals on).
    Quote Originally Posted by awd123
Name:	Yeti ASR5 160610.jpg
    Congras!
    What size? I saw that you have slx so can you put you components? did you buy just the frame?
    Jun 2010
    Bought as a custom build from LBS as no complete ASR5's available at that time in the UK. Size is medium. Build as follows: -
    Brakes/Crank/Shifters/Mechs all Shimano SLX
    Heatset - Chris King
    Stem - Thomson
    Bars - Moneylite XC70 carbon
    Seat post - Race Face Evolve
    Saddle - Yeti SDG
    Wheels - Stans 355 (tubeless) with Hope Pro II hubs
    Tires - Maxxis Ignitor
    Grips - Yeti lock on
    Pedals - DMR V8
    Stem - Thomson
    Saddle - Yeti SDG
    Pedals - DMR V8
    Nice. May I ask, why alloy? and not carbon. ride type?
    Jun 2010
    Didn't consider carbon as total bike cost would have been too much (for me), extra £600 (I think) over the alloy for 1 lbs weigh saving.
    Also I usually keep my bike's for a long time and upgrade as I go and tend to agree with the review in What Mountain Bike, they tested the alloy vs. carbon back to back and came to the conclusion that the alloy would be more durable for long term ownership.
    I saw the review too. Do you have it? can you scan and post it? 1 lb is a tentation. Anyway congras again and enjoy it.
    bye
    Reputation: bikesinmud's Avatar
    Dec 2005
    me too
    Large Carbon at 5.06lbs arrived today at 10am. Waiting on the kit for the build to commence. Cheers!
    my carbon ships tomorrow morning!
    Nice frame!
    Mine weighs in at 27.5 with pedals as well.
    I ride with the propedal ON.
    It's still blow out if you take a big hit and feels super plush.
    I don't see a need for a carbon frame, in my case, but they sure do look nice.
    You could shed some weight with hubs, wheels, seatpost stem, etc and get nice and light.
    It's just fine for me as it is!
    I LOVE the greay anodized as well.
    The 2010's also have a moulded chainstay guard on the drive side lower and upper!
    Nice colour.
    I actually wanted a white frame but I would have had to wait 4 weeks for that.
    Something i was not willing to do.
    I'm ready to get my 5 but I can't figure out which frame size to get. I ride a large fsr xc right now and it seems just a little big but the medium was too small. When I compared geometrys to the 5, the medium 5 was closer to my large fsr. I'm 5,11 with a 33.5 inseam so I'm right on the bubble for frame size. Without being able to demo in my area, it's a tough decision.
    I'd rather a frame on the smaller side then one that's just too big.
    You can alway adjust parts to fit you if the frame is a bit small... longer stem layback seat post, etc.
    YMMV.
    Jun 2010
    Not sure, but if it's any help I'm 5 9" with a medium 5, have low riser bars and 90cm stem. Feels like I've got plenty of room but I would have a concern about how much higher I would need the seat post if I was taller.
    May 2010
    Hi Rufhausen
    I'm 5'7" and the small is perfect - go smaller. As for weight look at Wheels - most bang for the $$$
    Has anyone else with the Small noticed an issue with the bottle cage location making it difficult to use the Pro Pedal lever when using a standard water bottle? I'm using the basic $4 bottle cage from REI. I'm wondering if there are cages with the hole in a higher position on the cage to make the bottle sit lower.
    I think is better if you put a picture of you situation. I use the carbon cage Elite they are very good and they have "the hole longer" check this link, but maybe you have to pay a little more than 4 usd
    http://cgi.ebay.com/Elite-carbon-fib...item439fcdf231
    P.S. cmon 3000 usd bike and 4 water cage, something is wrong in this picture
    OK, here's the picture of my $4 cage on my 3k bike. Now, I'm no bottle cage aficionado, but in my experience the $4 variety hold a bottle as well as the $50 variety, albeit at the expense of some weight. But I digress... I picked up a couple of the smaller bottles (500ml/21oz. ?) and will just go with that for now. My Perpetuem or Heed will just be more concentrated.
    I glad that you fix the trouble. I use a lot my water cage. I'm not use too much my camell bag. I know spend 45 usd in a carbon water cage can be too much but you bike will say "thank you" but the way I bought two in ebay for 34 usd
    Bike, I mean bye
    May 2010
    My Yeti dealer had a cage that you take out the bottle from the side - never seen one before, I was skeptical, but it works great.
    Quote Originally Posted by STEAMBOATBUCKEYE
    I've seen one of those as well, but the issue is that a standard bottle will rub the pro pedal lever, making it hard to use and making it easy to move the lever when removing the bottle (side load or not).
    Did an awesome ride out at Buffalo Creek, CO today with some smaller bottles and all is well, so no more worries.
    American Made!
    Reputation: 1x1clyde's Avatar
    White Carbon Large, absolutely love this bike!
    I9 wheelset with Stans Arch Rims running 12x142 rear dropout
    Full SRAM XX group
    Sunline V1 745mm Handlebar and Sunline XC1 stem 80mm
    Crank Bros Joplin 4 with Remote
    25.7 lbs with Time pedals
    I've been riding this beauty for over a month and the only drawback is not enough time to ride seriously I've got over 300 miles on her already and she rips!
    The only thing I wish for is a bit longer fork for some of the steeper rock rolls found in sunny socal but I just get back as far as possible to keep her rolling
    What is thy bidding, my master.
    Argument for alloy....
    Beautiful bike; your comment about wanting the longer fork further cements my conclusion that if I get this bike, alloy would be the way to go so I can do a 140 fork......
    Have yall seen the Yeti CA roadtrip vid they posted last week? It's got a ridiculous NorCal segment of Aaron Gwin riding the piss out of his 5... how it was meant to be ridden. Hellsyeah.
    http://www.yeticycles.com/#/video/new/2010California/
    new asr-5c in the house
    Here's my ASR-5C enduro build in size small. I dropped over a pound by swapping out the seatpost, stem, bars and grips, and probably another half pound in tires. It sits at a little over 25lbs on a bathroom scale.
    I've got 3 rides and a race in on it and it's a fast bike. With pro-pedal on there is minimal bob out of the saddle and with it off, the rear suspension is plenty plush for bombing down hill. Bombing downhill is definitely what this bike was designed to do. The 68* HTA slows things up in tight single track a tad, but makes the bike a beast down the hill. Another advantage to the HTA is jumps. The bike is very neutral in the air and is much less prone to endo's.
    The bike is stiff and feels tough. I've already got a big wreck on it thanks to the stock 27" bars. I was bombing through a rock garden at my local trail and clipped a tree, sent me over the bars, with a badly bruised leg, but the bike was fine, not even a scratch.
    Although the bike feels perfectly setup for trail riding, I plan on XC racing it all season. The only thing you give up is fork bob with the 120mm up front. At 25lbs it's XC weight and i plan on losing another pound in wheels and another pound in brakes and 10 speed components. At 23 lbs it will be a great xc/trail/endurance racer.
    May 2010
    how much did u spend in lightening it up? I considered it, then went with the race buld - 26 lbs with pedals, so probably similar - my wife might have strangled me obsessing over grams to replace parts on my new bike!
    I got the monkeylite bars off craigslist for $80, F99 stem was $90, grips were $15, and the Thomson seatpost I had from my old bike.
    Congratulations!! Nice.
    You came for a specialized fsr, right? what year and model.? How you fell the difference between both bikes?
    That's cool that you are enjoying the bike. good for you
    Ehh I didn't see the water bottle
    we need more pictures.
    Congrastulations!! Nice.
    Ehh I didn dee the water bottle
    How works the brakes? do you fell the diference between the forks (QR / 15mm)?
    I have an 07 SJ FSR Elite. The Triad shock is pretty bad, lots of pedal bob, and the rear triangle has lots of flex. The Yeti is a much stiffer bike, accelerates faster, and holds a line much better. Also I think the 120mm front fork is better matched for my riding versus the 140 on the SJ. The tapered 15qr fork feels really stiff.
    The enduro components are OK, nothing to write home about. I'll end up replacing everything down the road. I like my Juicy 7's better than the LX on the Yeti, but the LX gets the job done.
    Quote Originally Posted by blantonator
    I have the stumpjumper Expert 2006 (talas 90-130, triad, juicy 7, xt) in small size. I think Yeti will be a good opcion for me, maybe I will buy the alloy a Ilke the carbon but i want something that I can use for other 5 years( The true is I think the carbon can break a little more easy). Anyway good for you as I said we need more pictures
    SEEE YOUUU in the trails
    get the carbon, it will last plenty strong.
    some pics from a local race. got 2nd.
    and one more
    Great!! good for you.
    where are pictures from the podium?
    I've got about 100 miles on mine now in pretty short order including loop 2 of the upcoming Breckenridge 100 course which was a blast.
    Watch out for the pivots in the rear suspension and the bolts for the dropouts in the rear loosening up a bit in your first 100 miles.
    I just had my free checkup at the shop and hope I'm now good to go for a long while.
    May 2010
    sweeeeet
    New question here. hows the joplin going
    Quote Originally Posted by 1x1clyde
    Full SRAM XX group
    How is the joplin holding up, any good ? looking at getting one formy 06 575....cheers
    Trainings Cheating
    Reputation: danlate's Avatar
    mine after a few mods. its the best bike i've ever ridden!
    Nice!.
    The rear triangle is carbon too, but painted right? So why they don’t do sell the bike in WHITE, I mean the whole bike in white. It will be cool, maybe next year.
    Somebody knows when do we have the new model for 2011?
    Reputation: fizzywater's Avatar
    Wow....the ASR5 looks gorgeous in that blue front/white rear combination.
    Is this how the blue frame looks stock or did you make some paint changes?
    Also, is this the Medium frame?
    I am still drooling all over my desk...what a beautiful bike!
    American Made!
    Quote Originally Posted by pinknz
    This is my 2nd Joplin, I have the original on my Tracer VP, and its running fine!
    Once you go adjustable, you never go back
    Quote Originally Posted by fizzywater
    thanks
    this is the stock blue frame, no changes. Its a medium.
    Dec 2010
    See my Yeti ASR5a in slate grey
    Been running this baby for the last 9 months and still loving every minute of the ride. Check it out:
    - Stans ZTR Alphine rim with HopePro II hubs and Kenda Nevegal tubeless 1.9 front - 2.1 rear
    - Chris King threadless headset
    - Thomson x4 stem 80mm
    - Shimano 2011 Deore XT Groupset with XT brake
    - Easton EC90 SL Carbon Riser Bar 635mm
    - Fizik Gobi XM saddle
    - Xpedo G-Force1 pedal
    - 2012 Rock Shox Reverb Seat Post (just got it less than a month)
    - in photo, it is still in Thomson Elite Seat Post
    Total $$ to build = US$4500 every penny well spent :-)
    Man !!! You look really happy .....GREAT !!
    Dec 2010
    with my legs over Yeti, can't help but smile :-)
    Nice bike!
  67. #67
    Dec 2010
    Thanks armo
  68. #68
    Reputation: BobGolden's Avatar
    Just put together my wife's demo from Go-Ride, and now my 5 has a little sister.
  69. #69
    Scandinavian
    Hello guys. I am thinking of changing my present FS 150 mm bike with a ASR 5. Preferably the Carbon version.
    I am 172 cm (5"7' i believe?) and often falls in between frame sizes. After comparing size charts I have no doubts that Small is the size for me with this bike.
    When looking at pictures at other peoples Small i find them showing kind of different frame designs. In this thread Rufhausen and Blantonator are showing pictures of their bikes, both quoted as size Small. Ruf's bike has got a toptube slanting slightly upwards against the seatpost, while Blant's bike seems to have a downward slanting. Are both bikes really size Small, or could this be different for alu and carbon frames?
    As I am also considering just a new frame and fork and transfering the other parts I have some further questions:
    *How is the compatibility widt Truvativ Hammerschmidt crankset?
    *Does the rearframe take 2.4 tires ( Big betty, Rubber Queen, Fat Albert)
    And for last, a kind of offtopic question, but might make me reuse my awesome fork:
    *Is it possible to reduce travel on my Fox Talas 150(120) RLC FIT fork to 140-120?
  70. #70
    Quote Originally Posted by Cmon77 View Post
    Hi
    The bikes are diferent in alloy and carbon check the shock position in the frame, alloy has different position than the carbon. I just order my bike that comes with 140 and the shop reduce to 120 without trouble, Where I ride I don't need the 140 mm of travel fork.
    bye
  71. #71
    Quote Originally Posted by blantonator View Post
    Looks like wakefield, I know that exact spot. Should've gotten more air...
