Results 1 to 3 of 3
    Reputation: Gabe3's Avatar
    yeti asrc with 100mm fork
    has anyone put a 100mm fork on the asrc? the yeti site says its designed to be used with a 120 or 140mm. bad idea to use a 100mm?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    If you read through the dedicated thread for the ASRc, you'll see that there are a few guys riding it at 100mm.
    Personally, having ridden it at 100mm and 120mm, I prefer it at 120mm for XC racing.
    Death from Below.
    Here's my two cents. I just built my asrc and adjusted the fork from my jet9 from 100 to 120 and I could never go back. I blitzed through sections that would have me on the brakes before. Most all rockshox can have the travel adjusted. I only need a longer air shaft and it was only $25. Fairly easy to swap.
  1. JET 9 RDO vs YETI ASRc vs Pivot 429SL??
    By SUB1647 in forum Niner Bikes
    Last Post: 09-25-2016, 10:41 AM
  2. Replies: 0
    Last Post: 04-01-2016, 02:02 PM
  3. Yeti asrc value used
    By ssuperlight in forum Yeti
    Last Post: 10-17-2015, 03:15 PM
  4. JET 9 RDO vs YETI ASRc vs Pivot 429SL??
    By SUB1647 in forum 29er Bikes
    Last Post: 01-23-2015, 08:58 AM
  5. New 2012 Yeti ASRc build
    By feltbee in forum Yeti
    Last Post: 03-31-2012, 06:09 AM
Members who have read this thread: 8
