Results 1 to 6 of 6
    Reputation: cryde's Avatar
    Oct 2007
    Yeti ARC Carbon -- Fork size?
    Hey All,
    Looking at picking up a new ARC C and wanted to see what thoughts were on going with the 120 fork vs the 100? Hard for me to decide or say at this point as I don't have an option to try one.
    Anybody ridden one yet?
    You gotta Get Up to Get Down!
    Tribe Member
    Reputation: yetirich's Avatar
    On the Yeti page, they recommend a 100mm fork
    Yeti Cycles / Home
    What travel suspension fork can I run?
    The ARC Carbon geometry was optimized for a 100mm Fox fork. You can run an 80mm or 120mm travel fork but it will change the handling and geometry (a shorter fork will make the bike steeper and quicker handling, while a longer fork will make it slacker and slower handling).
    Proud Tribe member since 1992 - looking for better singletrack to be ridden year round
    Oct 2007
    Thanks YetiRich....
    I had seen that and since it is still new and not yet out there too much I guess I'll probably stick with what is 'optimized'.
    As always 'decisions, decisions'....
    Reputation: smithcreek's Avatar
    Nov 2012
    Not sure about other manufacturers, but if you get a Fox 120 it can be turned into a 100 with an inexpensive spacer. Not sure if the new Fox forks can go from 100 to 120 though. I've got an ARC on order and just went with a 100.
    Reputation: Joules's Avatar
    Quote Originally Posted by smithcreek View Post
    This. Almost any air fork can be reduced by 20mm (or 10, 110 might even be the sweet spot, who's to say?), not all 100mm forks can be extended.
    Unless you are really worried about the weight, I'd rather have a spaced-down 120 than a fixed travel 100.
    Oct 2007
    Sweet...Thanks guys for the heads up and advice on that. Options are always good and that certainly covers the bases.
  1. Cane Creek 110 Crown race size for Carbon fork
    By driver bob in forum Niner Bikes
    Last Post: 03-03-2013, 03:13 PM
  2. 2011 Zaskar carbon med fork size?
    By mtrhead in forum GT
    Last Post: 10-11-2012, 01:23 AM
  3. Yeti ASR-7 Pro XTR =$3850 (Size XL Only)
    By BigBill in forum Where are the Best Deals?
    Last Post: 02-26-2012, 11:35 AM
  4. What size fork fits an RZ One Forty carbon??
    By ollllllo in forum Cannondale
    Last Post: 05-03-2011, 08:36 AM
  5. Help Air 9 size&carbon fork
    By bubbleblower in forum Niner Bikes
    Last Post: 03-06-2011, 01:18 PM
