Results 1 to 6 of 6
    Reputation: TRAIL CRANKER's Avatar
    New question here. YETI 575 Rear Tri.....?????
    Just a question i would like to know about the 08 575 front frame ,, would a the 575 rear triangle from 2009,10, 11,and 12 fit an 08 front frame?? I know their have been changes over the years just not sure if all years would be compatible...Just would like to know for future reference. .Thanks any help.!!
    13 On One Fatty
    08 YETI 575 BLK. C.King Hubs/Hadley
    96 Specialized Stump Jumper FS Tweaked
    Reputation: mtnbiketodd's Avatar
    I know 2005-2010 rears will work together. I just put my 2005 on my 2010 while I was waiting for a replacement.
    I'm ~100% sure 2011 and 2012 will NOT work on the older frames. They changed the seat tube.
    Good job!
    Quote Originally Posted by mtnbiketodd View Post
    Thanks Todd! Good to know , Anybody know for sure about 11 &12?? ,,Wonder if 2010 triangles were any more stronger??
    13 On One Fatty
    Reputation: GreenBonty's Avatar
    Quote Originally Posted by TRAIL CRANKER View Post
    The major change on the chain stays and pivot (borrowed from the 7) was done in 2011.
    Your best bet is to contact Yeti's CS. They'll know for sure
    Good luck!
    Ride Driven
    we used the same rear ends from 08-10, with different hardware they can be used on any 575 prior to 2011. '11 and '12 575 rears will only fit '11 or '12 575 fronts.
    Good job! Big Thanks
    Thanks every one!! ,just in case i crack my rear .
    13 On One Fatty
